paro Posted yesterday at 05:49 Posted yesterday at 05:49 Hi All - As part of my work I was hoping to replace the pvc gutter with some nicer looking galvanised steel. The lean to roof is 38 degrees so a non standard size. I was hoping to find some kind of simple adjustable bend but this doesn't seem to be a thing. My next idea was to step it out slightly and then run it down the wall using a standard angle, however this will not look great as it will be at a different angle to the roof. In all honestly I am probably the only person that will ever see or notice this given that it's kind of hidden away. I thought I should ask if anyone was aware of any options for an adjustable bend. I did speak to someone from a reseller who said there are companies that will make custom ones but this will propbably cost a fortune and I am trying to stop myself doing stuff like that. The final downpipe will be fixed to the return wall on the extension. Thanks, Paul
ToughButterCup Posted 22 hours ago Posted 22 hours ago We solved a similar problem in a stuff-it-can't-find-the-right-product-way (wrong angle in the available standard stock) Not exactly the same issue as yours - but close..... Like this - a few holes drilled in the bottom. Take the boot off, flush out the leaves bingo. 1
paro Posted 21 hours ago Author Posted 21 hours ago 1 hour ago, ToughButterCup said: We solved a similar problem in a stuff-it-can't-find-the-right-product-way (wrong angle in the available standard stock) Not exactly the same issue as yours - but close..... Like this - a few holes drilled in the bottom. Take the boot off, flush out the leaves bingo. Thanks I needed that with all this build stuff at the moment
ProDave Posted 20 hours ago Posted 20 hours ago No help in an existing building, but this is just one of the many reasons I think all new roofs should be built at a 45 degree angle.
marshian Posted 11 hours ago Posted 11 hours ago 13 hours ago, paro said: Hi All - As part of my work I was hoping to replace the pvc gutter with some nicer looking galvanised steel. The lean to roof is 38 degrees so a non standard size. I was hoping to find some kind of simple adjustable bend but this doesn't seem to be a thing. My next idea was to step it out slightly and then run it down the wall using a standard angle, however this will not look great as it will be at a different angle to the roof. In all honestly I am probably the only person that will ever see or notice this given that it's kind of hidden away. I thought I should ask if anyone was aware of any options for an adjustable bend. I did speak to someone from a reseller who said there are companies that will make custom ones but this will propbably cost a fortune and I am trying to stop myself doing stuff like that. The final downpipe will be fixed to the return wall on the extension. Thanks, Paul I'd be gluing a 45 deg bend to the down pipe and then firing up a hot air gun and heating the downpipe just after the bend to make it form to the required 38 deg angle - you are never gonna see it from ground level and the water is going to want to flow along the bottom of the down pipe anyway
marshian Posted 10 hours ago Posted 10 hours ago Alternatively - if you get some solvent weld adhesive and it melts the down pipe fitting you might be able to pie cut a fitting and then solvent weld it??
