andeebee Posted 19 hours ago Posted 19 hours ago Hi all, Would just like some reassurance over a building fabric usd in my renovation / extension. I had originally asked that I wanted to fit a breather membrane like Pro Clima Intello fabric into the extension ceiling space between the living area and the warm roof, the builder replied saying he had some material that was expensive, so I felt reassured that this would be suitable. My extension has had a green poly looking material fitted for some weeks now, which doesnt look like the Intello fabric up close, it looks like poly. Can anyone tell from this photo what has been fitted and whether it is suitable to be fitted in the ceiling? I found a similar looking material listed on ebay as a 'vapour control barrier' in the same green colour, but was to be used under wooden flooring. I have given up trying to get the place airtight now as there are so many holes, but I dont want any problems due to the wrong material being used.
Nickfromwales Posted 17 hours ago Posted 17 hours ago Defo supposed to be a VCL. Breather would be on the external surfaces. With correct detailing, it could become the AVCL, but a lot of questions would need answering to assure you of this, plus a lot more attention to detailing. Are you having MVHR? I can't recall.
Russell griffiths Posted 7 hours ago Posted 7 hours ago (edited) That looks like the cheapest polythene you can get. if it’s a warm roof shouldn’t the vcl already have gone in under the insulation. is this the same builder that didn’t seal up all the roof area that you had to redo. and the same one that built the timberframe I questioned a section of your timberframe saying it was wrong but you didn’t reply to that bit. if it is then you need a new builder. Edited 7 hours ago by Russell griffiths 1
Nestor Posted 7 hours ago Posted 7 hours ago On my warm flat roof I fitted the VCL after the Rockwool in between the joists, then OSB, Batten, Plasterboard. I fitted 40mm Pavatherm above the joists.
Nickfromwales Posted 6 hours ago Posted 6 hours ago Horse and the cart seem a bit confused here tbh. @andeebee, do you have a pic of the architects section for this roof build up?
Redbeard Posted 5 hours ago Posted 5 hours ago (edited) 14 hours ago, andeebee said: I have given up trying to get the place airtight now as there are so many holes, but I dont want any problems due to the wrong material being used. While the extension is incomplete it is the best time to chase and resolve the leaks. They will bug the hell out of you in future if you don't. I agree with @Russell griffiths that the membrane on the sloping soffits looks like standard thin poly VCL. There's a small chance it could be something else but that green is suspiciously indicative of 'Bargain Basement VCL'. I'd like Intello too. Please do not give up on leak-finding! I assume the walls are leaky too? But even if they are not, as far as the roof goes you want (a) the right membrane and (b)someone to make sure it is as tight as a tight thing from an air-tightness POV. If the reason you have given up with a/t is the difficulty of finding the holes have you thought of making a basic 'blower door' (old desk fan or car radiator fan in a lump of ply) to tape into an opening? If you de-pressurise the room you're checking then, certainly in this weather, you will feel cold air rushing in. Arm yourself with good-quality a/t tape and you're off. I am sure someone(s?) on here has posted pics of such a home-made fan. Found it: 1st post on p.4 of this: Good luck. Do not give up, and please do not let them begin to plasterboard till you are happy. Edited 4 hours ago by Redbeard @Sparrowhawk's fan 1
Iceverge Posted 3 hours ago Posted 3 hours ago I'd would prefer nothing there than that layer of poly. It will be far too resistant to vapour to allow any drying back into the room and your roof rafters will get damp. Intello or some other low sd or variable sd membrane or nothing What's being constructed is a recipe for rotting your timbers.
