BotusBuild Posted Wednesday at 14:05 Posted Wednesday at 14:05 I just found a lovely use of a zip tie. Couldn't get the bottom screw of the pipe clip in .... 2
Redbeard Posted Thursday at 10:35 Posted Thursday at 10:35 Was the title meant to be *pipe* clips and zip ties? I had assumed not and was waiting for an exposition on the myriad alternative uses for paper clips (apart from temp. replacement clips on split-link chains and repairing my reading glasses). 3
BotusBuild Posted Thursday at 16:30 Author Posted Thursday at 16:30 5 hours ago, Redbeard said: Was the title meant to be *pipe* clips and zip ties? I had assumed not and was waiting for an exposition on the myriad alternative uses for paper clips (apart from temp. replacement clips on split-link chains and repairing my reading glasses). You've got the idea - adding to the thread with the start of a myriad of ideas 😅 1
marshian Posted Thursday at 17:47 Posted Thursday at 17:47 13 minutes ago, SteamyTea said: This is from the BBC just needs duct tape over the mouth to resolve the noise issue caused by cable ties
marshian Posted Thursday at 17:51 Posted Thursday at 17:51 My forum signature in a different place as always “in life you need three things - cable ties, duct tape and WD40 - if it moves when it shouldn’t use cable ties or duct tape - if it doesn’t move and it should use WD40” I am partial to old Opels so it’s pretty normal for those cars
Pocster Posted Thursday at 18:02 Posted Thursday at 18:02 10 minutes ago, marshian said: My forum signature in a different place as always “in life you need three things - cable ties, duct tape and WD40 - if it moves when it shouldn’t use cable ties or duct tape - if it doesn’t move and it should use WD40” I am partial to old Opels so it’s pretty normal for those cars You got a dungeon ?
SteamyTea Posted Thursday at 18:16 Posted Thursday at 18:16 27 minutes ago, marshian said: just needs duct tape over the mouth to resolve the noise issue Won't the WD40 stop the squealing.
marshian Posted Thursday at 18:38 Posted Thursday at 18:38 36 minutes ago, Pocster said: You got a dungeon ? No I haven't - can I borrow yours? I don't mind the odd drip 1
marshian Posted Thursday at 18:40 Posted Thursday at 18:40 22 minutes ago, SteamyTea said: Won't the WD40 stop the squealing. You're thinking shove the WD40 can in the mouth - because yes that would?
SteamyTea Posted Thursday at 18:50 Posted Thursday at 18:50 (edited) 23 minutes ago, marshian said: You're thinking shove the WD40 can in the mouth - because yes that would? You trying to get me into trouble. I find a good squirt on the soles of bare feet stops them running away. @Pocster taught me that. 3 in 1 works as well. Edited Thursday at 19:04 by SteamyTea 1
MikeSharp01 Posted Thursday at 18:52 Posted Thursday at 18:52 13 minutes ago, marshian said: odd drip Bit harsh implying @Pocster is an 'odd drip' he may be odd but he is no drip or have I got that the wrong way round. 1 2
Nickfromwales Posted Thursday at 19:09 Posted Thursday at 19:09 15 minutes ago, MikeSharp01 said: Bit harsh implying @Pocster is an 'odd drip' he may be odd but he is no drip or have I got that the wrong way round. We have considered giving him his own category here, but the men in white coats gave up trying to name it.....
SteamyTea Posted Thursday at 19:13 Posted Thursday at 19:13 4 minutes ago, Nickfromwales said: gave up trying to name it X-Spurt X is the unknown, spurt is a drip under pressure.
