DIY Heat Exchanger
12 minutes ago, SteamyTea said:
It is activated by the light and has the usual overrun of a bathroom fan (because it uses two bathroom fans).
Ta. Are the fans a matched pair in terms of lpm?
  • Replies 59
  • Views 28.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Yep probably should have said in the ceiling as the flow would be one to the other unless it was directed properly.    I’d (theoretically) put the inlet on the outside of the bathroom door a
  • To a point, but longer also means more resistance.     It'll work either way around - look at the arrows in this diagram - one end of the tube is stale air in and fresh air out (inter
  • Have you met Onoff?
Posted Images
5 hours ago, SteamyTea said:
Yes, a couple of inline Monroe ones.  They were dead cheap.
Manrose surely?
  • 4 months later...
How easy to recreate the heat exchanger in one of these?
Doesn't look a lot in them:
Just caught up on this thread. A few posts here are a bit concerned with the conductance (thickness and/or conductivity) of the separator material. My conclusion is that typically the resistance is dominated by the boundary layer resistance so the material doesn't matter all that much: https://edavies.me.uk/2014/03/mhrv-area/ , the hard part is making the area large enough in a compact and cheap way.
  • 5 years later...
With the 3D printer now, making a "holder" for the drinking straws into which you can pour a sealant should be a doddle.
MVHR.thumb.GIF.e2a8b801dde558c6423e52494df74aca.gif.b46678c077c0c52f1502f23b42985600.gif
@Onoff
I made an MVHR unit a few years back.
I separated the plates with some timber strips with double sided tape on each face.
One day I will make the Mk3 version.
27 minutes ago, SteamyTea said:
@Onoff
I remember. Still in your loft isn't it?
No.
I binned it during the early part of the year.
Don't think it was doing much in the end as I never put any filters in it.
Having said that, the pipe that goes to outside (is that the exhaust, they use odd names on heat exchangers) came loose, some housemartyns started nesting in the hole, and the pipe was dripping water out.  Still not painted the ceiling in the spare bedroom (needs at least 5 years to dry properly I think).
So it may have been working as condensation was happening.
