Mattg4321 Posted 13 hours ago Posted 13 hours ago Following on from the other topic I just posted, it would really help if I could connect to an access chamber (300mm) the same as in the picture (note it's not this one!) There are no spare inlets, can I create one in the riser somehow? Note that this is surface water, not foul. It would be a connection from an aco drain.
Mr Punter Posted 12 hours ago Posted 12 hours ago If this is just surface water you can pretty much do as you please. 1
Mattg4321 Posted 9 hours ago Author Posted 9 hours ago 13 minutes ago, Oz07 said: Just y off an existing branch It's an option, but more hard work than connecting directly into the access chamber!
