Advice needed re Perc tests - is it an issue if they were undertaken at a depth greater than 1m?
Hi everyone.  Would appreciate some advice.  I had some perc tests done to judge how large a soak away I required.  These were done at a depth of 1.8m at the drainage companies suggestion.
After completion of the tests I messaged some other drainage companies to get quotes for remedial work, and one stated that perc tests should not be deeper than 1m.  Is this correct?  What's the potential impact of going deeper than 1m?
What are the issues with the test results?  Draining too quick or too slow?
Why were they done so deep?
Why not re do at correct 1M depth?
Interesting question. The one metre depth may actually be to do with health and safety in terms of accessing an excavation without support.
If your house is on a slope, on a hillock then we don't want the water just running out further down, especially if it is from a septic tank for example. Sometimes it works to sit a soakaway deeper, for example there is a gravel layer a bit deeper down that can accept a bit of extra water. There is a trade off in that the excavation is deeper thus more cost.. but in a good gravel layer the soak away can be less extensive.
What you mention 1.8m depth seems more like an "Engineered" solution which can be elegant and offer best value for money while still performing.
Good questions. A soak away draining too quickly can be more easily mitigated than one that drains too slow, the too slow causes problems.  Often you just need to understand the ground composition, then adapt the design a bit.
