jfb Posted yesterday at 13:17 Posted yesterday at 13:17 Walls have been stripped of wallpaper back to original plaster (lime I presume?). Assuming it is still sound what would people recommend for skimming onto it? 1. bluegrit 2. PVA till tacky (with one coat before?) 3. pink SBR wait till fully dry Got a whole house to do so quite like the idea of something you can get on and leave to dry cheers
ProDave Posted yesterday at 14:31 Posted yesterday at 14:31 Rip it off and plasterboard. If you have ANY electrical alterations to do, your electrician will hate you for keeping the lath and plaster. Just my preference.
saveasteading Posted 23 hours ago Posted 23 hours ago 1 hour ago, ProDave said: If you have ANY electrical alterations to do, your electrician will hate you for keeping the lath Will he love you for adding a service void?
JohnMo Posted 22 hours ago Posted 22 hours ago 2 hours ago, ProDave said: Rip it off and plasterboard. Service battens tapered edge plasterboard and dry line.
jfb Posted 7 hours ago Author Posted 7 hours ago Ripping it all out and starting again is not going to happen. skirting and ceiling coving remaining in place and electrics not an issue. So if I were to skim on top of the plaster which option would anyone go for?
Redbeard Posted 7 hours ago Posted 7 hours ago 18 minutes ago, jfb said: Ripping it all out and starting again is not going to happen. OK, I'll chip in in the light of the above. Obviously none of us (except the OP) has seen or felt the surfaces but, as it's lime, you could consider something like Baumit RK70 - maybe with mesh; it's early and I have not thought that through enough yet. First stab is yes, rather than no, to mesh. And if you want a really smooth finish (think silk gloves) use Baumit Kalkin Glatt - goes on extremely thin, almost like a polish, so the RK70 has to be good. I'm not advertising for B----t, I just used the stuff for 10+ years with great success and I am not a plasterer. Other companies do lime products that do a similar job but I have not used them enough to be used to them. I note that you refer to Blue Grit and PVA. If the existing surface is very friable then no amount of nice lime plaster is going to hold onto the wall, necessarily. If it's sound but pitted, perhaps do something like I have suggested, without 'artificial aids'. You could do a 'test piece' of both... These lime products are not generally available at mainstream merchants, but they are available easily from specialist merchants.
saveasteading Posted 7 hours ago Posted 7 hours ago 18 minutes ago, jfb said: if I were to skim on top of the plaster I just wouldn't. Easier and better quality to batten out and plasterboard. Look into metal grid as an option to timber.
Nestor Posted 7 hours ago Posted 7 hours ago (edited) Used the Baumit Multifine RK70 with mesh on internal wood fibre insulation. Excellent product. https://baumit.co.uk/products/renovation-systems/visual-renovation/baumit-multifine-rk-70-n Do a test. Edited 7 hours ago by Nestor
