Tennentslager Posted June 26 Posted June 26 I've bought the bath and taps and panels for three sides. Also two bits of 1m x 2.4m wall panel. Its a 1700 x 700 bath, old one has mould as it was never an over shower job. so first Q is if i need wriggle room for taps...is the height of new bath exactly as old? Can i fit a flexy? Next Q Its a long narrow bathroom. Replce tile area as is, with wallboard...or As wallboatd is 2400 x 2000 some other shape? finally, wallboard behind bath or butt against top. its a new straight shower bath, no lip, no nothing just square
Nickfromwales Posted June 26 Posted June 26 13 minutes ago, Tennentslager said: @Nickfromwales You're supposed to say it 3 times....... anyhoo So, what we see is getting removed and replaced? You've bought a shower bath? e.g. one that can be stood upright in, and has the correct additional reinforcement etc.
Tennentslager Posted June 26 Author Posted June 26 Aye But its used daily for disabled son, he likes a soak. And very occasionally for his support workers who have the odd shower. Ergo the shower curtain can be out of matey boys way. Its 90% for him 10% for staff team, how it looks is secondary to function.
Nickfromwales Posted June 26 Posted June 26 3 minutes ago, Tennentslager said: how it looks is secondary to function. Agreed, but a bath that's not meant to be stood in moves and flexes a LOT, which causes seals / silicones / grouts to perish and the same issues to repeat themselves. Most baths I fit with shower 'over' them are Trojan Cast. Bombproof. Even if only occasional use as a shower bath, it'll still need to not budge. I always fit a batten along the wall, 2mm shy of where the underside of the bath will be, and set the bath into a fat bead of CT1, and use the same to bond the back edge of the bath to a tanked or primered wall, before sealing again, and then tiling.
Tennentslager Posted 4 hours ago Author Posted 4 hours ago Not having much success... This i think turns off the bath tap. The stopcock under the kitchen turns off kitchen taps and feed to combi so also bath hot tap. BUT when I turn the red wheel the hex nut below also turns, afraid to keep turning it anti clockwise in case it pops off. I think hex nut is a retaining nut. Where am I going wrong here?
Nickfromwales Posted 4 hours ago Posted 4 hours ago Put a spanner on the hex nut to hold it still, and give it a slight tighten when you're done. The internals of this gate valve may have seized, as these don’t last forever and dislike being in one place forever and then being asked to move. If you’ve got a combi then you’re high pressure hot and cold, and gate valves should be replaced with lever 1/4 turn ball valves. Simple route is to switch off the stopcock to the whole house, drain down, cut the bath pipes and fit speed-fit isolators in , then put the water back on.
Tennentslager Posted 4 hours ago Author Posted 4 hours ago Its just spinning forever. Tired to turn off the whole block from the street but kid you not the on street one is 4 feet deep and the standard T key can't reach it. When I did the wash basin had to cut it the 15mm pipe live and push a speed fit valve in. That one only oozed out a small amount, the pressure in this one is a lot, the tap fairly pushes out water. Hmmm
