Dillsue Posted 19 hours ago Posted 19 hours ago 12 hours ago, Russdl said: You can, but under current tariffs why would you? Axle buy it for £1/kWh, if I need to buy it back at peak rate it’ll cost me around 30p/kWh so effectively I’ve only got 70p/kWh instead of the whole £1. That’ll do nicely. Our inverter has a backup feature and I'd like to keep a minimum SOC to cover a few hours backup use from the battery, but not alot if Axle want it:)
Russdl Posted 19 hours ago Author Posted 19 hours ago 12 minutes ago, Dillsue said: I'd like to keep a minimum SOC to cover a few hours backup use from the battery Ah, in case of power outage I presume? My inverter is set to stop export when the battery reaches 10% SoC for just such an eventuality, I guess that would stop the export if Axle are taking the juice but not at all certain.
JohnMo Posted 18 hours ago Posted 18 hours ago 1 hour ago, Dillsue said: Is the Octopus payment via agile outgoing?? Yes
Bonner Posted 18 hours ago Posted 18 hours ago (edited) 2 hours ago, Dillsue said: So do they pay for solar export on top of battery discharge if its running through the smart meter?? Their FAQs say they need access to your inverter for metering even if you are manually triggering battery export? They pay for anything you export during the event. This will be battery discharge, any excess solar being generated and anything else, if you have a wind turbine for example. I guess they need to see what is going through your inverter to check you are not simply rerouting grid power from another supply. You can sign up here :- https://vpp.axle.energy/landing?ref=R-WHARJUFG Edited 17 hours ago by Bonner
JohnMo Posted 18 hours ago Posted 18 hours ago (edited) System is pretty simple They trigger an export event at you battery/inverter. It then exports battery power plus any other power being generated at that time, as your battery will not charge and discharge at the same time. Axle pay an agreed amount per kWh and your energy supplier will also pay you the agreed export value. Plus if Octopus have an energy saving event, sign on to that, it sees you are exporting and you get a tick in the box, do 2 energy saving event and get weekend power for 1 hr for free. Why procrastinate, sign up, if you don't like it you can stop - you get £25 for signing up anyway. https://vpp.axle.energy/landing?ref=R-VYFYIHBL Edited 18 hours ago by JohnMo
Dillsue Posted 9 hours ago Posted 9 hours ago 8 hours ago, JohnMo said: Why procrastinate, sign up, if you don't like it you can stop - you get £25 for signing up anyway. We're almost there......good things come to those who wait Anyone had any problems with Axle restoring original inverter settings after them taking control to force discharge?
Russdl Posted 8 hours ago Author Posted 8 hours ago 34 minutes ago, Dillsue said: Anyone had any problems with Axle restoring original inverter settings after them taking control to force discharge? Yes, on one occasion, but with the evidence of future events it may well have been that I just wasn't giving the inverter sufficient time to revert, for some reason the settings don't revert straight away when the Axle event is finished - at least for me. I now set a reminder for 15 mins after the event has finished and check the inverter settings then, all's been fine since.
joth Posted 8 hours ago Posted 8 hours ago 42 minutes ago, Dillsue said: We're almost there......good things come to those who wait Anyone had any problems with Axle restoring original inverter settings after them taking control to force discharge? From the facebook group, 90% of people with issues with this have a sigenergy inverter/battery. But it seems (well) less than 50% of sigenergy users actually hit that problem. I'm on SolatEdge and it's been rock solid. (Wish i could say the same for my attempts to take control of the inverter battery management locally via modbus. On paper that's a more robust setup, in practice SolarEdge just don't support it well - and seem likely to further cripple this in future)
Bonner Posted 7 hours ago Posted 7 hours ago 1 hour ago, Dillsue said: We're almost there......good things come to those who wait Normally agree however this can’t last. Axle are winning some bids at less than 30p/kWh and paying us £1. They have funding to prove the concept and get people on board. Eventually the rate they pay will fall in line with other companies variable export rates. 1
SteamyTea Posted 7 hours ago Posted 7 hours ago On 28/09/2026 at 17:02, Russdl said: Axle buy it for £1/kWh, if I need to buy it back at peak rate it’ll cost me around 30p/kWh so effectively I’ve only got 70p/kWh instead of the whole £1. That’ll do nicely. That should be a warning about Axle. 6 minutes ago, Bonner said: however this can’t last It won't, and some people are going to loose their cash.
JohnMo Posted 7 hours ago Posted 7 hours ago 54 minutes ago, joth said: 90% of people with issues with this have a sigenergy inverter/battery. But it seems (well) less than 50% of sigenergy users actually hit that problem That's statistics for you, what does mean in numbers a couple or a couple hundred
Bonner Posted 7 hours ago Posted 7 hours ago 8 minutes ago, SteamyTea said: That should be a warning about Axle. It won't, and some people are going to loose their cash. You don’t put anything in and whatever is paid into your account can be withdrawn immediately. If you want you could sign on and take the £25 and opt out. Nothing to lose really
SteamyTea Posted 5 hours ago Posted 5 hours ago 1 hour ago, Bonner said: Nothing to lose really The investors will loose.
