Garage floor paint/resin/epoxy resin
On 05/09/2026 at 19:03, BotusBuild said:
then upped the water
A bad thing to do. Explained elsewhere many a time.
The driver is not allowed to do that without your signature. So when it cracks it is not their liability.
How flat and level do you want it?
The standard test is that you don't see any 3mm gaps under as 3m straightedge whatever the position and direction, even pressing down one end.
A slight slope might not matter to you.
30mm is a lot of screed.
  • Replies 52
  • Views 5.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Roger440
    Roger440
    If its a proper screed, nice and flat, then if you just want to stop dust, just use a densifier. Its clear like water and just soaks in. Cheapish, and dead easy to apply.   If you paint, you
  • saveasteading
    saveasteading
    It's just that I did a search and that came up, showing it is common. I'm pretty sure we sourced ours through a paint merchant, and it was not a mass market make.
  • Depends what you'll use garage for, but if the floor is reasonably flat swisstrax is an option worth considering.  It worked out cheaper and easier than epoxy for us (in part because we didn't need to
Posted Images
Clarifying. The "wall" was dryer than standard. Then he upped the water to get to right mix. Levelling the "wall" was hard work in the heat, but it has all set off well and no cracks (that i can see throught the current muddy puddle!!)
See above about my want for level.
Its not got to be billiard table, but better than it is.
  • 2 months later...
The major lumps and bumps were ground off the slab and we applied a leveller on Sunday. Still waiting for it to dry fully.
So in the meantime we turned our attention to the outside
