BotusBuild Posted Monday at 15:51 Posted Monday at 15:51 I have a need to connect either 32 or 40mm waste pipe to a 110mm soil pipe that I can't disconnect, so been looking at options. The strap on connectors seem to depend on the rubber adapters. I'd rather have a more permanent seal, so looking for a solvent fitting. Found these available in either size. Yay or Nay?
SimonD Posted Monday at 16:13 Posted Monday at 16:13 I tend to buy this one: https://mcalpineplumbing.com/traps/condensate-traps-and-fittings/mechanical-soil-and-rainwater-pipe-boss-connector
Russell griffiths Posted Monday at 17:33 Posted Monday at 17:33 Don’t fit 32mm, 40 min and reduce to 32 under the basin. 1
Nickfromwales Posted Monday at 19:45 Posted Monday at 19:45 Can you get around the soil pipe? Id go for one of these, that clips together at the back, and solvent weld the lot in then. 👍 You can buy these with solvent reducers. Just a pic of the fitting for an example 1
BotusBuild Posted Monday at 20:17 Author Posted Monday at 20:17 30 minutes ago, Nickfromwales said: You can buy these with solvent reducers. If that's the case, I will do this as I can get round the pipe. 1
Nickfromwales Posted yesterday at 09:38 Posted yesterday at 09:38 12 hours ago, BotusBuild said: If that's the case, I will do this as I can get round the pipe. These are better than the push in ones imho, as once the band is locked and you’ve glued the face of the fitting to the soil pipe, it’s there for life. You need to abrade the surface of the pipe, and clean it with some solvent cleaner (made by the same people that make the glue). You need pipe cement filler not glue to do the join. https://www.wolseley.co.uk/product/polypipe-gfc100-gap-fill-cement-140g-gfc100/?srsltid=AfmBOoq47EOGcFFkFm0UUHAaMl5ntEYtF1-s87NcOwN9r8P9w6VwYv6WVTI
SimonD Posted yesterday at 10:06 Posted yesterday at 10:06 13 hours ago, BotusBuild said: If that's the case, I will do this as I can get round the pipe. 27 minutes ago, Nickfromwales said: These are better than the push in ones imho, as once the band is locked and you’ve glued the face of the fitting to the soil pipe, it’s there for life. You need to abrade the surface of the pipe, and clean it with some solvent cleaner (made by the same people that make the glue). You need pipe cement filler not glue to do the join. https://www.wolseley.co.uk/product/polypipe-gfc100-gap-fill-cement-140g-gfc100/?srsltid=AfmBOoq47EOGcFFkFm0UUHAaMl5ntEYtF1-s87NcOwN9r8P9w6VwYv6WVTI Just use the Macalpine mechanical bossconn as I linked to above - all you need is a hole saw and then use the compression fitting, so no messing around with cements or glue, or solvent weld reducers, or having to wrap around the soil pipe. Takes a couple of minutes max and you don't have any worries about whether the connection has been properly sealed as quite often happens with the wrap boss. The advantage of the Macalpine is that you can even use then for the blow offs from UVCs and boilers whereas the regs guidelines state you should NOT use wrapped bosses for these, but mechanical ones only. The 40mm version direct from Screwfix: https://www.screwfix.com/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722 Simple and no mess
BotusBuild Posted yesterday at 11:21 Author Posted yesterday at 11:21 (edited) 1 hour ago, SimonD said: The 40mm version direct from Screwfix: https://www.screwfix.com/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722 Looks like you have to be able to get a hand inside the pipe to attach it? If so, I can't use this 😞 in this instance. Edited yesterday at 11:25 by BotusBuild "hand"
SimonD Posted yesterday at 11:39 Posted yesterday at 11:39 14 minutes ago, BotusBuild said: Looks like you have to be able to get a hand inside the pipe to attach it? If so, I can't use this 😞 in this instance. No, fully installable from the outside as there's an expanding seal and a tightening too. Simple as - BTW - With a strap boss you need access to both sides of the soil pipe.
BotusBuild Posted yesterday at 11:44 Author Posted yesterday at 11:44 OK, off to SF 😀. I'll channel my inner Scot as I fit it 😉 1
Nickfromwales Posted yesterday at 15:11 Posted yesterday at 15:11 3 hours ago, BotusBuild said: OK, off to SF 😀. I'll channel my inner Scot as I fit it 😉 Use the force.
