Roger440 Posted 5 hours ago Posted 5 hours ago (edited) 1 hour ago, Dillsue said: Put a duct in so you can easily change the cable if needed?? I don't know what the regs say but with a duct run to a "safe" area either end you may be able to run singles in the duct which will be way cheaper than an equivalent SWA. That wouldnt comply, A plastic duct isnt mechanical protection. Edited 5 hours ago by Roger440
ProDave Posted 5 hours ago Posted 5 hours ago The AC/DC thing. Volt drop in AC is critical, with PV it manifests itself as voltage rise, i.e. the voltage at the inverter will be higher than the voltage when it gets to the house. Now most inverters have an upper limit where they will limit power output or shut down completely. This is typically 253V. If your grid voltage is already high, there might not be much tolerance and the inverter may shut down often. Voltage drop on DC will still give the same power loss but is very unlikely to cause the inverter to shut down, so does not cause much of a problem.
sgt_woulds Posted 5 hours ago Posted 5 hours ago 11 minutes ago, Roger440 said: That wouldnt comply, A plastic duct isnt mechanical protection. Correct hence my earlier post: 14 minutes ago, sgt_woulds said: High voltage AC can be protected with affordable and easily available RCD. If someone puts a shovel through a buried AC cable, the power cuts in the blink of an eye, and the inverter shuts down. If the same spade goes through a buried DC cable, it forms a direct circuit with the solar panels at full power until the sun sets! Again, I've been out of the game for a long time, and I know that DC RCM are now available for connection between the panels and field cables, but CMIIR, these don't work as quickly as an AC RCD, and are costly . With long buried DC field cables you will also need to use very expensive DC specific double insulated and armoured cables. Or 'ordinary' double insulated DC cables in armoured conduit. It would be usefull to hear from any practicing Solar installers / electricians for their thoughts
Ed_ Posted 3 hours ago Posted 3 hours ago 15 hours ago, Roger440 said: Summary. Electricity will get more expensive. Whatever government ministers might say. But we all know they lie, so i guess we shouldnt be surprised. Pre and post pandemic is a different universe for large construction projects, cost inflation has been brutal. There is, unfortunately, a lot of fake news around, like the recent loud protests in certain newspapers that the cost of net zero is £7tn. A figure that is deceitfully incorrect - the cost of net zero in the paper from which the £7tn is dishonestly derived is £380bn. Not trivial, but very different. The question is which generation source is the cheapest going forwards, given we need new generation, and it is probably pretty similar for renewables and gas taken as a system. What is not included in that cost and is arguably the most important factor is the uncosted effects - polution, climate change, funding of dictators and wars, volatility. Pick your poison. Oh, and an interesting point that is usually ignored is that given the highest cost generator sets the price for that slot, when considering the system costs of renewables you should account for the fact that if we didn't have renewables the electricity price every day would be much higher as it is the most expensive generators that it is kicking out of the mix. When you look at "gas prices" https://eciu.net/analysis/reports/2025/marginal-gains-how-wind-is-pushing-gas-out-of-the-power-market-and-cutting-costs On 15/01/2026 at 11:24, Roger440 said: Gas is, i understand, circa £55 v yesterdays 20 year commitment to paying £95. I don't believe this is correct. Wholesale prices yesterday were around £100, that price will have been set by gas generation. I think you might be quoting the price of gas as being around £55/MWh. CCGT efficiency in converting energy in the form of gas to electricity is around 60% so that gives a price of £92, then there is the cost of the plant doing the conversion so that probably takes you up to the £100. This is an easy mistake to make because it is a favourite technique employed by media commentators who know better but for some unknown reason choose to mislead.
Roger440 Posted 2 hours ago Posted 2 hours ago 8 minutes ago, Ed_ said: Pre and post pandemic is a different universe for large construction projects, cost inflation has been brutal. There is, unfortunately, a lot of fake news around, like the recent loud protests in certain newspapers that the cost of net zero is £7tn. A figure that is deceitfully incorrect - the cost of net zero in the paper from which the £7tn is dishonestly derived is £380bn. Not trivial, but very different. The question is which generation source is the cheapest going forwards, given we need new generation, and it is probably pretty similar for renewables and gas taken as a system. What is not included in that cost and is arguably the most important factor is the uncosted effects - polution, climate change, funding of dictators and wars, volatility. Pick your poison. Oh, and an interesting point that is usually ignored is that given the highest cost generator sets the price for that slot, when considering the system costs of renewables you should account for the fact that if we didn't have renewables the electricity price every day would be much higher as it is the most expensive generators that it is kicking out of the mix. When you look at "gas prices" https://eciu.net/analysis/reports/2025/marginal-gains-how-wind-is-pushing-gas-out-of-the-power-market-and-cutting-costs I don't believe this is correct. Wholesale prices yesterday were around £100, that price will have been set by gas generation. I think you might be quoting the price of gas as being around £55/MWh. CCGT efficiency in converting energy in the form of gas to electricity is around 60% so that gives a price of £92, then there is the cost of the plant doing the conversion so that probably takes you up to the £100. This is an easy mistake to make because it is a favourite technique employed by media commentators who know better but for some unknown reason choose to mislead. This is all good stuff. And interesting But the point remains, electricity is going to go up, probably a lot. Not down as our gloourius leaders, and some on here kepp saying. There are significant consequences to that especially if other countries dont see those increases.
saveasteading Posted 1 hour ago Author Posted 1 hour ago 4 hours ago, Roger440 said: old mole plough They are not expensive to hire. We once put in about 150m of duct across a field and I think it only took a day. I wasn't there that day so haven't seen it done, but our op, who was used to driving a digger, said it was easy.
