saveasteading Posted 19 hours ago Author Posted 19 hours ago 55 minutes ago, SimonD said: no fittings should be embedded in a floor or wall, 'Embedded' to me means locked solid in concrete or masonry. ie there could be differential stresses that could break the pipe or a joint, and cause water damage. That is sensible.
Nickfromwales Posted 18 hours ago Posted 18 hours ago 28 minutes ago, saveasteading said: 'Embedded' to me means locked solid in concrete or masonry. ie there could be differential stresses that could break the pipe or a joint, and cause water damage. That is sensible. Embedded means when you cannot get to them afterwards without destruction of property (kinda thing). I could send you the regs, but it's late and I can't be arsed to write my version. You'll not be turned by simple folk such as myself, so barrier it is.
SimonD Posted 10 hours ago Posted 10 hours ago 8 hours ago, saveasteading said: Hep2O say theirs comes off the coil straight, which must be good thing. Yeah, pull the other one. You'll be swearing for a month of Sundays getting it straight and keeping it straight even if it is lay-flat. So you believe the marketing blurb of these but not the technical documentation for MLCP? 13 hours ago, saveasteading said: Agreed. It looks fine, but not widely stocked. Well, here you you go. As it's going to be in insulation, the 9mm thickness will be absolutely fine? What diameter would you like sir? 16 Blue and Red https://www.plumbingforless.co.uk/plumbing/unipress-mlcp/unipress-mlcp-pipe/unipress-50mtr-mlcp-16mmx2.0-9mm-red https://www.plumbingforless.co.uk/plumbing/unipress-mlcp/unipress-mlcp-pipe/unipress-50mtr-mlcp-16mmx2.0-9mm-blue 20 Blue and Red https://www.plumbingforless.co.uk/plumbing/unipress-mlcp/unipress-mlcp-pipe/unipress-50mtr-mlpipe-20mmx2.0-9mm-red https://www.plumbingforless.co.uk/plumbing/unipress-mlcp/unipress-mlcp-pipe/unipress-50mtr-mlpipe-20mmx2.0-9mm-blue Oh, and here you go, Wolseley, pipe in pipe Mlcp: https://www.wolseley.co.uk/product/uponor-mlc-insulated-pipe-13mm-25-x-25mm-50mtr-blue/ And it confirms that: This Uponor MLC 13mm, 2.5mm thick pipe-in-pipe is designed for integration into a building structure and can be safely covered with screed. Withdrawn without causing structural damage, this water regs compliant pipe-in-pipe is supplied in 50M lengths. Product features Suitable for hot and cold and heating systems Suitable for recirculation hot water systems PE-X material construction Meets BS EN 13501-1 Complies with water regulations 1999 Any decent plumbers merchant will be able to order some in from one of the multitude of manufacturers out there and the good thing is that it's often cheaper than standard plastic PEX of Polybutylene. But hey ho, go with your barrier pipe...even if the world is moving on. 2
saveasteading Posted 10 hours ago Author Posted 10 hours ago 6 minutes ago, SimonD said: go with your barrier pipe.. Thanks, I'll check these out. It's not me who says to use barrier pipe... it's the others.
saveasteading Posted 10 hours ago Author Posted 10 hours ago 8 hours ago, Nickfromwales said: Embedded means when you cannot get to them afterwards without destruction of property That would preclude them being threaded through studs and joists, and behind boards, fitted units....
SimonD Posted 9 hours ago Posted 9 hours ago 26 minutes ago, saveasteading said: It's not me who says to use barrier pipe... it's the others. So this is what I said earlier, which you may have missed: Quote I don't know what they're talking about regarding barrier pipe unless they're referring the plastic pipe that has an oxygen barrier as I see no need for the barrier pipe you're referring to - it's confusing. First, you need to confirm exactly what barrier pipe they're referring to. Is it the MPDE barrier pipe that is design for COLD water services, or are they merely referring to Hep20 or Polybutylene push-fit pipe. As a distinction for you. PEX is the push-fit pipe that has memory and it's a pain in the arse to work with. Polybutylene is the lay-flat type of pipe that has less memory, but memory still. Second, MDPE service pipes, including the barrier versions are design for cold supplier. Their specifications usually state: based upon a 50 year design life at 20˚C. Any increase above 20˚C will result in a reduction in the maximum allowable operating pressure or lifetime or possibly both. Polyethylene pipe systems should not be operated above 60˚C. Your intended purpose as I understand it is to carry domestic hot water in your kitchen. Therefore MDPE Barrier pipe is completely unsuitable for this. PEX and Polybutylene as well and MLCP (whether PEX or Pert) are tested to over 100C and are designed for hot water. 1
Nickfromwales Posted 9 hours ago Posted 9 hours ago 43 minutes ago, saveasteading said: That would preclude them being threaded through studs and joists, and behind boards, fitted units.... That's more or less cosmetics tbf, if considering chasing a burst pipe. Most issues are with failed joints. 99.9% of failures there are installer error, the other down to a bad o-ring or similar manufacturing defect. This is the joy of radial plumbing, as the dozens of buried (enclosed) joints is near zero.
saveasteading Posted 8 hours ago Author Posted 8 hours ago 54 minutes ago, Nickfromwales said: considering chasing a burst pipe. Yes I assume this is the concern. I can't see much chance of a failure if the pipes have no joints where they run under the floor. And the insulation provides a slip layer and cover. And at worst, it is not structure but tiles over thin screed over pir. I can see why it's a pig to install whatever we do, and why heat loss will be low on some people's concern list. Not much chance of removing the island though: it is decided at a higher level.... and they do like the idea of cold being cold, and hot being hot. For my interest... hypothetically, if 2 uninsulated pipes were in a duct and one had to be replaced... could they be pulled out and new ones dragged through?
Nickfromwales Posted 8 hours ago Posted 8 hours ago 18 minutes ago, saveasteading said: Yes I assume this is the concern. I can't see much chance of a failure if the pipes have no joints where they run under the floor. And the insulation provides a slip layer and cover. And at worst, it is not structure but tiles over thin screed over pir. I can see why it's a pig to install whatever we do, and why heat loss will be low on some people's concern list. Not much chance of removing the island though: it is decided at a higher level.... and they do like the idea of cold being cold, and hot being hot. For my interest... hypothetically, if 2 uninsulated pipes were in a duct and one had to be replaced... could they be pulled out and new ones dragged through? If they're not going through stupidly acute bends then yes, but you'd probably have to pull both out and feed both back in again unless its a big duct. They'll not need changing out in our lifetimes....... Kinda moot if...... 18 minutes ago, saveasteading said: they do like the idea of cold being cold, and hot being hot ......as you'll need segregation and insulation? 1
SimonD Posted 7 hours ago Posted 7 hours ago 27 minutes ago, saveasteading said: Yes I assume this is the concern. I can't see much chance of a failure if the pipes have no joints where they run under the floor. And the insulation provides a slip layer and cover. And at worst, it is not structure but tiles over thin screed over pir. I can see why it's a pig to install whatever we do, and why heat loss will be low on some people's concern list. Not much chance of removing the island though: it is decided at a higher level.... and they do like the idea of cold being cold, and hot being hot. For my interest... hypothetically, if 2 uninsulated pipes were in a duct and one had to be replaced... could they be pulled out and new ones dragged through? Here are the regs. Really you need them ducted - you are after perfection after all 😉 1
-rick- Posted 7 hours ago Posted 7 hours ago So everything leading towards pipe in pipe sandwiched at the join between eps and pir (likely chased into eps). so you get: - pipes insulated by the eps pir sandwich - spaced to separate hot and cold - individually ducted for easy replacement if needed - minimal disturbance to the insulation. Ie cutting is way less than 50mm Though as @saveasteading is paying someone to do this maybe the biggest decider is what his installer is most comfortable with? 1
Nickfromwales Posted 7 hours ago Posted 7 hours ago 14 minutes ago, SimonD said: Here are the regs. Really you need them ducted - you are after perfection after all 😉 Not needed as it refers largely, if not entirely, to fittings. No fittings = common sense can prevail. Probably spent more time typing this than installing 2 pairs of both solutions though, lol. Self-building at it's best (worst?), eg set fire to £500 worth of time solving a £300 problem. Then multiply!! 2
Nickfromwales Posted 7 hours ago Posted 7 hours ago 9 minutes ago, -rick- said: Though as @saveasteading is paying someone to do this maybe the biggest decider is what his installer is most comfortable with? Dangerous territory sometimes, plus "he who pays the piper calls the tune", and that's exactly how it should be if you are competent to dictate (but also are someone who will take ownership of pushing for a bad choice and then having to pay to correct later without blaming anyone........dealing with this currently and it's a major piss-you-off)
-rick- Posted 7 hours ago Posted 7 hours ago 2 minutes ago, Nickfromwales said: Dangerous territory sometimes, plus "he who pays the piper calls the tune", and that's exactly how it should be if you are competent to dictate (but also are someone who will take ownership of pushing for a bad choice and then having to pay to correct later without blaming anyone........dealing with this currently and it's a major piss-you-off) sorry, was saying it in the context of multiple acceptable solutions as discussed above. Informed specifier has the leeway to allow the installers choice of options within an acceptable basket but say no to crap options.
SimonD Posted 7 hours ago Posted 7 hours ago 4 minutes ago, Nickfromwales said: Not needed as it refers largely, if not entirely, to fittings. No fittings = common sense can prevail. Probably spent more time typing this than installing 2 pairs of both solutions though, lol. Self-building at it's best (worst?), eg set fire to £500 worth of time solving a £300 problem. Then multiply!! Nick, the term "fitting" includes pipes! What I posted up includes reference to pipe too! FFS, I give up....🙄
Nickfromwales Posted 5 hours ago Posted 5 hours ago 1 hour ago, SimonD said: Nick, the term "fitting" includes pipes! What I posted up includes reference to pipe too! FFS, I give up....🙄 Never give up. “All pipes located in areas where subsequent inspection will be difficult or impracticable should be pressure tested before being concealed.” So it is covering every base, and open to interpretation, as always. Whenever bcos have been on site they’ve only ever cared about fittings being accessible (as in not buried in concrete / screed etc), and never about pipe. I challenge, show sensible management of risks, they say carry on. Look at the amount of UFH pipe in slabs and zero issues there. I only really insulate (9mm wall) when in slab to protect the pipes during the construction phase, leaving the insulation above ground as a sacrificial cover.
SimonD Posted 4 hours ago Posted 4 hours ago 40 minutes ago, Nickfromwales said: Whenever bcos have been on site they’ve only ever cared about fittings being accessible (as in not buried in concrete / screed etc), and never about pipe TBH, I don't really care whether the BCO will let something past, I care about the quality of the installation and how it can be serviced over time when necessary. 42 minutes ago, Nickfromwales said: Look at the amount of UFH pipe in slabs and zero issues there. This is explicitly allowed for in the regs guidance: "the bedding of any pipe and associated pipe joints in a closed system of underfloor space heating....in screed.....is generally acceptable if the pipes...etc. can be exposed by removing layers of screed. Pipe located in chase within a a solid floor are only generally permitted with heating pipes and should not be concreted in." So like I said the regs apply to pipe as fittings and they should not be installed below a solid floor at ground level - because we're talking about potable water and domestic hot water. If it's a new build then it takes a matter on minutes to install ducted pipework. The marginal cost is so small, there's no point even arguing about it. Which is what bemuses me here. A few months ago a customer of mine phone me about a leak where they'd got some emergency plumber in who had to dig out a whole load of concrete floor and in the end they had to get the original build in to take up a load more. This is a multi-million pound house. If they'd done it properly to begin with, the pipe could have been whipped out of the duct and replaced. Sh1t does happen.
JohnMo Posted 4 hours ago Posted 4 hours ago 5 hours ago, SimonD said: Uponor MLC 13mm, 2.5mm thick pipe-in-pipe is designed for integration into a building structure and can be safely covered with screed. Withdrawn without causing structural damage, this water regs compliant pipe-in-pipe is supplied in 50M lengths. Product features But it is within flex conduit not directly embedded, - for clarity States similar to this - https://www.multipipe.co.uk/knowledge-base/do-you-install-your-hot-cold-pipes-in-floors/?srsltid=AfmBOopxxCCySW4Q1pdnV0rpxDKf6TCdk71yIPUyWcaBhL6S0K1AMi5D 1
