June 16Jun 16 Talking to a plumber tonight. He is F gas certified. He was explaining the difference with these heat pumps to the standard ones to me. It's all a bit beyond my understanding. Anyway I was asking him if I could have wet UFH on GF then air to air units upstairs to do heating if needed and cooling in summer, also probably 1 or 2 air units downstairs to cool. All off 1 outdoor unit. I think he is more in with Daikin and said they are bringing out something soon, however Samsung appear to do the perfect solution with the TDM plus / climate hub. Outdoor pump, pre plumbed cylinder and air to air units. It looks good, no doubt very costly?! Does anyone have any experience with this set up. Seems simpler to a luddite like me. I suppose cost will be the trade off for simplicity i've no doubt others like @JohnMo can knock something up just as good performance wise for a lot less dough, maybe even have 2 seperate outdoor units. It's just beyond my pay grade though. I wonder what cost would be for this and 5 or 6 indoor air con units and the cylinder. https://samsung-climatesolutions.com/gb/b2c/our-solutions/home/heat-pump-solutions/heating-cooling/tdm-plus.html
June 16Jun 16 Lots of ifs and buts on this one. There are only really three practical ways of moving the heat into and out of the building: water, air, refrigerant. Air specific heat capacity is poor so you need lots of volume and flow, refrigerant needs its own specific pipework, qualifications etc. with lots of limitations to things like pipework length. Water is definitely the most effective way to move the heat. The aircon units will probably also need condensate drainage so added complexity there. I don't think the solution is that simple, or not as simple as the Samsung marketing department makes it look. Maybe okay for a new build, but for a retrofit? I'm not so sure. Like with all these things, the complexity lies more in the cooling than in the heating, especially if you want aircon type cold.
June 16Jun 16 The F gas solution doesn't look cheap, may be wrong. Could be a good system, but I would go A2W and have fan coils (water to air) in bedrooms and normal wet UFH. A pragmatic design could be pretty simple. Design for heating, accept cooling may not be perfect but way better than not having cooling. UFH will make house feel way cooler than the air temperature is. The fan coils in bedrooms will leave rooms for a comfortable sleep. First job is looking at heat loss and sizing an outdoor unit. Then room by room heat loss. Design UFH (not some cut and paste job by UFH suppliers). Size fan coils to provide room heating at under 30 degs. Then run everything as a single zone. Fan coils will modulate fan speed to keep room temperature stable. The above assumes you are talking about a low energy house.
June 17Jun 17 Author The build will be relatively low energy, not approaching passive but certainly lower than most. I have to admit the air con type cooling does appeal to us. After I built our last house I said i'd never build another without aircon. It's a small luxury that I'd be happy to pay for. I suppose what I need to do is compare prices of a normal ashp for 1500 odd sq ft house versus this f gas system. I'm sure fan coils and UFH would have ok cooling capacity but would it be as good as a2a air con?! I think with the umbrella scheme the grant could be claimed either way. I asked AI and I think it was estimating the installation at 12-20k with the cost for the samsung gear estimated at 7-12k. I did ask AI about the distances of air con units from the pump and it was saying quite long, 7.5-10m. I imagine they are decent if Samsung market this as 1 unit can serve whole house. I'm a fair way off heat calcs yet as resubmitting a new planning app but will deffo be one to keep an eye on. The plumber was saying to me that with the f gas you don't get any heat loss from the pipework to the unit whereas with the A2W you do?
June 17Jun 17 1 hour ago, Oz07 said: think with the umbrella scheme the grant could be claimed either way Maybe not, A2A is ok for £2.5k only and almost no one is approved, so don't hold your breath on that one. If you assume UFH is just part of house build cost. It all doesn't have to cost a lot to build a good performance system. I never bothered with the grants, would rather pay myself than get ripped off. Simple direct UVC for DHW, cheap as chips, save around £1000 compared to pre plumbed heat pump one. Charge on time off use tariff. Would be surprised if you need more than a 4kW heat source, from size of house and assuming better than Building Regs. If you want Aircon performance add a mixing valve to system and run fan coils at 6 degs, or just oversize the fan coils, decent fan coils have the output data for different flow temps. Or do everything A2A, don't bother with UFH. Still do direct water heating. Spend the money saved on a good system with good airflow regulation. Having lived in hot countries a number of years, the airflow became a thing of hate, once the novelty wore off.
June 17Jun 17 11 hours ago, SimonD said: Lots of ifs and buts on this one. There are only really three practical ways of moving the heat into and out of the building: water, air, refrigerant. Air specific heat capacity is poor so you need lots of volume and flow, refrigerant needs its own specific pipework, qualifications etc. with lots of limitations to things like pipework length. Water is definitely the most effective way to move the heat. The aircon units will probably also need condensate drainage so added complexity there. I don't think the solution is that simple, or not as simple as the Samsung marketing department makes it look. Maybe okay for a new build, but for a retrofit? I'm not so sure. Like with all these things, the complexity lies more in the cooling than in the heating, especially if you want aircon type cold. 2 hours ago, Oz07 said: The build will be relatively low energy, not approaching passive but certainly lower than most. I have to admit the air con type cooling does appeal to us. After I built our last house I said i'd never build another without aircon. It's a small luxury that I'd be happy to pay for. I suppose what I need to do is compare prices of a normal ashp for 1500 odd sq ft house versus this f gas system. I'm sure fan coils and UFH would have ok cooling capacity but would it be as good as a2a air con?! I think with the umbrella scheme the grant could be claimed either way. I asked AI and I think it was estimating the installation at 12-20k with the cost for the samsung gear estimated at 7-12k. I did ask AI about the distances of air con units from the pump and it was saying quite long, 7.5-10m. I imagine they are decent if Samsung market this as 1 unit can serve whole house. I'm a fair way off heat calcs yet as resubmitting a new planning app but will deffo be one to keep an eye on. The plumber was saying to me that with the f gas you don't get any heat loss from the pipework to the unit whereas with the A2W you do? For a current (MBC PH TF) project, the decision has been made to go for fa refrigerant based setup for domestic heating / cooling (via UFH) plus DHW (all via a plate heat exchanger), and a second setup for all of the first floor space heating and cooling. There is some considerable distance between the external units (x2) and the internal units, and to overcome this it has been suggested that a manifolded system is utilised. This is outside my wheelhouse as I mostly do wet (hydronic) systems, so am learning here too, but this certainly overcomes distance issues without a problem. Sizeable dwelling, circa 400m2, but (apparently) the proposed Daikin setup will perform perfectly well here; I think the furthest 2/3 units are >20m from A-B. Going for remote mounted chassis tucked into newly (purposefully created) closet / plant spaces vs units on the walls.
June 17Jun 17 2 hours ago, Oz07 said: The plumber was saying to me that with the f gas you don't get any heat loss from the pipework to the unit whereas with the A2W you do? This is pretty much irrelevant tbh. The 'losses' aren't really losses as they go into the heated envelope of the house, so do their bit on contribution. Honestly, I'd wait and see what your heat loss calc says and then review from there as they may be so small if you're going near ph that even a 4kW heat pump would be too big. The other ball to chuck into the mix for a highly efficient house for heating is an exhaust air heat pump, which simultaneously deals with your heating, MVHR and DHW. The you can go multi-split for your air-con. Just make sure that the person doing your heat loss actually understands whole house MVHR and models the heat loss accordingly - lots don't and then calculate normal ventilation losses.
June 17Jun 17 1 hour ago, SimonD said: This is pretty much irrelevant tbh. The 'losses' aren't really losses as they go into the heated envelope of the house, so do their bit on contribution. It's relevant for any external pipework. I think this is more common in F-Gas installs as they tend to be retrofits (in domestic installs at least), and tends to be easier by running pipes all over the outside of the building. (Ugly for sure, but easier & cheaper). I expect retrofits to increasingly use a2a for this very reason. 4 hours ago, Oz07 said: ... I have to admit the air con type cooling does appeal to us. After I built our last house I said i'd never build another without aircon. It's a small luxury that I'd be happy to pay for This is the key decision point. If you're happy to pay for it, then an a2a (i.e. some sort of refrigerant based) system is the only way to get the "arctic gale" of an aircon system. Whether you combine one system with UFH & DHW or do two systems (potentially one exhaust air for UFH & DHW) comes down to shopping about, supplier selection and what they are comfortable working with. Cost wise it's probably a wash (one complex system vs two more conventional ones). A a2w heat pump with FCUs is likely cheaper to install and can perform very well (comfort and cost wise) if setup correctly. And is much more DIY-able if that's your truck. But it will never give the same frozen air blast of a2a
June 17Jun 17 Have a word with CoolEnergy in Grimsby - they might be able to provide the sort of solution you're looking for.
June 17Jun 17 Author 9 hours ago, JohnMo said: Maybe not, A2A is ok for £2.5k only and almost no one is approved, so don't hold your breath on that one. If you assume UFH is just part of house build cost. It all doesn't have to cost a lot to build a good performance system. I never bothered with the grants, would rather pay myself than get ripped off. Simple direct UVC for DHW, cheap as chips, save around £1000 compared to pre plumbed heat pump one. Charge on time off use tariff. Would be surprised if you need more than a 4kW heat source, from size of house and assuming better than Building Regs. If you want Aircon performance add a mixing valve to system and run fan coils at 6 degs, or just oversize the fan coils, decent fan coils have the output data for different flow temps. Or do everything A2A, don't bother with UFH. Still do direct water heating. Spend the money saved on a good system with good airflow regulation. Having lived in hot countries a number of years, the airflow became a thing of hate, once the novelty wore off. The plumber was telling me he knows some guy who is accredited who wants to do business with him. I think the idea is this guy finds the leads, gives the plumber the install job and this guy does the heat loss and mcs side. From my brief research I think the samsung option would qualify for the 7.5k grant as its doing A2W UFH, or would the cooling option on A2A rule it out? I know you never bothered with grants as you can DIY, unfortunately that is beyond me. I don't want to go to a full bells and whistles firm and pay massive overheads which wipe out the saving from the grant but I might be able to find a happy medium one man band / small firm installer and claim the grant somehow.
June 17Jun 17 Author 5 hours ago, joth said: It's relevant for any external pipework. I think this is more common in F-Gas installs as they tend to be retrofits (in domestic installs at least), and tends to be easier by running pipes all over the outside of the building. (Ugly for sure, but easier & cheaper). I expect retrofits to increasingly use a2a for this very reason. This is the key decision point. If you're happy to pay for it, then an a2a (i.e. some sort of refrigerant based) system is the only way to get the "arctic gale" of an aircon system. Whether you combine one system with UFH & DHW or do two systems (potentially one exhaust air for UFH & DHW) comes down to shopping about, supplier selection and what they are comfortable working with. Cost wise it's probably a wash (one complex system vs two more conventional ones). A a2w heat pump with FCUs is likely cheaper to install and can perform very well (comfort and cost wise) if setup correctly. And is much more DIY-able if that's your truck. But it will never give the same frozen air blast of a2a He was deffo on about external pipework but realistically my unit would be adjacent to the house so i suppose it's a red herring. I have seen some naff pipework all up the side of houses today which have had aircons fitted. I've just got to do the numbers. If I was happy to spunk say 5k on 2 aircon units, but I can get a combined A2W and A2A system for the same price or cheaper than 2 seperate systems then I suppose it's a goer. What would a realistic figure be for an A2W system with UFH GF and 4 or 5 FCU upstairs, installed, no DIY. 10k? lower? I was pretty set on using UFH on GF but would running whole house on A2A be a good idea? You don't see this much. If I can get an A2W set up with the FCU which performs very well cheaper then i'm happy to forgo the frost blast of AC. As long as it performs and cools the house then happy days. Would this option work out cheaper?
June 17Jun 17 Author 8 hours ago, Nickfromwales said: For a current (MBC PH TF) project, the decision has been made to go for fa refrigerant based setup for domestic heating / cooling (via UFH) plus DHW (all via a plate heat exchanger), and a second setup for all of the first floor space heating and cooling. There is some considerable distance between the external units (x2) and the internal units, and to overcome this it has been suggested that a manifolded system is utilised. This is outside my wheelhouse as I mostly do wet (hydronic) systems, so am learning here too, but this certainly overcomes distance issues without a problem. Sizeable dwelling, circa 400m2, but (apparently) the proposed Daikin setup will perform perfectly well here; I think the furthest 2/3 units are >20m from A-B. Going for remote mounted chassis tucked into newly (purposefully created) closet / plant spaces vs units on the walls. I think Samsung offer a charged unit or manifold or god knows what if you exceed the distance. Can't see it being needed on mine with clever placement of outside unit and pipework runs. It's only 1500 sq ft ish. Mine will be nowhere approaching Passive, but better than building regs. I've done the numbers on passive and it just doesn't work for me i'm happy to spend a few extra quid running the place and have the bandwidth free to think about other things.
June 18Jun 18 22 hours ago, Oz07 said: He was deffo on about external pipework but realistically my unit would be adjacent to the house so i suppose it's a red herring. I have seen some naff pipework all up the side of houses today which have had aircons fitted. I've just got to do the numbers. If I was happy to spunk say 5k on 2 aircon units, but I can get a combined A2W and A2A system for the same price or cheaper than 2 seperate systems then I suppose it's a goer. What would a realistic figure be for an A2W system with UFH GF and 4 or 5 FCU upstairs, installed, no DIY. 10k? lower? I was pretty set on using UFH on GF but would running whole house on A2A be a good idea? You don't see this much. If I can get an A2W set up with the FCU which performs very well cheaper then i'm happy to forgo the frost blast of AC. As long as it performs and cools the house then happy days. Would this option work out cheaper? It depends a lot on location (installers in expensive property areas charge more - somewhat justifiably as they no doubt have higher living costs themselves) However I'd be very surprised if you pay someone to supply & install A2W, UFH, 5 FCUs (and a DHW tank right?) for less that 15k. Not in the south-east, for sure. When I tendered my reno (in 2019) my builder quoted 8k to install just one ducted FCU on its own - without any A2W or plumbing work! That was obviously a throwaway quote for work they didn't want to take on, but still... FCUs are still not much loved in this country. If you do non-ducted / wall mount fan radiator it's probably a bit less. A decent bit less if your installer prices it as just another radiator install. 22 hours ago, Oz07 said: If I can get an A2W set up with the FCU which performs very well cheaper then i'm happy to forgo the frost blast of AC. As long as it performs and cools the house then happy days. Would this option work out cheaper? Cheaper to install, cheaper to run, or ... ? If self-installing it's almost certainly the cheapest way to get heating and effective cooling. I contracting out, too many variables to say Running costs - probably the cheapest option, considering reduced maintenance load vs 2 systems, and esp with the increased TOU shifting that UFH allows. 22 hours ago, Oz07 said: I was pretty set on using UFH on GF but would running whole house on A2A be a good idea? You don't see this much. I'd always say put the UFH in, if you're doing some sort of GF slab that would accept it. Even if not connected it gives so much future flexibility. Specifically, UFH in a well insulated slab is both ideal emitter for renewable heat sources (very low flow rate), but also doubles as a large heat battery (storage heater) so you can heat it up during cheap rate and coast through the peak period. A2A really can't do that . Edited June 18Jun 18 by joth
June 18Jun 18 Author 2 hours ago, joth said: It depends a lot on location (installers in expensive property areas charge more - somewhat justifiably as they no doubt have higher living costs themselves) However I'd be very surprised if you pay someone to supply & install A2W, UFH, 5 FCUs (and a DHW tank right?) for less that 15k. Not in the south-east, for sure. When I tendered my reno (in 2019) my builder quoted 8k to install just one ducted FCU on its own - without any A2W or plumbing work! That was obviously a throwaway quote for work they didn't want to take on, but still... FCUs are still not much loved in this country. If you do non-ducted / wall mount fan radiator it's probably a bit less. A decent bit less if your installer prices it as just another radiator install. Cheaper to install, cheaper to run, or ... ? If self-installing it's almost certainly the cheapest way to get heating and effective cooling. I contracting out, too many variables to say Running costs - probably the cheapest option, considering reduced maintenance load vs 2 systems, and esp with the increased TOU shifting that UFH allows. I'd always say put the UFH in, if you're doing some sort of GF slab that would accept it. Even if not connected it gives so much future flexibility. Specifically, UFH in a well insulated slab is both ideal emitter for renewable heat sources (very low flow rate), but also doubles as a large heat battery (storage heater) so you can heat it up during cheap rate and coast through the peak period. A2A really can't do that . Im Midlands so hopefully a bit more reasonable. If we exclude the price of UFH and manifold from the equation. I imagine I will have this whatever method of heating I choose. Also I will partially DIY this with either a plumber to connect up the manifold or both of us for the day to do the lot. Likewise can probably exclude the cost of cylinder as again will be fitted no matter what. So if the rest is 15k and can get the 7.5k grant then I suppose it's not too bad. If it starts getting up to 20k upwards or 15k and no grant then i would seriously be looking at a gas boiler (if SAP allows). Boiler installation, exc UFH and cylinder would easily come in below 5k supply and fit. Ideal world i'd like something like the Samsung option but like others I suspect it's pricey. I had a look at fan coils tonight online and the Daikin wall mounted ones look just like the aircon units. Are they just not as effective if powered by A2W instead of A2A? So if we say I was happy to spend 5k (guesstimate) on a couple of aircon units and a traditional boiler system would be 5K (all excluding UFH and Cylinder) then 10k is my baseline. If I am getting 7.5k grant back then I can look at spending around 17.5k on a system and still be happy. That's my man maths anyway.
June 18Jun 18 Author Do you need a condensate drain in the wall for these air cons and fan coils presumably?
June 18Jun 18 37 minutes ago, Oz07 said: 15k If your anywhere near there on a new build, something is well wrong. UFH the parts are cheap enough. Your heat pump doesn't need to cost much either, mine was £2100 including VAT, you can claim the VAT back on new build. I would do a direct cylinder and just do cheap rate water heating, a cylinder is about £500. Then it's a matter of sourcing the fan coils. One in each bedroom. If you want to run fan coils at low temp for cooling you need condensation drains on fan coils and an electronic mixer, other option (the sensible one) run it at same temp. Your most expensive bit is the fan coils. 54 minutes ago, Oz07 said: Boiler installation, If that's the fall back, why are you being anal about cooling - be pragmatic install A2W simply as above and actually have cooling. (Don't bother getting ripped off by a grant scheme)
June 19Jun 19 16 hours ago, Oz07 said: Are they just not as effective if powered by A2W instead of A2A? Define "effective". If you leave then running long enough, and ideally predict very hot weather and "get ahead" by starting cooling before the house is already overheating, they're extremely effective. It's what I use, and would happily specify in any build I'm doing the controls for. (But, i know i can do the work to make the home automation keep on top of the cooling demand. You don't *need* automation for this, but it takes a bit more proactive user intervention. I can't rely on the occupier being so diligent, and they may also do stupid things like leave shading up and open the windows when the outside temperature is hotter than inside) If you're more into waiting until it's unbearable then smashing the A/C into max, you need a2a AC. Edited June 19Jun 19 by joth
June 19Jun 19 16 hours ago, Oz07 said: Do you need a condensate drain in the wall for these air cons and fan coils presumably? For an a2a system, yes definitely. For a2w I'd recommend provisioning for it if it's not too difficult, but in practice I'd always run the water flow temperature above dew point so the condensate is not needed (and actually just creates a liability of drying out and creating bad smells)
June 21Jun 21 Author On 19/06/2026 at 10:49, joth said: For an a2a system, yes definitely. For a2w I'd recommend provisioning for it if it's not too difficult, but in practice I'd always run the water flow temperature above dew point so the condensate is not needed (and actually just creates a liability of drying out and creating bad smells) How do you keep the flow temp above the dew point? Is it a set static temperature or does it depend on the outside air temp and/or humidity. Do you have to do the same with the ufh? Does the system take care of this or do you manually have to set some kind of stat?
June 21Jun 21 Author On 18/06/2026 at 19:30, JohnMo said: If your anywhere near there on a new build, something is well wrong. UFH the parts are cheap enough. Your heat pump doesn't need to cost much either, mine was £2100 including VAT, you can claim the VAT back on new build. I would do a direct cylinder and just do cheap rate water heating, a cylinder is about £500. Then it's a matter of sourcing the fan coils. One in each bedroom. If you want to run fan coils at low temp for cooling you need condensation drains on fan coils and an electronic mixer, other option (the sensible one) run it at same temp. Your most expensive bit is the fan coils. If that's the fall back, why are you being anal about cooling - be pragmatic install A2W simply as above and actually have cooling. (Don't bother getting ripped off by a grant scheme) Good to know it will be less than i thought. Is there a good brand of fan coil to get or do you try and match the manufacturer of the heat pump? Presuming these heat if needed in winter too? When you say other option run at same temperature do you mean same temp as UFH? I'm pretty sure we can manage without the artic blast of AC as long as the fcu are effective. I am trying to take steps to reduce heat gain i have asked architect to specify a pergola off rear SE elevation with climbing plants on it. Should keep the worst of midday sun off the patio glazing. Running a condensate with dry trap wouldnt be the hardest job in the world but it sounds like these fcu are going to make the system simpler.
June 21Jun 21 5 minutes ago, Oz07 said: How do you keep the flow temp above the dew point? Is it a set static temperature or does it depend on the outside air temp and/or humidity. Do you have to do the same with the ufh? Does the system take care of this or do you manually have to set some kind of stat? Depends on inside temp and humidity not outside. Easy way is set to a fixed flow temp. Generally keeping flow temp above 14-16 degs is fine. It depends on the first sentence, that depends on ventilation system etc
June 21Jun 21 Fan coil brands. Brand doesn't matter for ASHP. Good ones let you adjust the temp of water to enable the fan to start with a different temp for heat and cool. Poor ones are operated on a fixed water flow temp, which may not suit your setup. I have Myson iVector MkII fan coil, which is good. Panasonic, Daikin, Cool Energy all have good fan coils and many others. If you have time look on eBay many bargains come up or shop around as prices can vary hugely for the same thing. Some cheap fan coils are set up to just heat, so be careful read the install manual. 21 minutes ago, Oz07 said: When you say other option run at same temperature do you mean same temp as UFH? Yes, one circuit feeding UFH and fan coils. But to this you need to size the fan coil to the expected flow temperature.
June 21Jun 21 Author 1 hour ago, JohnMo said: Fan coil brands. Brand doesn't matter for ASHP. Good ones let you adjust the temp of water to enable the fan to start with a different temp for heat and cool. Poor ones are operated on a fixed water flow temp, which may not suit your setup. I have Myson iVector MkII fan coil, which is good. Panasonic, Daikin, Cool Energy all have good fan coils and many others. If you have time look on eBay many bargains come up or shop around as prices can vary hugely for the same thing. Some cheap fan coils are set up to just heat, so be careful read the install manual. Yes, one circuit feeding UFH and fan coils. But to this you need to size the fan coil to the expected flow temperature. So bit like radiators bigger fan coils for lower flow temp difference between target and flow. Any pics of your units so I can see how they look. I suppose I really need my detailed drawings and heat loss calcs before I start looking which will be some time off. I can tell its going to be hard work finding the right gear if I have to start looking at MI's
June 21Jun 21 16 minutes ago, Oz07 said: I suppose I really need my detailed drawings and heat loss calcs before I start looking which will be some time off. I can tell its going to be hard work finding the right gear if I have to start looking at MI's Yes, get your heat loss calcs done - but also remember that the heat loss doesn't translate directly to cooling capacity, so you'd need to model that separately. You will be reading MIs but I like Panasonic as all the data is readily available in easily accessible format - https://www.aircon.panasonic.eu/GB_en/ranges/aquarea/fan-coils/
June 21Jun 21 Be careful if you bother doing a cooling heat gain calculation, as instantaneous solar gains can give you a huge heat gains. Others on here have tried it got 20kW cooling requirements and 2kW heating requirements. Then got bogged down with indecision. Size your heat source for heating needs, accept cooling isn't perfect, but better than nothing. Or go full A2A. Be pragmatic or pay £20k for a good plated solution. Think @Nickfromwales did a cooling solution where he cooled the upstairs/downstairs hallway instead of the bedrooms directly. That sort of solution cuts the number of fan coils needed, moves noise away from bedrooms and any drafts away caused by fan coils.
