bissoejosh Posted December 8, 2017 Posted December 8, 2017 Fairly certain this has been covered before but can anyone tell me how to calculate decrement delay? I've seen the link to the calculator by Arup but I think it's windows only. Thanks
TerryE Posted December 8, 2017 Posted December 8, 2017 Josh, try searching the forum for this: Buildhub forum: search all content for decrement delay. There's been lots of discussion including the ARUP online calculator (add ARUP to the search).
Jeremy Harris Posted December 8, 2017 Posted December 8, 2017 The ARUP calculator does a reasonable job: https://www.concretecentre.com/Publications-Software/Publications/Dynamic-Thermal-Properties-Calculator.aspx
bissoejosh Posted December 8, 2017 Author Posted December 8, 2017 Apologies, I'd tried the ARUP link previously but couldn't get it to work on my mac hence asking. Seems to be working this time.
SteamyTea Posted December 9, 2017 Posted December 9, 2017 https://en.wikipedia.org/wiki/Volumetric_heat_capacity#Thermal_inertia There you go.
bissoejosh Posted June 12, 2018 Author Posted June 12, 2018 (edited) I'm still unable to make the calculator work for some reason having tried again, the drop down boxes aren't available for selection and a message claiming protected cells cannot be modified stops me in my tracks. Would someone with a spare 2 minutes who can use it mind doing a calculation comparing the following wall build ups? 20mm Larch cladding 100mm cavity 11mm OSB 300mm Warmcell vs 3 x 100mm Rockwool flexi Batts (0.038) 11mm OSB 38mm Cavity 12mm PB & SKIM I'd like to know the difference replacing the Warmcell with Rockwool would make in terms of house comfort but can find no other calculator online to try. Many thanks Edited June 12, 2018 by bissoejosh
PeterW Posted June 12, 2018 Posted June 12, 2018 15 minutes ago, bissoejosh said: I'm still unable to make the calculator work for some reason having tried again, the drop down boxes aren't available for selection and a message claiming protected cells cannot be modified stops me in my tracks. Would someone with a spare 2 minutes who can use it mind doing a calculation comparing the following wall build ups? 20mm Larch cladding 100mm cavity 11mm OSB 300mm Warmcell vs 3 x 100mm Rockwool flexi Batts (0.038) 11mm OSB 38mm Cavity 12mm PB & SKIM I'd like to know the difference replacing the Warmcell with Rockwool would make in terms of house comfort but can find no other calculator online to try. Many thanks Whats the U/R value of Warmcell..?
SteamyTea Posted June 12, 2018 Posted June 12, 2018 I think you are asking the wrong question really. But after a quick look on the internet, both Warmcell and Rockwool CAN have the same R-Value and Density. So that means they can have the same thermal properties, the airtightness may vary. That should have been taken car off anyway by your basic construction method.
