BotusBuild Posted July 9, 2025 Posted July 9, 2025 I just found a lovely use of a zip tie. Couldn't get the bottom screw of the pipe clip in .... 2
Redbeard Posted July 10, 2025 Posted July 10, 2025 Was the title meant to be *pipe* clips and zip ties? I had assumed not and was waiting for an exposition on the myriad alternative uses for paper clips (apart from temp. replacement clips on split-link chains and repairing my reading glasses). 3
BotusBuild Posted July 10, 2025 Author Posted July 10, 2025 5 hours ago, Redbeard said: Was the title meant to be *pipe* clips and zip ties? I had assumed not and was waiting for an exposition on the myriad alternative uses for paper clips (apart from temp. replacement clips on split-link chains and repairing my reading glasses). You've got the idea - adding to the thread with the start of a myriad of ideas 😅 1
marshian Posted July 10, 2025 Posted July 10, 2025 13 minutes ago, SteamyTea said: This is from the BBC just needs duct tape over the mouth to resolve the noise issue caused by cable ties
marshian Posted July 10, 2025 Posted July 10, 2025 My forum signature in a different place as always “in life you need three things - cable ties, duct tape and WD40 - if it moves when it shouldn’t use cable ties or duct tape - if it doesn’t move and it should use WD40” I am partial to old Opels so it’s pretty normal for those cars
Pocster Posted July 10, 2025 Posted July 10, 2025 10 minutes ago, marshian said: My forum signature in a different place as always “in life you need three things - cable ties, duct tape and WD40 - if it moves when it shouldn’t use cable ties or duct tape - if it doesn’t move and it should use WD40” I am partial to old Opels so it’s pretty normal for those cars You got a dungeon ?
SteamyTea Posted July 10, 2025 Posted July 10, 2025 27 minutes ago, marshian said: just needs duct tape over the mouth to resolve the noise issue Won't the WD40 stop the squealing.
marshian Posted July 10, 2025 Posted July 10, 2025 36 minutes ago, Pocster said: You got a dungeon ? No I haven't - can I borrow yours? I don't mind the odd drip 1
marshian Posted July 10, 2025 Posted July 10, 2025 22 minutes ago, SteamyTea said: Won't the WD40 stop the squealing. You're thinking shove the WD40 can in the mouth - because yes that would?
SteamyTea Posted July 10, 2025 Posted July 10, 2025 (edited) 23 minutes ago, marshian said: You're thinking shove the WD40 can in the mouth - because yes that would? You trying to get me into trouble. I find a good squirt on the soles of bare feet stops them running away. @Pocster taught me that. 3 in 1 works as well. Edited July 10, 2025 by SteamyTea 1
MikeSharp01 Posted July 10, 2025 Posted July 10, 2025 13 minutes ago, marshian said: odd drip Bit harsh implying @Pocster is an 'odd drip' he may be odd but he is no drip or have I got that the wrong way round. 1 2
Nickfromwales Posted July 10, 2025 Posted July 10, 2025 15 minutes ago, MikeSharp01 said: Bit harsh implying @Pocster is an 'odd drip' he may be odd but he is no drip or have I got that the wrong way round. We have considered giving him his own category here, but the men in white coats gave up trying to name it.....
SteamyTea Posted July 10, 2025 Posted July 10, 2025 4 minutes ago, Nickfromwales said: gave up trying to name it X-Spurt X is the unknown, spurt is a drip under pressure.
