phykell Posted 19 hours ago Posted 19 hours ago Hi, I'm having an indoor pool built to replace an existing outdoor pool and while I think it should be a relatively straight-forward project, the structural engineer seems to disagree. In addition to the cost of calculations for the roof and steels they want to drill several 5m boreholes to test ground conditions, in-situ geo-technical testing and soil samples for chemical testing. I've recently had a water borehole dug out to 50m with a basic report (soil/ground type, water found, etc.) issued - I gave them a copy and they still said they wanted the above work done. I accept that they need to cover all bases due to professional liability, etc. but I've been through the mill with the LPA and all of their "required" reports, investigations and mitigations. Am I now just being cynical or does that all sound reasonable? Thanks for any advice/opinions offered.
Nickfromwales Posted 19 hours ago Posted 19 hours ago 2 hours ago, phykell said: Hi, I'm having an indoor pool built to replace an existing outdoor pool and while I think it should be a relatively straight-forward project, the structural engineer seems to disagree. In addition to the cost of calculations for the roof and steels they want to drill several 5m boreholes to test ground conditions, in-situ geo-technical testing and soil samples for chemical testing. I've recently had a water borehole dug out to 50m with a basic report (soil/ground type, water found, etc.) issued - I gave them a copy and they still said they wanted the above work done. I accept that they need to cover all bases due to professional liability, etc. but I've been through the mill with the LPA and all of their "required" reports, investigations and mitigations. Am I now just being cynical or does that all sound reasonable? Thanks for any advice/opinions offered. Listen to your SE! Anything short of their current proposal would be what worried me here, plus they won’t put even the hairs of their crown jewels onto the chopping block of assumption, why would / should they? This one is absolutely fundamental, as the downward and outward forces at play here are significant to say the least. If this is done even slightly poorly you risk losing the integrity of the house you’re putting it into. Best not to tar them with the same brush….. 1
Mr Punter Posted 18 hours ago Posted 18 hours ago The boreholes should not be too costly. If they are good designers they may use the information from the geotechnical report for a more cost effective solution for the pool. 2
saveasteading Posted 18 hours ago Posted 18 hours ago 1 hour ago, phykell said: it should be a relatively straight-forward project, But it is not. It is a very big water tank, and if the ground moves a tiny bit, the slab and or walls could break and it gets very messy and expensive. And you will be indoors now, not outside., so damage and repairs are x3. There are a lot of failures of swimming pools and contractors have gone bust and Engineers had very expensive claims. And some of these are for proper designs: the ground we live on is very mobile. If the results of the boreholes are encouraging then you will save cost on the amount of concrete and of reinforcememnt. If they show poor ground then it really is essential to know that and design to suit. Is it still 27m long as previous posts? that is big and not to be dabbled with. How much do you want it? 3
phykell Posted 17 hours ago Author Posted 17 hours ago 1 hour ago, Mr Punter said: The boreholes should not be too costly. If they are good designers they may use the information from the geotechnical report for a more cost effective solution for the pool. For just the additional report on the ground composition, etc. it's just over £4k. From the comments here and some "pseudo-research" on AI, it's not something I can or should avoid having done so looks like I just have to bite the bullet.
phykell Posted 17 hours ago Author Posted 17 hours ago 53 minutes ago, saveasteading said: But it is not. It is a very big water tank, and if the ground moves a tiny bit, the slab and or walls could break and it gets very messy and expensive. And you will be indoors now, not outside., so damage and repairs are x3. There are a lot of failures of swimming pools and contractors have gone bust and Engineers had very expensive claims. And some of these are for proper designs: the ground we live on is very mobile. If the results of the boreholes are encouraging then you will save cost on the amount of concrete and of reinforcememnt. If they show poor ground then it really is essential to know that and design to suit. Is it still 27m long as previous posts? that is big and not to be dabbled with. How much do you want it? Understood 😎 Yes, it's the ~28m one that I had to take to appeal. The pool is approximately 11m x 4m with the rest for plant, changing area, and three-bay garage. One day I'll update this place with the completed project, one fine day 👍 1
Nickfromwales Posted 17 hours ago Posted 17 hours ago 24 minutes ago, phykell said: it's just over £4k. This will be the best £4k you ever spend sir.... 21 minutes ago, phykell said: One day I'll update this place with the completed project, one fine day 👍 Please do. I've done a few pools for clients over the years, next one is outdoors in ICF, and am ever curious (and keen to brush up where any opportunity presents itself). 1
saveasteading Posted 4 hours ago Posted 4 hours ago 12 hours ago, phykell said: The pool is approximately 11m x 4m with the rest for plant, changing area, and three-bay garage. I think I would design these as distinct units, so that they can articulate without cracking, as the loadings are very different, and an 11m pool structure will be less complex than 28m. The gaps can be filled in with flooring. 2
phykell Posted 4 hours ago Author Posted 4 hours ago 12 hours ago, Nickfromwales said: Please do. I've done a few pools for clients over the years, next one is outdoors in ICF, and am ever curious (and keen to brush up where any opportunity presents itself). The whole build will be ICF including at least the back wall of the pool - possibly concrete for the other three walls. I was planning on SIPs but preferred ICF due to being more substantial (we get winds from adjoining field), water (housing a pool) and better thermal mass (reduce temperature fluctuations). A couple of items that might interest you in particular is that the ICF pool will require an extra chamber to house the in-ground pool cover. There's not much room around the pool so the cover will be underground - not much of an issue for an outdoor one but it also looks a lot better than the above-ground covers. The other item is that we're looking at an undercroft using block/beam to give access to the pipework/lighting, rather than just embedding it all in the floor.
phykell Posted 4 hours ago Author Posted 4 hours ago 3 minutes ago, saveasteading said: I think I would design these as distinct units, so that they can articulate without cracking, as the loadings are very different, and an 11m pool structure will be less complex than 28m. The gaps can be filled in with flooring. Thanks - I'll see what the structural engineer comes back with. I believe the initial plan just shows one huge concrete raft though.
Nickfromwales Posted 4 hours ago Posted 4 hours ago 3 minutes ago, phykell said: The whole build will be ICF including at least the back wall of the pool - possibly concrete for the other three walls. I was planning on SIPs but preferred ICF due to being more substantial (we get winds from adjoining field), water (housing a pool) and better thermal mass (reduce temperature fluctuations). A couple of items that might interest you in particular is that the ICF pool will require an extra chamber to house the in-ground pool cover. There's not much room around the pool so the cover will be underground - not much of an issue for an outdoor one but it also looks a lot better than the above-ground covers. The other item is that we're looking at an undercroft using block/beam to give access to the pipework/lighting, rather than just embedding it all in the floor. I specified a ‘sump’ in the space under the 5x15m pool, in the basement, to house all the ‘pool paraphernalia”, so if anything failed the entire contents of the pool could be evacuated quickly. I combined that with the drainage system from the basement, and did the pimp set in triplicate for redundancy. Gave me and the SE a headache or 3! I planned to use UFH pipes in the base and lower sides of the pool walls, to minimise the impact of the pool plant space needed. Was an interesting idea, and was received well, but apparently not very common in ‘usual’ pool builds; seemed ideal for one done in ICF though. If you need a very good ICF guy who’s fluent with pools and basements etc, send me a PM. 👍 1
markc Posted 3 hours ago Posted 3 hours ago (edited) @phykell all the above is great advice. Just to add, the deep bore report is great for water extraction but not much use for a pool, hence the 5m bores. With a above ground pool the mass (weight) of the pool and water are very important but with an in ground pool it’s very different, the mass off the soil you remove is generally much less than the big concrete tank and fill with water. When you empty the pool the ground wants to push the walls in and any water in the first few metres wants to float your pool out of the ground. If you have a high water table you will be looking at anchoring the pool down rather than supporting it. Edited 3 hours ago by markc
