LDNRennovation Posted Monday at 19:32 Posted Monday at 19:32 We might convert the garage to a bedroom, but would you render it, or add a porch? Should we add timber cladding? A new door? any ideas?
Nickfromwales Posted Monday at 20:00 Posted Monday at 20:00 If you're converting to a habitable space then the garage door is first to go in the bin. Have you thought of EPS EWI (external wall insulation) and then have a new render all round?
LDNRennovation Posted Monday at 20:31 Author Posted Monday at 20:31 25 minutes ago, Nickfromwales said: If you're converting to a habitable space then the garage door is first to go in the bin. Have you thought of EPS EWI (external wall insulation) and then have a new render all round? yes it’s overpowering isn’t it. I have thought of the insulation and render, I like the idea but would it add value to the house, or emphasise the brown windows. We aren’t planning on fitting new windows. 3 minutes ago, ETC said: How much do you want to spend? we have 40k in total for the renovation project. That’s a new kitchen and flooring (20k), and the conversion of the garage (20k). I have another 40k for an extension after that. I guess I need a new front door and clean the roof, as a minimum. I guess to do up the front and exterior would be about 10k, but do you have something nice in mind?
Iceverge Posted Monday at 21:10 Posted Monday at 21:10 (edited) By the way. That’s exactly how I did that………. Be afraid……BE VERY AFRAID!!!! Edited Monday at 21:11 by Iceverge
LDNRennovation Posted Monday at 21:12 Author Posted Monday at 21:12 I really love it lol, yep terrifying
Nickfromwales Posted Tuesday at 12:04 Posted Tuesday at 12:04 Has nobody seen iRobot? Stop with this voodoo before the machines rise against humanity and we all become slaves! probably.
Nickfromwales Posted Tuesday at 12:04 Posted Tuesday at 12:04 But the white does utterly transform the house!
saveasteading Posted Tuesday at 12:44 Posted Tuesday at 12:44 Being a suspicious type, I immediately assume that paint on masonry is to hide something.
LDNRennovation Posted Tuesday at 15:42 Author Posted Tuesday at 15:42 2 hours ago, saveasteading said: Being a suspicious type, I immediately assume that paint on masonry is to hide something. It looks nice for about a month, it is the typical house flipper tactic! I really want to render it, with insulation. But there’s so much ‘side’ to the house, where it’s going to be render you never see and goes green? the white on the outside really does make it look nice though. But it requires window colour change, I feel like.
Iceverge Posted 16 hours ago Posted 16 hours ago On 22/04/2025 at 13:04, Nickfromwales said: Has nobody seen iRobot? Stop with this voodoo before the machines rise against humanity and we all become slaves! probably. Too late.......... Probably. 1
Iceverge Posted 16 hours ago Posted 16 hours ago On 22/04/2025 at 16:42, LDNRennovation said: It looks nice for about a month, it is the typical house flipper tactic! I really want to render it, with insulation. But there’s so much ‘side’ to the house, where it’s going to be render you never see and goes green? the white on the outside really does make it look nice though. But it requires window colour change, I feel like. I wouldn't paint it, you'll be stuck painting it forever. Work with what you have is my opinion. Before going anywhere near EWI let's start at the start. 1. How to you currently ventilate the house? Extractor fans and tickle vents? 2. What's the airtighess situation? Is the house very drafty? 3. Insulation. Do you have attic insulation and cavity wall insulation? Sort things in this order.
LDNRennovation Posted 14 hours ago Author Posted 14 hours ago thanks iceverge! Really appreciate the order you did. It has cavity walls, 1980s, so I would think about adding some more insulation there. Not sure how or if it is possible. Definitely adding loft insulation yes, the roll stuff onto the rafters. it’s not drafty, yes trickle vents and extractor. we are replacing the boiler, first orders. Then it’s insulation time I think! Honestly the front elevation AI is superb.
LDNRennovation Posted 10 hours ago Author Posted 10 hours ago On 21/04/2025 at 21:23, ETC said: How much do you want to spend? Do you have any ideas? I love your designs I’d like to do something cool with this! I can do an extension at the back too.
