saveasteading Posted 4 hours ago Posted 4 hours ago Kitchen island going in now, using a fitter. I would like to screw the feet down, as we have one that moves if leant against. But the new one is bigger, heavier and has plumbing so probably won't move. The ufh pipes are omitted at the area. Screw into 40mm screed? Or maybe stick it down with silicon or tape?
Conor Posted 4 hours ago Posted 4 hours ago No need to fix down once you get worktops on and fill the cupboards.
dpmiller Posted 4 hours ago Posted 4 hours ago a bead of gripfil around some of the feet, if you must... 1
torre Posted 3 hours ago Posted 3 hours ago Our last kitchen came with a fix down bracket for the island and adhesive. If you've a lot of pan drawers on one side and a narrowish island then I'd say definitely. Less important if it's wide and cupboards below
Nickfromwales Posted 3 hours ago Posted 3 hours ago I just bond a 2x2 to the floor and the bottom of the end panels, x2 minimum, using cheap silicone so it’s easy to remove if you want to. There’s too much play in the legs to fix just a couple of those. 1
saveasteading Posted 3 hours ago Author Posted 3 hours ago Thanks all. The feet look better on this (Howdens) than the moving one* (benchmarx) and it is much bigger. I'm just thinking... one chance / shouldn't stress or rely on the plumbing. *It slides when leant on, then the legs snap or break off the base, then the kickboards have no support. I'll add some sticky stuff and have another look at it overall.
Nickfromwales Posted 2 hours ago Posted 2 hours ago 27 minutes ago, saveasteading said: Thanks all. The feet look better on this (Howdens) than the moving one* (benchmarx) and it is much bigger. I'm just thinking... one chance / shouldn't stress or rely on the plumbing. *It slides when leant on, then the legs snap or break off the base, then the kickboards have no support. I'll add some sticky stuff and have another look at it overall. Lifting the legs up one at a time, and then setting them back down again into a blob of CT1 (10p piece sized is fine) will be ample over the number of legs. I’d say you’d be fine doing this with just the front legs, so easy to do / easy to reverse without going commando on your belly.
saveasteading Posted 1 hour ago Author Posted 1 hour ago 1 hour ago, Nickfromwales said: easy to reverse without going commando on your belly. Not a pretty sight. And then there is getting out again. How did I know it would be CT1? Or Snibbo as it used to be called.
