Nickfromwales Posted 13 hours ago Posted 13 hours ago 6 hours ago, Super_Paulie said: wonder if its worth adding a rodding point to all 3 or if its easy enough to manipulate up or down from the main access in the middle of the 3? Could drill out and add removable caps i guess, my only access would be from directly behind the soil, not from the sides. If it’s all boxed in, what is the (real life) point in bothering? I’ve a much more convoluted arrangement that I buried into the floor(s) of my bathroom. 9 years of 2 adults, 4 kids, and everything you could ‘throw at it’, never a moments trouble. How many toilet blockages have you had in the last 20+ years? And not the U bend of the WC pan, I mean in the pipework from the pan to the sewers…?
Super_Paulie Posted 12 hours ago Author Posted 12 hours ago 1 hour ago, Nickfromwales said: If it’s all boxed in, what is the (real life) point in bothering? I’ve a much more convoluted arrangement that I buried into the floor(s) of my bathroom. 9 years of 2 adults, 4 kids, and everything you could ‘throw at it’, never a moments trouble. How many toilet blockages have you had in the last 20+ years? And not the U bend of the WC pan, I mean in the pipework from the pan to the sewers…? Zero. At least nothing but a hair-burg I could get from the bath plug. So you're saying don't bother with any rodding points or access ? I mean could keep one on the middle WC branch but then just box it all in, could always cut out the boxing if I need to. Id always follow your good advice chief. 1
Nickfromwales Posted 9 hours ago Posted 9 hours ago 2 hours ago, Super_Paulie said: Zero. At least nothing but a hair-burg I could get from the bath plug. So you're saying don't bother with any rodding points or access ? I mean could keep one on the middle WC branch but then just box it all in, could always cut out the boxing if I need to. Id always follow your good advice chief. If I couldn't give good advice, I would give you zero advice. I am on a 3 weekly rota for removing 8" long horse tails from my bath (shower over) plughole; 2 teenage girls with hair down their backs, and my plugholes...... Plumb as above, less any "access", and if that pipe blocks I will come there personally, FOC, and sort it. Don't get lost in this; try this bit of advice instead: Tell your better half to chuck some glad-rags on, and just head out to the local for some wine & dine. You'll thank me afterwards. 🙂. Life is too short, let the errant turds fight amongst themselves!
Spinny Posted 3 hours ago Posted 3 hours ago Can't comment on pipes really. I have a similarly sized small bathroom. I think you might want to consider whether turning the toilet through 90 to sit on the same wall as the basin would give a better layout ? At the moment it looks like you are studding out from two walls - the basin wall, and the shower/toilet wall. With the toilet alongside the basin you could just build a nice vanity unit with top at basin height. Our unit is 1.31 long. Our bathroom is just 1.96m wide and 2.05m long.
