BotusBuild Posted March 16 Posted March 16 I have a need to connect either 32 or 40mm waste pipe to a 110mm soil pipe that I can't disconnect, so been looking at options. The strap on connectors seem to depend on the rubber adapters. I'd rather have a more permanent seal, so looking for a solvent fitting. Found these available in either size. Yay or Nay? ย
SimonD Posted March 16 Posted March 16 I tend to buy this one: ย https://mcalpineplumbing.com/traps/condensate-traps-and-fittings/mechanical-soil-and-rainwater-pipe-boss-connector
Russell griffiths Posted March 16 Posted March 16 Donโt fit 32mm, 40 min and reduce to 32 under the basin. ย 1
Nickfromwales Posted March 16 Posted March 16 Can you get around the soil pipe?ย ย Id go for one of these, that clips together at the back, and solvent weld the lot in then. ๐ ย ย You can buy these with solvent reducers. Just a pic of the fitting for an example ย ย 1
BotusBuild Posted March 16 Author Posted March 16 30 minutes ago, Nickfromwales said: You can buy these with solvent reducers. If that's the case, I will do this as I can get round the pipe. 1
Nickfromwales Posted March 17 Posted March 17 12 hours ago, BotusBuild said: If that's the case, I will do this as I can get round the pipe. These are better than the push in ones imho, as once the band is locked and youโve glued the face of the fitting to the soil pipe, itโs there for life.ย ย You need to abrade the surface of the pipe, and clean it with some solvent cleaner (made by the same people that make the glue). You need pipe cement filler not glue to do the join.ย ย https://www.wolseley.co.uk/product/polypipe-gfc100-gap-fill-cement-140g-gfc100/?srsltid=AfmBOoq47EOGcFFkFm0UUHAaMl5ntEYtF1-s87NcOwN9r8P9w6VwYv6WVTI ย ย
SimonD Posted March 17 Posted March 17 13 hours ago, BotusBuild said: If that's the case, I will do this as I can get round the pipe. ย 27 minutes ago, Nickfromwales said: These are better than the push in ones imho, as once the band is locked and youโve glued the face of the fitting to the soil pipe, itโs there for life.ย ย You need to abrade the surface of the pipe, and clean it with some solvent cleaner (made by the same people that make the glue). You need pipe cement filler not glue to do the join.ย ย https://www.wolseley.co.uk/product/polypipe-gfc100-gap-fill-cement-140g-gfc100/?srsltid=AfmBOoq47EOGcFFkFm0UUHAaMl5ntEYtF1-s87NcOwN9r8P9w6VwYv6WVTI ย ย Just use the Macalpine mechanical bossconn as I linked to above - all you need is a hole saw and then use the compression fitting, so no messing around with cements or glue, or solvent weld reducers, or having to wrap around the soil pipe. Takes a couple of minutes max and you don't have any worries about whether the connection has been properly sealed as quite often happens with the wrap boss. The advantage of the Macalpine is that you can even use then for the blow offs from UVCs and boilers whereas the regs guidelines state you should NOT use wrapped bosses for these, but mechanical ones only. ย The 40mm version direct from Screwfix:ย https://www.screwfix.com/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722 ย Simple and no mess
BotusBuild Posted March 17 Author Posted March 17 (edited) 1 hour ago, SimonD said: ย The 40mm version direct from Screwfix:ย https://www.screwfix.com/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722 Looks like you have to be able to get a hand inside the pipe to attach it? If so, I can't use this ๐ in this instance. Edited March 17 by BotusBuild "hand"
SimonD Posted March 17 Posted March 17 14 minutes ago, BotusBuild said: Looks like you have to be able to get a hand inside the pipe to attach it? If so, I can't use this ๐ in this instance. ย No, fully installable from the outside as there's an expanding seal and a tightening too. Simple as -ย ย ย BTW - With a strap boss you need access to both sides of the soil pipe.
BotusBuild Posted March 17 Author Posted March 17 OK, off to SF ๐.ย ย I'll channel my inner Scot as I fit it ๐ 1
Nickfromwales Posted March 17 Posted March 17 3 hours ago, BotusBuild said: OK, off to SF ๐.ย ย I'll channel my inner Scot as I fit it ๐ Use the force.ย
