Whenever we get extreme weather, the same questions come up.
So to answer them, I have created a calculator that works out the dewpoint temperatures and absolute humidity from air temperature and relative humidity.
You should be able to change the relevant cells, though I cannot check this as I do not have Excel (only Calc).  There is a text box giving instructions.
I have also added some of my local weather data as a time series.  This is as an example only and can be deleted, or replaced with your own data.
I hope it is useful.
Dewpoint and Absolute Humidity Calculator(Excel).xlsx
26 minutes ago, ToughButterCup said:
it is useful
Can be used to take a lot of the guess work out of it.
Could also be useful for controlling UFH in cooling mode, especially when you consider the statistical nature of thermodynamics.
It's a nice idea but my computer doesn't seem to like it. I downloaded the file into Excel but can't type into the input cells. I get a message saying the spreadsheet is protected.
An alternative for anybody having the same problems as me, is to use a psychrometric chart. I'm attaching one here and have marked it up with an example:
Relative humidity 70%, Temperature 20o C
Start at the top and follow the 70% line down to where it intersects 20o C on the x axis. Gives a dew point (wet bulb or saturation temperature) of 16.5o C.
Unlike @SteamyTea's spreadsheet, it doesn't account for different atmospheric pressures though. I'm not sure how much difference that makes.
psychrometric-chart-en-uk.pdf
