Stratman Posted 9 hours ago Posted 9 hours ago Apologies if this has been concluded elsewhere on the forum - I've trawled and was unable to find a solution. My timber frame is up, windows in, roofing on, cladding commenced. I understand the sentiment surrounding log burning stoves being an expensive folly in a well insulated home, but we are determined nevertheless. The issue is that I cannot seem to find conclusive advise on the detail to pass a twinwall flue through the external timber frame wall at a 45 degree angle that satisfies building regulations and hopefully prevents the insulation from melting and the house bursting into flames ...which would be a bad thing! I've found Schiedel products such as the Ignis but the diagrams and discussions never seem to match my build up which is: AI helpfully suggests a gap between the flue and combustibles left completely empty with no insulation or airtightness!!! Can anyone help, please? Preferably with a solution that has actually been installed and signed off by building control. Thanks
ProDave Posted 9 hours ago Posted 9 hours ago I found an "insulated sleeve" for the purpose when I bought my flue. It is designed to clamp onto the outside of twinwall flue so must be non combustible to be able to do that, and is 50mm thick which then leaves anything that is combustible >50mm from the flue. The reality is my 5Kw stove even burning full tilt, the outside of the twin wall flue where it passes through the roof is barely warm to the touch. 1
JohnMo Posted 9 hours ago Posted 9 hours ago 3 minutes ago, Stratman said: AI helpfully suggests a gap between the flue and combustibles left completely empty with no insulation or airtightness!!! I framed out where the hole for the flue went through our roof (your wall in this case), using PIR insulation. The size was slightly larger than the distance required from combustible material. This left a closed void. Then filled the void after flue installed with Rockwool as it's a none combustible insulation. Then to get the airtightness back I used a flanged flue rubber diaphragm and taped to the the airtight membrane.
Stratman Posted 8 hours ago Author Posted 8 hours ago Both useful suggestions. Thank you. Does the insulated sleeve get cut back to the external face of the OSB then taped? What happens as the twinwall passes through the battening void and then the timber cladding? Presumably there would have to be a 50mm gap from the edge of the flue to the combustible cladding.
MPx Posted 3 hours ago Posted 3 hours ago Not helping your question I'm afraid, but I have one of my own for you. We would have liked a wood burner in our Passive std house. I never considered the issue of the flue and combustibles...we canned it on the need for airflow to the fire. Is the MVHR capable of supplying enough air to meet the fire regs? Last time we fitted a woodburner we had to have an enormous air brick put into the lounge wall to get the installation signed off - not really on in PH!
Nickfromwales Posted 2 hours ago Posted 2 hours ago 5 minutes ago, MPx said: Not helping your question I'm afraid, but I have one of my own for you. We would have liked a wood burner in our Passive std house. I never considered the issue of the flue and combustibles...we canned it on the need for airflow to the fire. Is the MVHR capable of supplying enough air to meet the fire regs? Last time we fitted a woodburner we had to have an enormous air brick put into the lounge wall to get the installation signed off - not really on in PH! You just fit a room sealed WBS that sucks air in from outdoors. 👍. Sad fact is, folk spend thousands fitting one, suffer silently in protest whilst roasting to death, and then it’ll eventually become an ornament. The further irony is the several hundreds of thousands spent making an airtight, well insulated home, that requires next to no heat at 0° OAT, and then fitting the most fierce heat source that you can lay your hands on….. The heart and the head are two very different things
JohnMo Posted 1 hour ago Posted 1 hour ago 55 minutes ago, Nickfromwales said: You just fit a room sealed WBS that sucks air in from outdoors. 👍. Sad fact is, folk spend thousands fitting one, suffer silently in protest whilst roasting to death, and then it’ll eventually become an ornament. The further irony is the several hundreds of thousands spent making an airtight, well insulated home, that requires next to no heat at 0° OAT, and then fitting the most fierce heat source that you can lay your hands on….. The heart and the head are two very different things You need a stove covered in soapstone and a low capacity to slow everything down. After the first year lighting ours twice and melting, we tried the second time the following year. But now only add one small log at a time, turn the air down to lowest setting to still get a clean burn. Now that log lasts maybe 1 to 2 hours, the heat spreads across the whole house, 2 logs on the coldest day is more than enough. 1 hour ago, MPx said: Is the MVHR capable of supplying enough air to meet the fire regs NO it leads to depressurisation of the house. You cannot install a WBS in a house with MVHR safety, unless it has primary and secondary air from outside. It is something the OP needs to think about and plan for. Where will they put the air duct, took us an age to find the correct stove
ProDave Posted 1 hour ago Posted 1 hour ago Ours works well as long as you open all the downstairs internal doors to let the heat out to the whole house and as above don't put much wood in at a time. Fill it full and keep the living room door shut and you will be cooking. It helps that we have double doors from the room with the stove to the hall from where heat can go up the stairwell and it nicely heats the whole house. We only have it because we have plentiful wood. I would not have one if I needed to buy wood, and if I did not have one I would be giving away or selling wood for someone else to burn.
