Thorfun Posted yesterday at 17:05 Posted yesterday at 17:05 it seems opinions on the web differ. some say PVA, some say a Plastering Grit, some say just soak the concrete blocks with water and some say don't bother with anything! what's a person to do? they are new blocks (although the walls were built 4yrs ago) so it's not like they've got old plaster or render on them or paint or anything. it's not a large area either with a small area around a door, a short wall (800mm wide) and in a cupboard under the stairs. do I REALLY need to prime?
crispy_wafer Posted yesterday at 17:26 Posted yesterday at 17:26 Wipe em down, get rid of any dust/loose material, a bit of moisture on the wall will slow down any moisture transfer from the adhesive, which may or may not help… depends on how loose the mix is, with mine some walls i damped down, some I didn’t, looks like it has made no difference to the end result. In your case I’d probably not bother. 1
Oz07 Posted yesterday at 18:26 Posted yesterday at 18:26 Mix a blob of adhesive up, dab a bit of board on and try to get it off in a week. No prep required usually. If excessively dusty give it a brush. I certainly wouldn't be wetting it immediately prior. Might be hard to dab the boards to a straight edge 1
Thorfun Posted yesterday at 18:29 Author Posted yesterday at 18:29 1 minute ago, Oz07 said: Mix a blob of adhesive up, dab a bit of board on and try to get it off in a week. No time for that! Want to get it finished this weekend so I can tidy up next weekend for the plasterers the week after. 😉
Nickfromwales Posted yesterday at 18:56 Posted yesterday at 18:56 Avoid that Sineat(?) adhesive. Was getting sucked dry in no time, and boards weren’t staying stuck to it if any open time had been introduced. Switched back to Gypsum and totally different results. Client bought Sineat stuff as it was the path of least resistance, but even their plasterboards were shit in comparison. If a roller dipped in 50/50 SBR/water solution, put on with a shaggy roller is cheap and simple, then I’d say sizing the walls the day before to bind the surfaces would be a no brainer. Not exactly something you can revisit, is it? Don’t get lazy now, get your finger back out and put in the time and effort 🫡. SBR is cheap enough, and can even be applied with a Hozelock spray bottle that you pump up, but you Siri need to take a soft brush to the wall (hence the roller application as it kills both birds).
Thorfun Posted 23 hours ago Author Posted 23 hours ago 1 hour ago, Nickfromwales said: Avoid that Sineat(?) adhesive. Was getting sucked dry in no time, and boards weren’t staying stuck to it if any open time had been introduced. Switched back to Gypsum and totally different results. Client bought Sineat stuff as it was the path of least resistance, but even their plasterboards were shit in comparison. If a roller dipped in 50/50 SBR/water solution, put on with a shaggy roller is cheap and simple, then I’d say sizing the walls the day before to bind the surfaces would be a no brainer. Not exactly something you can revisit, is it? Don’t get lazy now, get your finger back out and put in the time and effort 🫡. SBR is cheap enough, and can even be applied with a Hozelock spray bottle that you pump up, but you Siri need to take a soft brush to the wall (hence the roller application as it kills both birds). Interesting how that I’ve had 3 responses and there’s still no real agreement! 😂
crispy_wafer Posted 22 hours ago Posted 22 hours ago (edited) Haha, used siniat boards and adhesive 🤣, no problems, had a bag that was slightly out of date, that stuff went off quicker than Usain Bolt and the board didn’t hold, but that was me being a tight git, rather than the materials! Edited 22 hours ago by crispy_wafer 1
crispy_wafer Posted 22 hours ago Posted 22 hours ago 44 minutes ago, Thorfun said: Interesting how that I’ve had 3 responses and there’s still no real agreement! 😂 If you’ve any doubt, you’ve got nothing to lose by sizing the wall with a splash of sbr and water, it certainly won’t harm the job. IMO The mix of adhesive is the biggest factor.
Thorfun Posted 21 hours ago Author Posted 21 hours ago 1 hour ago, crispy_wafer said: If you’ve any doubt, you’ve got nothing to lose by sizing the wall with a splash of sbr and water, it certainly won’t harm the job. IMO The mix of adhesive is the biggest factor. Sure. And I’ve thought about just mixing up some PVA but I wanted to get it finished tomorrow and if I have to paint it on and let it dry then that won’t happen! I’ll sleep on it and see how I feel in the morning.
Thorfun Posted 3 hours ago Author Posted 3 hours ago So, it turns out the question I should’ve asked is “Should I REALLY be allowed anywhere near a plastering trowel?” to which the answer is a most definite NO!!! I should’ve learnt from when I first tried plastering that I am rubbish with a trowel. I just made a mess. ended up giving up, scraping it all off and went back to metal frame instead. if I ever ask a question about DIY anything that involves a plastering trowel please tell me to not be so f*****g stupid and to pay a professional. 1
Thorfun Posted 2 hours ago Author Posted 2 hours ago 19 minutes ago, Oz07 said: I find a bucket trowel easier to throw dobs on. Thanks but I’m never trying that again. 1
Oz07 Posted 2 hours ago Posted 2 hours ago I'm also terrible at wet trades. I think a lot of the skill is getting consistentcy of the mix right whether it be mortar, adhesive etc etc
Thorfun Posted 2 hours ago Author Posted 2 hours ago 10 minutes ago, Oz07 said: I'm also terrible at wet trades. I think a lot of the skill is getting consistentcy of the mix right whether it be mortar, adhesive etc etc I did wonder if the adhesive was too wet but if I added any more then I think it would've been too dry. I guess it's a fine line. probably didn't help that I was trying my first attempt around a door in a constricted area up a ladder with cables in the way and needing to bring the plasterboard out 35mm. maybe if it was a flat large wall and simpler I might have had more success. but it's most definitely once bitten twice shy! especially when metal framing is so simple. 1
-rick- Posted 1 hour ago Posted 1 hour ago 13 minutes ago, Thorfun said: probably didn't help that I was trying my first attempt around a door in a constricted area up a ladder with cables in the way and needing to bring the plasterboard out 35mm. Really set yourself up for success there! Curious why you even went down this route when you are already plasterboarding some walls? 1
Oz07 Posted 1 hour ago Posted 1 hour ago 42 minutes ago, Thorfun said: I did wonder if the adhesive was too wet but if I added any more then I think it would've been too dry. I guess it's a fine line. probably didn't help that I was trying my first attempt around a door in a constricted area up a ladder with cables in the way and needing to bring the plasterboard out 35mm. maybe if it was a flat large wall and simpler I might have had more success. but it's most definitely once bitten twice shy! especially when metal framing is so simple. Yeh I've seen site bashers literally use a garden fork and spade to mix it up in a big tub. I think as dry as you can have it while still workable for board adhesive.
Nickfromwales Posted 1 hour ago Posted 1 hour ago 1 hour ago, Thorfun said: and needing to bring the plasterboard out 35mm. If you’d have said that earlier, I’d have said don’t dab! Metal frame saves the day (or timber) at that depth.
Thorfun Posted 18 minutes ago Author Posted 18 minutes ago 1 hour ago, -rick- said: Really set yourself up for success there! Curious why you even went down this route when you are already plasterboarding some walls? Curiosity? To see if I can do dot and dab. Also there was a bit in the cupboard that would’ve been a pain to use MF so I thought I’d give it a go.
Thorfun Posted 17 minutes ago Author Posted 17 minutes ago 42 minutes ago, Nickfromwales said: If you’d have said that earlier, I’d have said don’t dab! Metal frame saves the day (or timber) at that depth. You live and you learn.
