YodhrinForge Posted April 26, 2025 Posted April 26, 2025 Still trying to figure out the specifics of my eco retrofit of a circa 1900 stone cottage, but I've been slightly buggered by the WUFI modelling. Based on what I'd read previously I believed taped & jointed - American style - thin gypsum plasterboard with vapour open paint would be sufficient to allow the internal wood fibre insulation and the stone wall to breathe properly, but Computer Says No apparently. Previously planned buildup was external lime harling > original stonework > up-to 30mm Diathonite levelling & airtight layer > 100mm rigid wood fibre > ~40mm stud wall to create service cavity with spaces infilled with flexible wood fibre > 12mm plasterboard > clay paint, however the modelling suggests this would accumulate moisture over time despite proper MVHR to manage internal humidity - slowly, but in a few years or certainly a decade or two I'd be having issues. The two suggested alternatives suck for different reasons; either adding an Intello membrane between the rigid wood fibre and the stud wall, but this would require dropping the flexible wood fibre filling out the spaces in the stud wall which is a noticeable reduction in u-value; or switching to clayboard with clay plastering for the interior instead of plasterboard, which has sufficient permeability to avoid the buildup issue but uses up a bit more internal space given it's thicker and would require me to fork out for a specialist plasterer to do the mesh-reinforced binder coat and the skimmed finish coat, which ain't cheap. I found *one* company offering what appear to be lime-based plasterboard substitutes designed to be very vapour open but still work pretty much exactly like common gypsum board, but they're only just starting to roll out the product and aren't selling to the public yet, and I can't imagine that a small house renovation will get through their application process to be a demo project(not to mention that as it's brand new there's no track record to look at, could be a complete dud in practice). Are they genuinely the first to come up with such a thing? Standard plasterboard was appealing exactly because with the tape & joint method I could do it myself and achieve pretty nice results for just material costs, while still maximising insulation, so any alternative that let me do something similar would be ideal.
JohnMo Posted April 26, 2025 Posted April 26, 2025 31 minutes ago, YodhrinForge said: read previously I believed taped & jointed - American style Not really American style, been done in the UK since the 70s, almost all homes in Scotland are done that way - dry lined, or Ames taping is what it's called. Just make sure you use taper edge plasterboard. Discussion here on plasterboard https://www.greenbuildingadvisor.com/question/gypsum-board-vapor-permeable-or-what
YodhrinForge Posted April 26, 2025 Author Posted April 26, 2025 1 hour ago, JohnMo said: Not really American style, been done in the UK since the 70s, almost all homes in Scotland are done that way - dry lined, or Ames taping is what it's called. Just make sure you use taper edge plasterboard. Discussion here on plasterboard https://www.greenbuildingadvisor.com/question/gypsum-board-vapor-permeable-or-what I refer to it that way mostly because most of the youtube tutorials I found were yanks and they rarely do anything else by all accounts, whereas all you hear about on UK property shows when I was growing up was plastering. Anyway, I appreciate the link but that's actually one of the things I read that encouraged me that plasterboard would work in the first place. Unfortunately the modelling of my intended buildup says that even the small additional resistance of gypsum board over clay or similar is enough to cause a slow accumulation of moisture in the wall over time even with fully vapour open paint used internally, so I'm not sure what to believe except that if the modelling is right then in a few years time I'll have to rip out all the work I'd done and do it again so it seems safer to look for alternatives.
nod Posted April 27, 2025 Posted April 27, 2025 You will have to ask your taper not to seal As it’s normal to seal after sanding which is a sealer and hardener
jfb Posted April 27, 2025 Posted April 27, 2025 Is any of this work done yet? why bother with the studs for a service void? You can embed electric cables into the wood fibre board. then finish with a number of different breathable renders (I just used sand/nhl lime). Would save a lot of time.
SteamyTea Posted April 27, 2025 Posted April 27, 2025 Rerun the WUFI model with some full fill mineral wool insulation, a VCL and a normal plasterboard wall. It may be that WUFI does not like the 'moisture buffering' of wood fibre insulation.
Mike Posted April 27, 2025 Posted April 27, 2025 (edited) On 26/04/2025 at 18:40, YodhrinForge said: the modelling suggests this would accumulate moisture over time despite proper MVHR to manage internal humidity Selecting the correct internal environment in WUFI to model that is not at all straightforward, as mentioned in my post on the topic from last year - there seems to be an absence of accurate information on which to calculate it. And, If they have erred too much on the side of caution (which I suspect), the results will be overly pessimistic. If you're able to post the details of the internal environment that they've used, that may give us a clue. if you don't have it, it would be worth asking for it. On 26/04/2025 at 18:40, YodhrinForge said: either adding an Intello membrane between the rigid wood fibre and the stud wall If that's what WUFI suggests, that increases my suspicion that it's inaccurate. I'm not a WUFI expert, but based on my own WUFI experiments, adding Intello membrane to a building that has WUFI is likley to make the moisture build-up within the wall somewhat worse (in winter), not better. That's because standard MVHR is likely to result in a lower internal relative humidity than would otherwise be the case, which, in turn, would remove moisture from the wall structure. A VCL, even a smart one such as Intello, will tend to block that drying action for part of the year. On 26/04/2025 at 18:40, YodhrinForge said: switching to clayboard with clay plastering for the interior instead of plasterboard, which has sufficient permeability If that's also based on WUFI, that also seems counter-intuitive in view of the previous suggestion. Option 1 (Intello) suggest that slowing drying to the inside (in winter) is better; Option 2 (clayboard) suggests that increasing drying to the inside is better... Edited April 27, 2025 by Mike
YodhrinForge Posted May 10, 2025 Author Posted May 10, 2025 On 27/04/2025 at 08:18, nod said: You will have to ask your taper not to seal As it’s normal to seal after sanding which is a sealer and hardener I'll remember to remember that tip thanks On 27/04/2025 at 08:45, jfb said: Is any of this work done yet? why bother with the studs for a service void? You can embed electric cables into the wood fibre board. then finish with a number of different breathable renders (I just used sand/nhl lime). Would save a lot of time. No this is me going back & forth with my architect trying to find something with the right balance of cost, risk, time, DIY-ability, and likelihood of getting past BCO/planning/whinging council conservation officers. As for the service cavity: it's more convenient, future repairs/modifications are easier, and it lets me use the plasterboard approach which for me will be a lot cheaper as I can do it myself. On 27/04/2025 at 23:44, Mike said: Selecting the correct internal environment in WUFI to model that is not at all straightforward, as mentioned in my post on the topic from last year - there seems to be an absence of accurate information on which to calculate it. And, If they have erred too much on the side of caution (which I suspect), the results will be overly pessimistic. If you're able to post the details of the internal environment that they've used, that may give us a clue. if you don't have it, it would be worth asking for it. -snip- I'll ask the architect about the model, and the other suggestions received thanks to all. Just to be clear neither of the alternatives actually have been modelled for this property and only the latter(clayboard & clay plaster) has been used(and modelled) by the architect before, the membrane solution was something the architect got back from a potential "eco" building supply place we were considering using for the raw materials, and I wanted to see if there was a way to stick with my original plan before faffing about running more models.
