Onoff Posted July 31, 2025 Posted July 31, 2025 5 hours ago, saveasteading said: I used waco once then got a sparky to do the clever bit. He removed and changed them all. Then these as above this time. I think they are a bit small for the stranded armoured cable. I couldn't decide if I had to lift the lever or is that only for removal... holding that up was a nuisance. I will practice tomorrow and maybe get the hang of it. Plenty of videos on using them on YouTube. You are in a minority not using them tbh. 1
saveasteading Posted July 31, 2025 Author Posted July 31, 2025 6 hours ago, Nickfromwales said: what bit It was in a very old house for one of the family, about 10 years ago . I distributed cables and fitted new downlighters: so the floorboard lifting, drilling of oak joists etc that Mr Sparks wouldn't like. So 8 hours me, 30 mins Electrician. " You're not going to do the mains connection I hope". "No, I'll get Mr Sparks to check it and connect it. ". What I'd done was fine except he didn't like Wagos and redid with terminal blocks. Then I put back the floor. 2 hours ago, Kelvin said: cheap copies. Mine are as the pic above, from SF. All very fiddly inside the box with my big and clunky fingers. I must have had an average of 5 go's with each, then for some reason it would hold. So that was 7 wires x 5. The box instructions simply have a tiny picture indicating "push in wire", which didn't work.
andyscotland Posted July 31, 2025 Posted July 31, 2025 1 hour ago, saveasteading said: Mine are as the pic above, from SF. All very fiddly inside the box with my big and clunky fingers. I must have had an average of 5 go's with each, then for some reason it would hold. So that was 7 wires x 5. The box instructions simply have a tiny picture indicating "push in wire", which didn't work. Ah yeah that sounds much more faffy than actual Wago. Especially for stranded. 1
Nickfromwales Posted July 31, 2025 Posted July 31, 2025 4 hours ago, saveasteading said: What I'd done was fine except he didn't like Wagos and redid with terminal blocks. He was a penis then. 1 1
