June 28Jun 28 Whenever we get extreme weather, the same questions come up. So to answer them, I have created a calculator that works out the dewpoint temperatures and absolute humidity from air temperature and relative humidity. You should be able to change the relevant cells, though I cannot check this as I do not have Excel (only Calc). There is a text box giving instructions. I have also added some of my local weather data as a time series. This is as an example only and can be deleted, or replaced with your own data. I hope it is useful. Dewpoint and Absolute Humidity Calculator(Excel).xlsx
June 29Jun 29 Author 26 minutes ago, ToughButterCup said: it is useful Can be used to take a lot of the guess work out of it. Could also be useful for controlling UFH in cooling mode, especially when you consider the statistical nature of thermodynamics.
June 29Jun 29 It's a nice idea but my computer doesn't seem to like it. I downloaded the file into Excel but can't type into the input cells. I get a message saying the spreadsheet is protected. An alternative for anybody having the same problems as me, is to use a psychrometric chart. I'm attaching one here and have marked it up with an example: Relative humidity 70%, Temperature 20o C Start at the top and follow the 70% line down to where it intersects 20o C on the x axis. Gives a dew point (wet bulb or saturation temperature) of 16.5o C. Unlike @SteamyTea's spreadsheet, it doesn't account for different atmospheric pressures though. I'm not sure how much difference that makes. psychrometric-chart-en-uk.pdf
June 30Jun 30 Author 5 hours ago, LnP said: I get a message saying the spreadsheet is protected That's odd, anyone else have that problem?
