Russell griffiths Posted 4 hours ago Posted 4 hours ago Morning. attatched garage I have 4 x25mm holes between the house and the attached garage, each hole has a 25mm conduit in it with a couple of cables in each. what are the regs for any fire prevention measures between the garage and the house, around the area of these cables. any thoughts. cheers.
Dunc Posted 2 hours ago Posted 2 hours ago Dunno if this applies for you: Scottish building standards technical handbook section 2.1.14 allows penetrations of up to 40mm diameter without remedial measures. 1
Russell griffiths Posted 36 minutes ago Author Posted 36 minutes ago 2 hours ago, Dunc said: Dunno if this applies for you: Scottish building standards technical handbook section 2.1.14 allows penetrations of up to 40mm diameter without remedial measures. That would be handy.
