Which airtight tape is best for window reveal cavity closers to blockwork?
I need to start buying air tight tape for various areas of the build, but first up, i need to order some asap to seal the plastic cavity closers to the internal block work reveals before the windows get fitted next week.
I've just realised I'm going to need to tape one side of the closer before the frames go in. I'm having the frames set back into the cavity by 25mm, so window reveal fixing straps are being used, these will over lap the closer, meaning taping later wont make a decent seal.
Siga fentrim was suggested for some areas but its very expensive.
Just to add, all block work reveals are painted in airtight paint and closers will be modified to be thicker.
You don't tape to blockwork.
You need to parge the blockwork, to get it flat and uniform, and then paint it with liquid airtight membrane (assume Passive Purple from Intelligent Membranes?) and then you tap to that.
If you've PP the bare blockwork then that's less than great as the pours of the blockwork will allow air to pass behind the tape.
A pic of what you have would help, but, tbh, you just get the windows installed and then airtight afterwards, which reduces unnecessary work and effort.
This was one where I got the builders to fully parge the woodcrete ICF, as it's pretty dogshit unless you do the lot, and then PP over. Then they foamed, then they taped.
Very difficult project where I was principal consultant, but the builders were really good guys and we got an initial 0.88 ACH, then a bit of 'go find the leaks', and then a final test at 0.66 ACH (as built, end of project test) which was really not expected.
Would it make a difference if the blockwork was being wet plastered? Fully embedding the airtight tape into the plaster. This is what i did, with the fabric type tape, was what the guidance suggested was the right thing to do. Blocks were primed with airtight primer before the tape. Just curious really, not much i can do about mine now if it is wrong lol
Hi, I'll reply to you both.
Correct me if theres a better order to do this before or after the windows are fitted next week. I was thinking i need to do some upfront work. See picture for my window reveal.
Its 100mm dense block inner, 100mm pir set back by the depth of the plastic cavity closer 25mm. 50mm air gap, 100mm facing brick.
I'm going to fit the cavity closers this weekend before the windows go in. Im modifying them and adding 50mm thick pir to make them 75mm total, the extra bit wont bridge the cavity, but will overlap the set back window frame.
I'm using soundal soudatight brush on around the reveals, the rest of the walls will later be sprayed after chases are completed Cant get anyone to wet plaster so dot and dab boards.
I planned to paint the reveals this weekend to seal up pores in the blocks, then add the cavity closers over lapping, then tape closers to blocks, then windows fitted with the straps drilled into the inner block work, and then touch up over the brackets and screws with tape or more membrane. That way any air tight tapes are adhering to painted blockwork and will adhere much better than to bae dusty blockwork.
I thought if i fit closers, then windows in, then try to paint over it all and tape closers to blocks it will get messy.
It sounds like i need to parge coat the reveals with sand a cement asap, then add soudal liquid membrane paint, then cavity closers, then windows fitted, then tape over? @Nickfromwales
I want to ensure the laps/wings of the plastic closer have a good seal to the inner block work and need the closers fit before Tuesday windows.
The brush on soudal lq has reinforcement fibres in and is a paste and much thicker than what will be sprayed onto the inside block work later on using their sp version.
Its already bought. Passive purple is great but the price was far too expensive.
Use flexible tile adhesive instead of sand / cement, you’ll thank me later ;)
Use the standard set not rapid, and mix it to quite a stiff consistency. You don’t need a 5mm thick layer so don’t go wasting time / money getting these perfect and uniform. Just get it on, do a couple of reveals, go back to the first and trowel it to get it half decent, and then go over with a wet sponge an hour later to get a ripple free finish.
Couple of hours later you can paint the liquid AVCL over the parge. Moisture will soak into the mortar so don’t worry about it not having fully dried out.
I do about 150-200mm of parge, then about 100mm of liquid AVCL, minimum 2 coats, leave to fully dry (this is very important) then tape to that.
How much of the cavity closer will be exposed between the frames and the tape / parge?
The brush on stuff is good, just when you use it it tends to either need to be lathered on to allow the fibres to bridge stuff (which means it takes days to dry) or you brush most of that back off. It’s a bit of a fiddle to get used to applying it, plus you then use a lot more than perhaps you needed. One benefit, as it says it’ll plug 5mm pores, is you could miss the parge work out, but it needs more coats lathered on and lots of drying time vs parge and thin coats of the liquid AVCL.
If times against you, I’d parge.
What does the 150 - 200 mean?
Most of my vertical block reveaals are 1050 to 1275mm high. I've used the brush on around the full house perimeter before i built the masonry hangers into the block work diring construction and its quite an easy product to apply and it does fill a lot of the grainy holes, a parge would give this a better finish but i thought the liquid avcl would have a better lifetime bond to the blocks rather than adhesive then painting over that?
The cavity is 150mm, frames set back 25mm. Ill assume the closers wings are 25mm, so there will be 150mm of plastic to cover.
I didnt think theres a need to paint over the whole closer. I proposed to tape the inside closer edge to the parged or liquid sealed inner leaf block, then use a folded tape to tape the window frame to the closer 15/50mm or similar.
Then adhere my plasterboard to the reveals over everything.
If i don't vertically tape the closers edge to the inner block before the windows are fitted, ill be taping over metal window straps too so the tape wont be continuous betwen plastic and masonry, it will be taping over metal too.
Edited by ruggers
I think you need check reveal cavity closers as one of the wings will clash with your brickwork.
These https://insulationgo.co.uk/150mm-xt-cl-close-r-checked-fit-pir-cavity-closer-brick-outer-pir-core-insulation/
or if you want fire rated, which may be a better fit with the rigid insulation:
https://www.insulationsuperstore.co.uk/product/arc-ecocloser-150mm-fire-rated-cavity-closer-2-4m-length-pack-of-6.html
A 150mm to 200mm ribbon, continuous around every opening. The pic above shows about 300mm as the clients went loop the loop with liquid Barney.... The danger when a self-builder becomes beyond obsessed with one particular thing, and then can't stop themselves ordering a few pallets of something......then some more.....and some more......
Not imo, the parge with tile adhesive is a much better surface for the liquid AVCL than rough blockwork, and gives a far more uniform surface for tape to be applied to. I got a <0.2 ACH with the last one, a masonry refurb of a 1960's POS. Blasted that past EnerPHit, and out the other side 😎.
You'll need to use foam over the closer, and dab over the masonry / Soudal / tape.
Which is fine, as then the fixings of the plates will be behind the tape / foam, and be sealed nicely. This is how every job gets done that I've seen. Tape last.
And yes, the window company "could" have used bloody cranked plates....... they just thought it would be good to make like difficult.
I'll have a look whats delivered tomorrow, theyre all dkfferent.
If theres an outer wing too, i can cut it off or it will be hidden between the frame and brick anyways.
@Nickfromwales I'll give the flexi adhesive a go this weekend, only needs to be a few mm thick then so should dry quick.
Get all the closers cut ready, and fit them with a bit of hybrid polymer and if needed some twist nails.
I was looking at some soudal tape 200mm, they do two types.
One has a self adhesive window strip side, then a peel off butyl side on the masonry edge.
The extra tape is the same, but then the full area between the two strips is also a peel off adhesive strip. Not ure if this will make it easier or harder to apply for a full 4 sided opening in one go.
I need a decent upstairs ceiling membrane too. I was asvused to use ampatex db90 with siga fentrim 50/85 (£85 quid is steep) because its prefolded and saves tons of tkme. Do the full upstairs before the stud walls go up so its only the perimeter edge to tape up.
Edited by ruggers
If you’re not short of time, and your time is ‘free’ then don’t buy pre-folded tape?
200mm wide tape is something I’ve never seen or used, usually we’d just do multiples of runs of 50 or 60mm tape, but typically 80 and 90mm is the biggest stuff we use, with the largest being the window tape.
That is where the backing is split like 15mm so you can just put that onto the window or door frame and not get tangled up with exposed self adhesive trying to grab on to everything in sight.
Once you start you’ll get the hang of it quite quickly tbh.
Get the consistency of the adhesive right, and it’ll be easy to work / manipulate, but if it’s too sloppy you’ll be finding it a horrible job.
Get a plasterers hawk and a medium size plasterers trowel and that will speed things up.
Hi Nick, when you say multiple runs of 60mm tape, do you mean all 4 sides of the window in one continuous swoop, then another over lapping the tape each time until you reach the desired width?.
Or do you go 360 on the inside window edge and then 360 on the closer outer edge nearest to the room side?
First option wod use a lot of tape.
I got the flexi adhesive parge coat on yesterday, just scraped it hard to the block and it went on nicely.
Was the thank me later to this aimed at longevity or ease of spread compared to sand and cement?
I'm considering doing the inner walls the same now with multifinish before i spray them with airtight membrane (dont think my shoulder will thank me later), Could be over kill but self builders often aim high.
Do you have a preference for tape brands you use or they all much alike?
If you need to cover 100mm then you’d be looking at minimum 2 runs of 60mm tape to do that, I’d go 3 for robustness and to give a decent overlap.
You can buy thicker tapes, but you just end up trying to buy the right thickness tape for xyz locations and as a contractor it just isn’t economical. Wider tape costs more than narrow tape so 🤷‍♂️.
Yes, self builders are mostly all loonies, so I am making plenty of adjustments lol.
Sand and cement doesn’t really parge well, unless you mix a bit of SBR in and get the consistency perfect each mix, then it still goes quite granular as you spears it out and the masonry almost immediately sucks the moisture straight out of it. Then it’s like making thin sandcastles on vertical surfaces, give it a go if you wish, which is where you will thank me. I accept all major brands of beer / IPA.
Remind me are you using AeroBarrier or just tape / foam / parge / liquid AVCL?
Are you saying you’re going to spray the whole house interior with liquid AVCL??
I'm still curious if wet plastering the tape in would save all this parging and excessive taping?
Or would these areas be lined with plasterboard?
Living in a 60s bungalow, the 'cavity closers' on my place are L shaped blocks, so the whole reveal is solid and therefore wet plastered
You can’t wet plaster these reveals in, over a modern cavity / cavity closer, so your example of a 60’s returned masonry reveal isn’t apples for apples re the OP question.
For your job the advice would be different again.
