I'd like to add a simple wall mounted panel heater to our holiday cottage, so that we can keep it at a reasonable temperature when nobody is there, using the off peak overnight rate. At the moment we leave the heated towel rail on when the weather is cold, which is probably not the most cost effective method.
I was thinking of just buying a hardwired wifi relay (e.g. a 25A one from Shelly) but then I came across heaters with Wifi functionality built in. That's quite appealing because it would allow people in the cottage to use the heater as well.
I'm a bit worried about the longevity of any built in 'smart' technology though. Having owned an early Smart TV which after a couple of years was no longer supported, I feel that it's easy for the app to be updated and suddenly older tech no longer works. Maybe this could happen to the Shelly relay too, but at least in that case I only have to replace that one small component.
Any thoughts? And any recommendations?
I would go simple heater (thermostat) and add any control for timer etc.
far too much stuff now that requires an app to use it.
i have just put two oil filled rads in my workshop but controlled with smart plugs for timing
Edited by markc
That's my gut feeling, but it doesn't let the person in the cottage operate it unless they download the app and log in.
I use Tapo plugs and you can control by app but also turn on/off using the button, nice bit is that if you manually over-ride, the next schedule cycle reverts back to auto control.
4 hours ago, -rick- said:
Keep it simple and use something like this?
https://www.tlc-direct.co.uk/Products/SMTGBD4.html
* Confirm with electricitian this is suitable
That doesn't do anything that a heater with built in controls wouldn't already do.
I'm looking to be able to remotely control the heater, but also allow on-site control, all without having to have two heaters.
That might be along the right lines, although having had a scare with an immersion heater that ran through a plug in timer, I'd much prefer hard wired.
Perhaps I'm being a bit paranoid, the immersion was 3kw and the heater would be much less. But I'd still prefer it if the user was unable to unplug it to charge their phone!
Sorry, I actually misunderstood the features of that device.
I was thinking of something that had a built in timer (that wasn't adjustable by the guest) with a boost button that they could press for extra heat.
A Shelly relay will allow remote  (via app) control as well as a switch in the cottage for people there to use, it won't prevent a simple switch being used as well.
I thought about simply adding a relay to a normal heater, the problem there is that a guest could turn it off and then I can't turn it back on.
I'd have to instruct my cleaner to leave the controls in the on position, but based on experience I wouldn't want to rely on that.
28 minutes ago, -rick- said:
Wire the shelly to a retractable switch and program it to boost for 1 hour if the switch is pressed.
Retractable?
