Jothetaxi Posted 7 hours ago Posted 7 hours ago I’ve put this post in this area, as I was unsure where else to put it. Builders installed weep holes above our doors in random positions and they look a right mess. We know they are required but it’s the random positioning that bothers us and it draws your eye. I’ve attached photos but they don’t really show the extent of it. is there a way of obscuring these? We know they can’t be sealed up.
Mr Punter Posted 2 hours ago Posted 2 hours ago If you are not in an exposed location you could have got away without these as the render would stop water getting through. You probably have weep vents every 450mm but some have been covered by render. You could have a dig about to find more or cover up any you don't like, but either way it is very difficult to make it match in with the render.
Russell griffiths Posted 22 minutes ago Posted 22 minutes ago Add more of them to even out the spacing.
