Hoponline Posted December 9, 2017 Posted December 9, 2017 I want to match a porch hipped roof with a ridged hipped roof on a side extension - Architect says can't be done and the options are lean to or mansard type roof - I want to avoid any flat roof entirely - I cannot see why what I propose is anything other than a framing challenge with a valley where the two roofs meet , side elevation is hidden so less important than the aesthetics of the front elevation I did see an image of such a roof on a google search ... but typically cannot find now when needed to send to the architect Has anyone built similar or is aware of why such a roof could not be built?
AliG Posted December 9, 2017 Posted December 9, 2017 I guess you could do this if you had a wall in line with the small ridge in the second diagram and the front area of the roof was higher than the side part of the roof. The side roof would have to be at a shallower angle than the front roof and the wall would be in line with the ridge, they couldn't share a pitch half way up as you have shown as the side roof would have to rise the same height over roughly twice the distance. But it would look very strange from the side, very strange. If you want them to look the same it would probably be much better to change the porch roof so it didn't have a ridge.
bassanclan Posted December 10, 2017 Posted December 10, 2017 Can you post up a picture of the overhead view of including the porch and proposed porch please?
ProDave Posted December 10, 2017 Posted December 10, 2017 Your red Y in the second picture. That will only work if a red line continues down from the middle of the Y and you then have a section of flat roof, which you don't want.
