Should I contact planning enforcement about my own build?
Towards the start of my build, I had a site visit from planning enforcement because of a complaint on the roof being built too high. The officer was somewhat confused when they arrived and found that the house didn't actually have a roof yet. They revealed that they'd had complaints for 9 other things including not following the landscaping plans, when no landscaping was close to even starting. This led them to concluding that the complaints were obviously vexatious and I never heard from them again, other than to confirm the case had been shut.
The house has been completed now, and I'm willing to bet they received a variety of other nonsense complaints during that time. I'm wondering if it's worth contacting them myself now to ask them to officially confirm they're satisfied the house has been built to plans, or if its better to let sleeping dogs lie?
My concern on the former, is if it's inviting them to go through everything with a fine tooth comb, potentially leading them to find a wall is an inch out, then asking me to rebuild it or apply for a planning alteration, which I believe would invalidate the CIL relief. My concern with the latter, is that if they decided in the future to investigate a complaint of 'the wall is an inch too wide' they might try harder to find fault than if I had contacted them myself to take a general overview of the house.
If they have confirmed the case has been closed, I would just crack on
From experience, planning enforcement only tends to get involved when someone makes a complaint and draws things to their attention. Even then it has to be sufficiently serious for it to be worth them getting involved. Let's face it, I doubt if many on this forum have actually built their houses exactly in accordance with every requirement of their planning permission and there are very few enforcement cases raised on here.
The Council have confirmed the case is shut and my view is to let that very sleepy dog lie and steer well clear of it............................
Ohhh don't even think about picking up that phone.
Never ask a question you don't want the answer to. If they had issues you would be the first to know and know already.
Relax. The planners are well aware that the complaints were vexatious. if there are more then they will contact you.
I've had such complaints and as long as you aren't deliberately cheating then it goes away or needs a simple resolution such as retrospective approval..
eg.  to high?   above what? they don't know.
Too wide?  an inch is not remotely significant.
and so on.
If you've added a wing or converted an attic without permission then that's different.
Come back to us if there are any more contacts though, of course.
The consensus seems to very much be on the let sleeping dogs lie side. After the initial visit I placed a couple very visible ring cameras by the road side and that may also have discouraged further complaints as you can't take photos without being recorded doing so.
^ This 100%
When I applied for planning permission for a 2 storey house extension and a single storey garage extension I had 5 objections to planning from neighbours - all were over-ruled (3 because the extensions wouldn't be visible so them) and 2 other the reason for objections were already covered by the plans (obscured glass in one window for one side and no window on another wall for the other)
Having gained planning I then had to put up with further complaints from the two all thro the build - people can just be knobs about the pettiest things.
Final complaint was related to the boundary fence which I was re-instating to 6ft as per original and planning were advising that it could only be 3ft and I ended up telling the planning officer to take me to court if they wanted (in the meantime I made the 6ft fence into a 6ft gate :D ) which really pissed the neighbour off
Most planners are too busy. Chances are they won't give you anything in writing unless you apply for a certificate.
Take the advice - don't invite them unless absolutely needed. There's a small bit of leeway as houses can't be built mm perfect as on paper but there is obviously a limit as to how much it can be stretched.
My architect always said anything within the dimensions of a concrete block would probably be ok with planning.
Half a brick one planner told me. That was logical for a brick house, and a half brick each side of a door would then apply and becomes one brick.
I wonder how many people deliberately make a house bigger than drawn.
There's plenty cheating on other things eg a  "garage" without ramps or an "attic" that gets skylights.
100mm either side is what I've heard - which seems to tie up generally with the 2 comments above.
One area we were told to be very careful on is to not breach the 1m from the boundary rule in our area (for detached houses) as the LPA are generally quite hot on not creating a cramped/overcrowded look.
My instruction to the builder was very simple - no deviation from approved plans. After the nightmare we had with getting planning in the first place, I have no appetite for any further planning related battles.
Yes there are some parameters that you breach at your peril. Daylight and over shadowing of neighbours are one, traffic visibility splays another for example. Folk often bend the permissions a bit.. but it's a risky business!
If you do deviate from the plans then you should ask yourself, how confident am I that if I get pulled up I can get an amendment to planning? If I come to sell and a surveyor spots this are they going to write your house value down? If the house goes on fire for example could the insurers use a non compliance to angle towards refusing a claim?
It's best to check these things so you can make an informed judgement.
Agree, you might open a can of worms.
