Sib99 Posted March 29 Posted March 29 Hi, so we sit on a decent size plot. Certainly size to build a small house at the bottom of garden. however, the only access is an unmade service road - we are at the very end. Probably 80-100m (not measured) length and certainly wide enough for vans etc. the service road is back access to houses one side and a parade of shops with flats above the other. has anyone had experience of getting PP with this sort of access?
ToughButterCup Posted March 29 Posted March 29 20 minutes ago, Sib99 said: ... has anyone had experience of getting PP with this sort of access? Hello. Access is unlikely to be a Planning issue. Why do you think it might be a problem?
BotusBuild Posted March 29 Posted March 29 Fire appliance access could be a planning issue, but can be overcome by having a mist or spray system fitted to final build
Sib99 Posted March 29 Author Posted March 29 3 minutes ago, ToughButterCup said: Hello. Access is unlikely to be a Planning issue. Why do you think it might be a problem? I’m not sure?? This seemed the most obvious place to put it. But then i genuinely don’t know what the issues are as never done anything without access from an existing road before!
Sib99 Posted March 29 Author Posted March 29 7 minutes ago, BotusBuild said: Fir appliance access could be a planning issue, but can be overcome by having a mist or spray system fitted to final build it’s actually wide enough to get a fire truck down - assuming no one else is parked (technically they shouldn’t, in reality they do) but great solution, appreciated
Susie Posted March 29 Posted March 29 Have you got room for a turning circle or hammer head turn as fire appliances are not allowed in to reverse so far.
DevilDamo Posted March 29 Posted March 29 Rights of access over this road may be more of an issue. Who owns the road?
LSB Posted March 31 Posted March 31 (edited) On 29/03/2025 at 17:28, Susie said: Have you got room for a turning circle or hammer head turn as fire appliances are not allowed in to reverse so far. Our build planning said we must have sprinklers so it is possible without the turning need Edited March 31 by LSB
Nickfromwales Posted March 31 Posted March 31 13 hours ago, LSB said: Our build planning said we must have sprinklers so it is possible without the turning need Yup. After 45m iirc, and if further away you must provision for the appliance to be able to drive in, in a forward gear, turn a full circle, and leave in a forward gear. If our bin man can reverse the refuse truck half a mile whilst swigging a coffe then you have to ask WTF here tbh 🤷♂️.
