I'm planning an in to out 'warm' wall build up as follows - all outboard of a structural oak frame.
Plasterboard and skim
125 x 50mm stud at 400 centres (vented air gap)
15mm OSB3 taped joints (functioning as a VCL amongst other jobs). Could apply another VCL over this OSB if needed/use smartply if we have to!
120mm PIR
50mm Counter batten (vented air gap)
Breather membrane
Wood cladding
The aim here is to avoid the inevitable breaks and gaps that occur when an internally applied VCL is installed around a structural oak frame. I also like the idea of a VCL that retards but doesn't 'trap'. The design idea also allows for an unbroken insulation layer that fully wraps the structure without thermal breaks (other than counter batten screws)
Ubakus tells me the condensation risk is zero. Does anyone have any thoughts? I can apply a stand alone VCL over the OSB if needed.
Thanks for any thoughts!
:bigsmile:
Also posted in the Green Building Forum FYI!
14 minutes ago, David Cooke said:
120mm PIR
Why PIR, it could shrink, giving you breaks in the insulation. I take it's going between the 125mm studs?
I would increase depth of stud and do mineral wool, wood fibre or even cellulose pumped in.
If it's not structural why not use 600mm centres this will lead to fewer thermal bridges.
My last self build was a timber I-beam portal frame, structure as follows:-
350mm Steico timber I-beam, fully filled with Icynene
15mm OSB3 square edge racking
Protect TF200 membrane
50mm timber battens fully filled with Rockwool RW6
Protect A1 membrane
50mm counter battens vented air gap
15mm cedar cladding
The walls and roof were both constructed in a similar way. The construction was successfully tested using the Glaser method for condensation risk. A WUFI analysis was not carried out. That may be of some use.
Hi JohnMo,
It's a warm construction - PIR outside of stud and OSB3.
So unbroken layer of PIR on top of OSB3 (carried by the stud wall)
PIR held in place by counter battens.
Stud voids to be used as utility voids and probably not insulated unless client wants additional.
My question is whether it needs a dedicated VCL over the OSB3 or not. My guess is no - dew point being somewhere toward outer surface of a completely unbroken layer of PIR - where no moisture laden air can reach.
12 hours ago, David Cooke said:
Hi GoneWest,
Was that a Passivhaus?
Yes, two storey, walls and roof U factor 0.095W/m2K, floor 0.1W/m2K, 0.47ACH.
That would work fine. U value won't meet regs though. What kind of rain screen are you planning on ?
The vapour permeability of the OSB is a bit mute when you have foil faced PIR outside of it but it will work as an air control layer which is much more important than vapour control.
With a 125x50 TF external to the oak frame you're building 2 houses though but that always seems to be the issue with oak frames. I think @Post and beam used SIPS.
As an idea you could spec an I-Joist structure to balloon frame over the oak with an external airtight layer like @IanR. With the Oak taking most of the structural loads it hopefully could be quite minimal. Full fill with cellulose then.
@Iceverge - over counter battens, likely machine profile horizontal larch on walls. Roof - plain clays.
Interesting you say won't meet regs - ubakus seems to suggest it will (just) at 120mm - (but 140 would work too if needed). If you can equate any of the German PIR branded types to a comparable UK brand that would be really helpful!
Yes do like the I joist method with full fill cellulose - I'm also designing my own house at the mo - and will look into this for that.
The 125 x 50 allows me to go hybrid structurally - ie. reduce the work load of the oak (and thus the quantity) by sharing it with the softwood wrap.
