Bancroft Posted 12 hours ago Posted 12 hours ago I noticed this wind turbine the other day (outlined against the solar panels) on the edge of a new development. Surprised for two reasons: First, will it actually achieve anything meaningful? It's quite low and surrounded by houses and some high trees to the south west (where prevailing winds come from). How/why has the local planning department agreed to it? It doesn't seem to fit the criteria required for personal wind turbines, even permitted development rights.
JohnMo Posted 12 hours ago Posted 12 hours ago 9 minutes ago, Bancroft said: First, will it actually achieve anything meaningful No, not high enough to mitigate wind disturbance 10 minutes ago, Bancroft said: How/why has the local planning department agreed to it? It doesn't seem to fit the criteria required for personal wind turbines, even permitted development rights. Would they have applied?
saveasteading Posted 10 hours ago Posted 10 hours ago It appears to be on a pole along with a small solar panel. It likely powers a street light which illuminates the adjacent footpath.
SteamyTea Posted 8 hours ago Posted 8 hours ago 1 hour ago, saveasteading said: likely powers a street light which illuminates the adjacent footpath I would sell them to the council. Could save them £1000s on each sale. Probably where the myths that renewables are expensive, and don't work, comes from.
saveasteading Posted 6 hours ago Posted 6 hours ago @SteamyTea I'm not grasping your meaning. I noticed in Spain that all new street lights appear to be solar. At first it seemed to be on commercial estate but now on dual carriageways. The weather helps of course. Must be much cheaper to install than mains, with no trench or cable.
SteamyTea Posted 5 hours ago Posted 5 hours ago 4 minutes ago, saveasteading said: I'm not grasping your meaning. Local Authorities have no idea what things should cost, so selling them a £300 wind turbine made for a boat, a fifty quid PV panel, a small battery system for say £500 and a person to put it all together, should probably be about £1000. Councils will probably pay 5 to 6 times that amount. Then, where there is a meeting to fit renewables to council buildings, someone in accounts, will drag out the £5000/kW number and say 'it is too expensive'.
