Copper vs aluminum clouts for slate roof?
I'm having a slate roof installed on a self build, 400 centres, and I want to know if copper clout nails should be used or aluminum?
The slates are 250 x 500mm 7 to 9mm thick.
38mm clouts required and 30mm for the eaves course.
Aluminum 3.35mm or the roofer says if using copper I could use 2.65mm.
I want the roof to last 40 yrs+
Some online reading says aluminum may fail between 20 and 30 years is this true?
We're 3 miles inland off the West coast, there's a few houses around but we do get a bit of wind in winter.
Have you looked at stainless hooks?  Zero uplift on windy days.
We used copper.
You don't with nails either.
+ 1 I used these when re-roofing our old place. We had a very shallow slope so the increased uplift protection was needed.
Copper. My roof is about 135 years old. I reckon 70+% is 'as laid' and has the original copper nails. No membrane, of course, and no leaks at present.
  • 3 weeks later...
On 22/12/2025 at 11:59, JohnMo said:
We used copper.
No one could get me a price until the new year.
Did you use 2.65 or 3.35mm?
Cheapest i can get is £89 per 5kg of 2.65mm, which is a lot cheaper than online.
Amazon is £82 but not sure what they'll be like.
Think the thicker ones, roof installer did everything including nail supply.
He only specified nails.
The hooks are very expensive
There will be specialist local roofing merchants who will know what is the local preference.
