zaffy Posted 2 hours ago Posted 2 hours ago (edited) Equestrian barn damp floor inside. I have just started to tackle the sloping edge on the outside. On the outside, there is a failed concrete edge between the ground and the concrete block wall. I have chipped away lose concrete and bits of rubber filler. I am about to apply new sand and cement mortar. Thought I'd check if this is the correct approach or should I use a rubber filler? Or is the concrete edge making things worse and should be removed, which would be difficult because it is solid. When it rains it is like a rainfall running past because it runs off the track and straight down past the barn. Edited 2 hours ago by zaffy
zaffy Posted 2 hours ago Author Posted 2 hours ago Image of failed edge where I have hammered off some of the concrete and bits of rubber type mastic.
BotusBuild Posted 1 hour ago Posted 1 hour ago (edited) Before you fix this, can you address the issue of the water running onto the path at the top, some kind of redirection. Maybe consider some Arco drain to redirect the wall to the far side of the path or a soakaway or drain. I would be looking to power clean the cracked area before applying anything. Whatever you apply will need a stable clean surface. There are various rubber or bitumen based sealants that may work. The ultimate fix is to relay the concrete path and introduce some diagonal grooves in the surface that direct the water away from the building and down the path. Bad text diagram following - connect the diagonal together for continuous grooves. |\ \ \ \ \| |\ \ \ \ \| |\ \ \ \ \| |\ \ \ \ \| |\ \ \ \ \| Or, more simply, have the path relaid with a slope away from building wall Edited 1 hour ago by BotusBuild
Mr Punter Posted 19 minutes ago Posted 19 minutes ago Agree with @BotusBuild. Aco drain will work well here. Hopefully there is somewhere you could connect it to at the end.
