Mr Blobby Posted Wednesday at 14:53 Posted Wednesday at 14:53 Our manifolds have no gauges. Which is a bit disappointing as I would be rather interested to see flow and return temps at the manifold. I can't see any reason not to have temperature guages at the manifolds, am I missing something here? In short, is it a good thing to install some guages at the manifold? I would have thought it would be useful for commissioning, if nothing else.
JohnMo Posted Wednesday at 14:59 Posted Wednesday at 14:59 You can easily add them, I just read the flow and return temps of the heat pump and or performance monitoring.
Nickfromwales Posted Sunday at 18:13 Posted Sunday at 18:13 On 24/06/2026 at 15:53, Mr Blobby said: Our manifolds have no gauges. Which is a bit disappointing as I would be rather interested to see flow and return temps at the manifold. I can't see any reason not to have temperature guages at the manifolds, am I missing something here? In short, is it a good thing to install some guages at the manifold? I would have thought it would be useful for commissioning, if nothing else. Post a pic to see if the manifold has 1/4” pickets to take some friction fit ones which just push in. Or get some of these: https://www.bes.co.uk/clip-on-pipe-thermometer-63mm-22147/
Conor Posted yesterday at 07:41 Posted yesterday at 07:41 I got stick on fish tank / brewing thermometers. Not the most precise but gives you a good idea of what's going on.
Super_Paulie Posted yesterday at 09:29 Posted yesterday at 09:29 my manifold has something similar to these and i found/find them useful if not vital for the setup. But obviously to retrofit would be a draindown so maybe a clip on would be better. https://www.theunderfloorheatingcompany.co.uk/product/1-isolation-valve-set-with-temperature-gauge/?gad_source=1&gad_campaignid=22542092802&gbraid=0AAAAAD1Ow65gAx_VRbI9JILR8ijckwR5x&gclid=Cj0KCQjwr4jSBhCSARIsAOX1E-L8qu9NDV9_uDuhPT8w_ldVaAL7Rx7GMn_L-Z1GmznWEmXsUsFOWAoaAm9OEALw_wcB
JohnMo Posted yesterday at 10:24 Posted yesterday at 10:24 16 hours ago, Nickfromwales said: Or get some of these: https://www.bes.co.uk/clip-on-pipe-thermometer-63mm-22147/ I bought a couple of these, the accuracy is pretty pants, was running around 4 degs dT. My return was reading higher than the flow, so consigned to the useless parts bin.
Nickfromwales Posted 15 hours ago Posted 15 hours ago 10 hours ago, JohnMo said: I bought a couple of these, the accuracy is pretty pants, was running around 4 degs dT. My return was reading higher than the flow, so consigned to the useless parts bin. Amazon do some cheap digital ones, but then you are replacing the batteries periodically. The stock ones that come with the manifolds are pretty accurate, but not like an IR thermometer etc; #manageyourexpectations
dpmiller Posted 6 hours ago Posted 6 hours ago you can generally calibrate cheapo dial thermometers easily enough to match them at your chosen temp. On some the dial can be rotated, you can pull the bezel, pull the needle and reposition on others, or you might even be lucky and find a wee setting screw...
SimonD Posted 3 hours ago Posted 3 hours ago On 24/06/2026 at 15:53, Mr Blobby said: I can't see any reason not to have temperature guages at the manifolds, am I missing something here? It depends on whether you're looking to rely on them or not. The problem with temp gauges at the manifold is that the return one will show a combined return temp from all loops so you don't know if your individual loops are running at the correct dT. The flow one is okay, but personally I have a mixture of clip on k-type used with a digital thermometer and some bluetooth ones that provide datalogging back to a specific app - at least for commissioning and maintenance use - so each loop can be properly balanced. 1
Mr Blobby Posted 3 hours ago Author Posted 3 hours ago 3 minutes ago, SimonD said: temp gauges at the manifold is that the return one will show a combined return temp from all loops so you don't know if your individual loops are running at the correct dT My thoughts exactly 1 minute ago, SimonD said: I have a mixture of clip on k-type used with a digital thermometer and some bluetooth ones that provide datalogging back to a specific app Interesting. Do you leave these permanently in place, or just for commissioning? Do they clip on the UFH pipes below the manifold? Are they accurate enough, and do you have any links to products please.
