JohnMo Posted June 30, 2025 Posted June 30, 2025 Currently have no smart meter that works due to a poor signal, after talking with a smart meter installer I now know how to get a working meter. Will explain for any one in a similar position. Electric supplier has to have 3 unsuccessful smart meter installs. You then request the case is raised with the DCC. 6 weeks later they allow a 4G meter to be installed. Problem fixed. So to my dilemma Have ASHP, GivEnergy 13kWh battery, PV but don't get paid for export. What is the best tariff to be on Standard tariff make no sense with a battery. E7 currently on that, easy to manage, but may not be most cost effective? Cosy, seems easy to manage? Agile, GivEnergy has controls built in, but expects export from what I can tell. Any suggestions or users doing anything different? Should I just pay octopus the £250 to allow export and be paid?
JamesPa Posted June 30, 2025 Posted June 30, 2025 (edited) 26 minutes ago, JohnMo said: Any suggestions or users doing anything different? Should I just pay octopus the £250 to allow export and be paid? For me (no battery, ev, ashp, pv) I can't better eon next drive and eon export. 7hrs at 6.7p, the rest very slightly more than the best fixed rate without tou. 16.5p export. So I charge the EV, do the washing and washing up, heat the dhw and bake bread at night whatever the season as the revenue from export exceeds the cost of nighttime import. This has the distinct advantage that it's simple to manage (like the one you are on). I don't even need a smart ev charger, just a 13A EV rated socket. With a battery and no EV I think I'd end up doing the same, but I can't make the business case for a battery work. I did a spreadsheet comparing the various options. The differences between the various tou tariffs weren't that large by comparison to not having a tou tariff at all, and the simplicity meant I didn't need any smarts other than the smart meter. Of course the numbers will depend on your own usage. Edited June 30, 2025 by JamesPa
S2D2 Posted July 1, 2025 Posted July 1, 2025 Eon next drive is good but I've stuck with Octopus Go because I use Cosy in the winter and can't be bothered switching supplier twice a year. I see Eon now have "Next Pumped" but that's only 8 hours cheap overnight (maybe, they dont show actual pricing online) so not a replacement for cosy with the 3 cheap periods. If your battery can get you through the rest of the day though, 6.7p on next drive is very attractive.
JohnMo Posted July 1, 2025 Author Posted July 1, 2025 Unfortunately I don't have an EV, go and drive type tariffs won't work, unless they don't really ask you to prove EV. I am thinking Cosy maybe a good choice, easy to programme times for charging etc. But an EV tariff is way cheaper
sharpener Posted July 1, 2025 Posted July 1, 2025 24 minutes ago, JohnMo said: I am thinking Cosy maybe a good choice, easy to programme times for charging etc. But an EV tariff is way cheaper We started with 7.1 kWh of battery and quickly added another module which I had allowed for so now have 10.65 kWh In an ideal world I would add a fourth module but that would mean moving the consumer unit so cba. Cosy suits us well bc the 1300 - 1600 cheap slot allows the HP to precharge the thermal store at the same time as the inverter charges the battery, all ready for the evening meal and keeping the CH going through the evening peak rate. With yr enormous slab @JohnMo you will probably do entirely without the HP during the peaks. I decided not to go for the Octopus Go etc EV tariff bc you need to play continual games to optimise the behaviour for the HP. Cosy is fit and forget. All I have to do is change the settings when I am away so the house can run from the battery during the allowable charging times, when the house is occupied this is not desirable as it cycles the batteries too deeply (simple explanation but not entirely correct).
Dillsue Posted July 1, 2025 Posted July 1, 2025 55 minutes ago, JohnMo said: Unfortunately I don't have an EV, go and drive type tariffs won't work, unless they don't really ask you to prove EV. Octopus didn't ask us for proof of an EV but only wanted the model. I think its fairly easy for them to see the load profile during the night time cheap rate but whether they monitor that is anyone's guess??
JohnMo Posted July 1, 2025 Author Posted July 1, 2025 25 minutes ago, sharpener said: With yr enormous slab @JohnMo you will probably do entirely without the HP during the peaks. I can run the HP at full load during cheap rates (E7 hrs) via a second set point, but if I add hot water in the mix, I cannot get enough energy in the floor when temps start to get close to zero (mostly defrosts limiting ultimate output), so as temperatures drop the heat pump runs longer in the day. I can get to the point by teatime I have a flat battery, then I am using 32p instead of 14p energy. Cosy would give the opportunity to charge again during the day when needed. Then I could just run straight WC and do it all on cheaper rates. 1 minute ago, Dillsue said: Octopus didn't ask us for proof of an EV but only wanted the model. I think its fairly easy for them to see the load profile during the night time cheap rate but whether they monitor that is anyone's guess?? Thats interesting
S2D2 Posted July 1, 2025 Posted July 1, 2025 57 minutes ago, JohnMo said: Unfortunately I don't have an EV, go and drive type tariffs won't work, unless they don't really ask you to prove EV. I am thinking Cosy maybe a good choice, easy to programme times for charging etc. But an EV tariff is way cheaper Next Drive was available for a short time for battery owners but the latest version reintroduced the requirement for an ev, no idea why. Octopus never asked for proof for Go but if they wanted to find users without, it wouldn't be too difficult from usage. Cosy is convenient and allows my small battery to cover heavy heat pump usage in the winter. I experimented with tweaking the heat pump but with just radiators decided it wasn't worth it and just the battery do the work, charging 3x per day. The only compromise is the higher cheap rate.
JoeBano Posted July 1, 2025 Posted July 1, 2025 When I was on octopus agile it was a lot cheaper then octopus intelligent go which currently on. Only swapping over because I got an electric van. On agile it’s cheapest between the 10am to 4pm. You can get tracking apps to tell your technology to come on when it’s cheapest 4 hour window. In summer you get paid to burn electricity. I would swap back but I need to charge my van (60kw) at night when I’m home.
JamesPa Posted July 1, 2025 Posted July 1, 2025 (edited) 5 hours ago, JohnMo said: Unfortunately I don't have an EV, go and drive type tariffs won't work, unless they don't really ask you to prove EV. Eon didn't ask me for proof of ev ownership or even the model, and doesn't require you the have a dedicated EV charger (IE the eon rules allow you to charge from a 13A socket). Can they tell the difference between your battery and a battery on wheels? will they bother? Edited July 1, 2025 by JamesPa
JohnMo Posted July 1, 2025 Author Posted July 1, 2025 1 minute ago, JamesPa said: Can they tell the difference between your battery and a battery on wheels? will they bother? I doubt they would really know, they would have no idea if I did 5 miles a day or 500 miles.
trialuser Posted July 1, 2025 Posted July 1, 2025 On 30/06/2025 at 19:26, JohnMo said: Currently have no smart meter that works due to a poor signal, after talking with a smart meter installer I now know how to get a working meter. Will explain for any one in a similar position. Electric supplier has to have 3 unsuccessful smart meter installs. You then request the case is raised with the DCC. 6 weeks later they allow a 4G meter to be installed. Problem fixed. Hi, is this definitely a 4G comms hub? I'm in Scotland (arse end), and unsuprisingly the LRRN hub failed to connect. I pestered them and they installed a GSM hub, but I believe it is 2 /3 G. I still dont have a signal as the meter/hub is in a steel clad outbuilding. I'm now pestering them to fit a T3 external antenna, but a 4G comms hub would also be preferable as the 4G signal hee is great. Thanks.
JohnMo Posted July 1, 2025 Author Posted July 1, 2025 The 4G ones apparently have just been issued, in the last week or so. Believe a few have been installed around us - near Elgin. Octopus are still playing about, insisting they attempt the smart meter install 3x, before moving to getting a SIM card meter. 1
ReedRichards Posted July 5, 2025 Posted July 5, 2025 Would it be such a sacrifice to trade-in your existing car for an EV? I'm on the EON NextDrive tariff and it meshes very well with my other electrical items, ASHP, solar PV with battery. 1
JohnMo Posted July 5, 2025 Author Posted July 5, 2025 56 minutes ago, ReedRichards said: Would it be such a sacrifice to trade-in your existing car for an EV? Not got the money at the moment, to change car, so a bit of a sacrifice to save a hundred quid or so.
marshian Posted July 5, 2025 Posted July 5, 2025 9 hours ago, ReedRichards said: Would it be such a sacrifice to trade-in your existing car for an EV? I'm on the EON NextDrive tariff and it meshes very well with my other electrical items, ASHP, solar PV with battery. I think you’ve probably missed the nice collection @JohnMo has 😉 I wouldn’t want to swap any of them for an EV 1
JohnMo Posted July 12, 2025 Author Posted July 12, 2025 Firstly now have a 4G smart meter, commissioning time was about 10 mins. Spoke with Octopus just after commissioning to change tariff (16:00 on Friday) and am now on a smart tariff (Saturday 08:30). Octopus mini hub is also being delivered today. Decided to go Octopus Cosy. Super easy battery scheduling, should never run out of cheap rate electric, not super cheap but 12.65p per kWh, 2p cheaper than my E7 tariff. Have used Wonder Watt to schedule times. First cheap slot is setup as a smart schedule so it charges based on forecast generation of PV, second slot set to 90% SoC fixed target. 90% chosen so it does not interfere with immersion or heat pump diversion, and by this time, if the smart charge is ok the battery should already be above this level, so will only come in to play if forecast is wildly out etc. Final charge is set for a fixed 100% SoC. May need to tweak over the coming days, but will see how it pans out. 3
joth Posted July 12, 2025 Posted July 12, 2025 On 30/06/2025 at 19:26, JohnMo said: Should I just pay octopus the £250 to allow export and be paid? How much PV do you have, and how much do you typically end up exporting? For me I'd pay the £250 regardless anyway as it feels rewarding to be getting something back for the export but I know others that don't care. I'm in eon next and still don't have EV, I had to click through an agreement saying I had one but that was the extent of their checks.
JohnMo Posted July 12, 2025 Author Posted July 12, 2025 1 hour ago, joth said: How much PV do you have, Around 7kW but with lots of shading morning and evening. Yesterday was mostly sunny so do 28kWh, should do 30 or so today. Looking at the battery data without trying 935kWh has slipped into the grid since I got the battery, so £140. If I stopped diverging power to heat pump and immersion that export would be 2 to 3 times, without any effort.
JoeBano Posted July 12, 2025 Posted July 12, 2025 @JohnMo off topic, what heat pump do you have? My friend is starting his self install heat pump and yours was a good price and quality.
JohnMo Posted July 12, 2025 Author Posted July 12, 2025 Mine is a Maxa, but a bargain from eBay, about 70% off retail. Look here https://coolenergyshop.com/collections/air-source-heat-pumps/products/pro-inverter-air-source-heat-pump-ce-ih6plus Or just go Panasonic. 1
joth Posted July 12, 2025 Posted July 12, 2025 (edited) 5 hours ago, JohnMo said: Around 7kW but with lots of shading morning and evening. Yesterday was mostly sunny so do 28kWh, should do 30 or so today. Looking at the battery data without trying 935kWh has slipped into the grid since I got the battery, so £140. If I stopped diverging power to heat pump and immersion that export would be 2 to 3 times, without any effort. Yeah sounds like a no brainer then. That'd be £400+ of missed exports and the lost ashp / immersion duty could be met from overnight cheap rate import at half the price of additional export you'd have made. Edited July 12, 2025 by joth
JohnMo Posted July 12, 2025 Author Posted July 12, 2025 1 hour ago, joth said: Yeah sounds like a no brainer then. That'd be £400+ of missed exports and the lost ashp / immersion duty could be met from overnight cheap rate import at half the price of additional export you'd have made. Have now applied. They are after some strange paperwork, will see what comes back and what other bits are needed.
sharpener Posted July 12, 2025 Posted July 12, 2025 (edited) 10 hours ago, JohnMo said: Decided to go Octopus Cosy. Super easy battery scheduling, should never run out of cheap rate electric, not super cheap but 12.65p per kWh, 2p cheaper than my E7 tariff. Have used Wonder Watt to schedule times. First cheap slot is setup as a smart schedule so it charges based on forecast generation of PV, second slot set to 90% SoC fixed target. 90% chosen so it does not interfere with immersion or heat pump diversion, and by this time, if the smart charge is ok the battery should already be above this level, so will only come in to play if forecast is wildly out etc. Final charge is set for a fixed 100% SoC. I have a similarly complex charging regime but have been considering just charging battery to 100% every cheap period. The thinking is that every unit bought off the grid at 12.65p liberates a unit of PV which can be exported for 15p. Is there a flaw in this? Edited July 12, 2025 by sharpener
JohnMo Posted July 12, 2025 Author Posted July 12, 2025 35 minutes ago, sharpener said: I have a similarly complex charging regime but have been considering just charging battery to 100% every cheap period. The thinking is that every unit bought off the grid at 12.65p liberates a unit of PV which can be exported for 15p. Is there a flaw in this? I was thinking of doing the same if I get export approved. Makes it fit and forget.
