Mattg4321 Posted Monday at 17:29 Posted Monday at 17:29 I've got a spare MPPT on my Sunsynk inverter. I've got a garage (flat) roof on the side of my house I could fit 5 (or possibly 6, I've not bothered measuring yet!) panels on, landscape to reduce height. It's south facing, with only moderate shading early/late in the year. Half the year it will be in full sun all day. I'm sure it would payback within a couple of years or so as I can fit myself. I don't want any penetrations through my flat roof and I don't want it to look awful. Are the ballasted systems any good? Roof structure is early 70's and in good condition. 4x2 timber. 2.4m span. Not sure if I will require structural engineer? What's the lowest profile flat roof system? Do I require planning? All input appreciated!
TedM Posted Monday at 17:48 Posted Monday at 17:48 (edited) Hmmm. A quick look at good old AI suggests: According to standard UK span tables (BS 5268), a 2" x 4" (specifically 47 x 100 mm) joist typically has a maximum allowable span of only 1.7 to 2.1 meters depending on the wood grade and spacing. At a 2.4m span, the joists are "undersized" and prone to significant sagging or structural failure under standard loads. So maybe no planning required but some acro props probably will be as whatever you put up there may well try to find its way downstairs fairly quickly 😬 (The 70's has a lot to answer for!) "I'm sure it would payback within a couple of years or so as I can fit myself." Possibly a bit longer if you take roof repairs into account 😉 Edited Monday at 17:55 by TedM
Mattg4321 Posted Monday at 18:35 Author Posted Monday at 18:35 46 minutes ago, TedM said: Hmmm. A quick look at good old AI suggests: According to standard UK span tables (BS 5268), a 2" x 4" (specifically 47 x 100 mm) joist typically has a maximum allowable span of only 1.7 to 2.1 meters depending on the wood grade and spacing. At a 2.4m span, the joists are "undersized" and prone to significant sagging or structural failure under standard loads. So maybe no planning required but some acro props probably will be as whatever you put up there may well try to find its way downstairs fairly quickly 😬 (The 70's has a lot to answer for!) "I'm sure it would payback within a couple of years or so as I can fit myself." Possibly a bit longer if you take roof repairs into account 😉 I think you're right. Will be giving this a miss then.
BotusBuild Posted Monday at 18:39 Posted Monday at 18:39 FYI - It is not unheard of for sloping roof trusses needing to be strengthened when PV panels are fitted, so based on @TedM's findings I would be looking to add extra wood to the existing timbers. A friendly SE's input would not go amiss in this situation, especially as you are talking about ballast systems
Mattg4321 Posted Monday at 21:01 Author Posted Monday at 21:01 2 hours ago, BotusBuild said: FYI - It is not unheard of for sloping roof trusses needing to be strengthened when PV panels are fitted, so based on @TedM's findings I would be looking to add extra wood to the existing timbers. A friendly SE's input would not go amiss in this situation, especially as you are talking about ballast systems The problem with that is that it starts to push out the payback time. I suppose it depends what strengthening work might be required. Anyone have any idea what might be typical?
jack Posted Tuesday at 09:14 Posted Tuesday at 09:14 It might be just a case of spreading the load across as many timbers as possible, but you'd need an SE to confirm the mass needed, and whether your roof has the necessary load capacity. We have a low-angle ballasted system on a flat roof that uses concrete council-type slabs as ballast, but with a frame system specifically designed for PV. I can't easily check, but it's something like a couple of slabs per panel, I think. I'd have preferred a through-membrane system bolted down to the roof deck, but unfortunately didn't plan ahead and so it wasn't a reasonable option at the time. Hasn't moved in 10+ years. I appreciate it's desirable to avoid roof penetrations, but if done properly it needn't be a significant leak risk. You'd still need SE calculations for load, lift, and fastener pullout, but I still think that's preferable to using ballast. Even it's within your roof's load capacity, you'll be putting considerably more pressure on the membrane and underlying structure.
TedM Posted Tuesday at 09:54 Posted Tuesday at 09:54 36 minutes ago, jack said: I appreciate it's desirable to avoid roof penetrations, but if done properly it needn't be a significant leak risk. My late dad was an architect and always said to never put anything through a flat roof unless there was absolutely no other choice. 5 panels would probably mean 20 holes, meaning that it would potentially be 20 x more likely to leak at some time in the future 😬
TedM Posted Tuesday at 10:00 Posted Tuesday at 10:00 12 hours ago, Mattg4321 said: I suppose it depends what strengthening work might be required. Anyone have any idea what might be typical? You would basically need to strengthen each existing joist - two options might be: bolt a steel strap to one side of each joist (we've done that before to a pair of roof purlins with the blessing of our SE) add new joists of the correct diameter - but they will def be deeper which would then affect the ceiling height of the room below. There may be other options but I would imaging they would all involve considerable intrusion into the room below ceiling and it's associated repair costs.
JohnMo Posted Tuesday at 11:16 Posted Tuesday at 11:16 Ballast buckets, do a good job of spreading loads
saveasteading Posted Tuesday at 12:12 Posted Tuesday at 12:12 17 hours ago, BotusBuild said: sloping roof trusses needing to be strengthened garages are generally designed without the factors of safety required for a house. So the timbers will be on the light side already. I.e. it's unlikely anyone would die if it collapsed in a storm, and cars don't matter. The snow load will still apply as it can sit on the solar panels, so this is extra load even beford ballast. So the joists will need help. The easiest solution may be to sister the existing ones. But uplift in wind will be the critical force As the oaneks act as a wing and kite. You don't want holes in the roof, quite rightly, so you may need a gantry to spread the load, perhaps strapped to the walls. I'm reinventing the wheel here... there must be a standard way, although don't count on contractors or vendors to know or care. Is it a building regs thing? I'd have to check but I think it is as it's integral with the house. I don't think many people ask, or do it right.
BotusBuild Posted Tuesday at 16:12 Posted Tuesday at 16:12 3 hours ago, saveasteading said: cars don't matter All the buildhubbers who are classic car owners are now gnashing their teeth (incl me) 🙂 2
BotusBuild Posted Tuesday at 16:13 Posted Tuesday at 16:13 6 hours ago, TedM said: intrusion into the room below ceiling It's a garage - I don't think this is of much concern in this situation 🙂
saveasteading Posted Tuesday at 17:19 Posted Tuesday at 17:19 (edited) After you've had a look at gantry options, Id be interested to know what you come up with, and we can look at support and fixings. ballast is still possible, but with reinforcement of the joists, which should be quite easy: fixing the same size of timber to the sides wont intrude either. Edited Tuesday at 17:23 by saveasteading
saveasteading Posted Tuesday at 17:25 Posted Tuesday at 17:25 1 hour ago, BotusBuild said: cars don't matter It shocks some people that agricultural buildings are basically allowed to fail, whether for hay, tractors or living animals. I asked a farmer once if he knew of buildings collapsing, as I hadn't ever heard of it being a problem. He told me it was quite common especially in heavy snow, and was reported in farming journals. 1 hour ago, BotusBuild said: classic car owners might want to have their garage designed with a FOS. It's about 40% in approx terms.
TedM Posted Tuesday at 17:47 Posted Tuesday at 17:47 1 hour ago, BotusBuild said: It's a garage - I don't think this is of much concern in this situation Oh! ......Didn't know.
JohnMo Posted Tuesday at 18:24 Posted Tuesday at 18:24 33 minutes ago, BotusBuild said: ? Factor of safety
Mattg4321 Posted Tuesday at 20:04 Author Posted Tuesday at 20:04 No worries about intruding on a room below. The flat roof is above a utility room 80's extension with 6x2 joists (same 2.4m span) and also a garage as previously mentioned with the 4x2. There's nothing below the joists in the garage so easy access. No idea of the cost of a structural engineer for something simple like this, anyone like to guess? If it's as potentially simple as sistering the joists, I may look into it as without strengthening the joists and the costs involved in that, payback time is going to be around 2 years according to AI, so pretty attractive. Current joists go into pockets in the brickwork of the house and then overhang the wall plate on the other side by a few hundred mm to create an overhang outside. Presumably any sistered joints would just need to sit on the wall plate (not all the way to the fascia outside), but if the joists are deeper than the current ones, the bottom would need notching out at the wall plate? Assuming these would generally then be bolted to the existing joists. I'm also not sure what the approved practice would be at the junction with the house. I assume create a pocket in the brickwork for the joist to sit in.
saveasteading Posted Wednesday at 07:52 Posted Wednesday at 07:52 14 hours ago, saveasteading said: FOS. It's about 40% in approx terms. As I had written it in full I am entitled to then use the abbreviation.... but should properly have written them together first time. I'll try harder. 11 hours ago, Mattg4321 said: cost of a structural engineer for something simple like this, anyone like to guess? Formally about £400 but you will need information on the proposed system. Informally £200 ( a look, a few words and nothing in writing). Very Informally. .. double up the joists bolting new on the side of old. But there could be factors we haven't seen, and your classic car won't be insured if it goes wrong.... and it remains a garage, not any domestic purpose. 1
TedM Posted Wednesday at 08:51 Posted Wednesday at 08:51 12 hours ago, Mattg4321 said: but if the joists are deeper than the current ones, the bottom would need notching out at the wall plate? Assuming these would generally then be bolted to the existing joists. If I was doing this I'd fit a plate to the wall and then new bigger joists onto joist hangers screwed to the wall plate, like this: You won't be able to get the new joist right next to the existing one but I'm not sure that matters - you could fit them at the mid point between the existing joists. I would probably use an acrow to apply a little bit of upward pressure to the new joist while fitting the hanger - this is to make sure the new joist is doing some of the work. It seems that 8x2 (47mm x 195mm) C24 graded timber would be a starting point - but this is also assuming the walls are up to taking the extra weight.
Dillsue Posted Wednesday at 14:12 Posted Wednesday at 14:12 Building control tables for C16 floor joists suggest 5x2" at 400mm centres will span 2.5m and 6x2" at 600mm centres will do similar. The 4x2" you've already got will likely carry several tons at the ends where they bear on the walls so bolting slightly deeper joists to the existing would likely be fine to prevent sag without bearing the new joists on the wall. If it were mine and the underside of the existing joists were pretty flat I'd glue and screw 2x1" to the underside of the existing joists to make a basic laminated joists. Another option would be to screw long strips of ply to the side of the existing joists.
TedM Posted Wednesday at 19:25 Posted Wednesday at 19:25 5 hours ago, Dillsue said: Building control tables for C16 floor joists suggest 5x2" at 400mm centres will span 2.5m and 6x2" at 600mm centres will do similar. Have you taken I to account the extra 100kg of panels plus the ballast for each one? How much ballast do they take... I guessed at 100kg each 🤷🏻♂️ My numbers were for a standard roof plus about 700kg extra.
Beelbeebub Posted Thursday at 05:36 Posted Thursday at 05:36 How. Much headroom do you have below the 4x2 joists?
Mattg4321 Posted Thursday at 15:40 Author Posted Thursday at 15:40 9 hours ago, Beelbeebub said: How. Much headroom do you have below the 4x2 joists? Headroom not a problem if I had to lose a couple of inches. If I have to spend £600+ on structural engineer and timber etc, which is looking likely. I’ll probably bin off the idea. It just seems a shame not to use the spare MPPT, especially as I can get all the pv kit vat free still I think. And no labour costs.
Mattg4321 Posted Thursday at 15:44 Author Posted Thursday at 15:44 20 hours ago, TedM said: Have you taken I to account the extra 100kg of panels plus the ballast for each one? How much ballast do they take... I guessed at 100kg each 🤷🏻♂️ My numbers were for a standard roof plus about 700kg extra. This system claims to be only 10-11kg per sqm. No idea if it’s any good though!
