The Pros and Cons of Direct Air for a Wood Stove (when there’s no mandatory requirement)
Hi all
Direct air / External air…
Additional air requirements are mandatory for stoves above 5kW in older houses, and for any stoves in newer houses (post-2008) or houses with an air permeability of 5 m3/hm2 or less.  I can understand the logic in having DA when the alternative would be an air vent (hole in the wall); although even then there are arguments on both sides.  But putting that aside a moment, when no additional air requirements are needed for a stove, is DA still a worthwhile option?  I’ve spent the day reading up on this and thought I’d post what I’ve found, as much to share my research as to get feedback and thoughts from people if anyone is interested in discussing it.
***In Favour of DA***
- Draughts.  There are quite a few people on the internet who can’t say enough good things about DA and highly recommend using it whenever possible to reduce draughts and cold air in the room.  It’s an enticing idea!  However,  I did notice that this is usually as opposed to having to have an air vent.  When the alternative to DA is no air vent (for a 5kW or less stove), I’m not so sure how many of these people would still recommend it.
- Draughts – Anecdotes.  That being said, I found instances where people were saying they used to have a stove which took air from the room, they weren’t happy with the draughts being created, and so retrofitted a DA feed and it made a world of difference.
- Wasting Heated Air.  Some say that without DA, you are wasting air in the room that has already been heated and replacing it with cold air.  This quote sums it up:  “…I would definitely fit a direct air supply not only [for] the prevention of draughts but for the conservation of heat. Using room air you would be using air already heated and a wood burner will use a considerable amount of combustion air out of the room you have heated.”  REBUTTAL:  However, stoves actually use quite a small amount of air when compared to the average standard air changes required in a room.  The air changes will have to happen one way or another, so unless MVHR is used, won’t hot air still have to be replaced with a fresh cold supply regardless?
- Colder Air Burns Better.  Quote:  “The colder the air – the denser it is and more oxygen per unit volume it contains, so it must be good to assist combustion.”  REBUTTAL:  However, I’m sure I’ve also heard the opposite, that colder denser air is detrimental to combustion.  Not sure which is right.
- Cold Air Expands When Heated.  The claim therefore is that this can assist chimney draw as it is taken away up the flue.
- Control.  Although DA means less air changes compared to air from the room, it means you have more control over when you ventilate the house.  IE – opening windows in the morning, or before going out.  You can control the ventilation, and separate the times to ventilate from the times to heat.  Also, you can introduce more ventilation when required due to the weather (damp days) and less when not (dry crisp days).  As one person puts it, “Using the stove air to ventilate, means you wouldn't ventilate the right amount at the right time.”
I thought this article was particularly useful in highlighting benefits, although note the “conditions” on page 2.
https://mtbest.net/wp-content/uploads/sites/12/2023/02/cold-air-intake-1.pdf
***Against DA***
- Simply Not Needed.  Many people claim DA is not necessary, for various reasons.  Also, all of the installers and stove shops I have spoken to (which is quite a few!) have unanimously said not to bother and that we would not gain anything.  The “Outdoor Air Myth Exposed” article – link below – claims that it has been studied and DA (or even just air vents) are most often of no benefit.
- Stoves Don’t Create Draughts.  Some say it is not true that you feel draughts.  They say to try putting your hand by the stove’s air inlet, where the air is being sucked through a small aperture and should therefore be the aggregate of all air being pulled.  If there were draughts you would feel it there, but you don’t.
- Cold Air Cools the Stove.  Pulling cold air directly into the stove will be worse for combustion and will cool the internal temperature of the firebox.
- Cold Air When Not in Use.  The duct will be cold and will emit cold air, especially when the stove is not in use (or even when the stove is in use, to be fair, as it’s still sucking in cold air).  Thermal bridge to outdoors.
- DA is Worse for Ventilation and Humidity.  If the stove takes air from the room, it encourages more air changes in the house.  This in turn can increase ventilation and help with humidity too.  Outside air is almost always drier/lower RH, so frequent air changes help.
- MVHR.  Of those people who think DA is a good idea, they sometimes add that MVHR is needed too for air changes.  Without MVHR, some say it’s best to vent the stove from the room air.  I don’t and won’t have MVHR, so that’s an “against” for me.
- Wind and External Air Pressure (Backdraught) Problems.  If the wind is at a particular strength and direction it can cause smoke to blow back into the room, as well as CO.  It can also make it difficult to start the stove.  Unpredictable and variable.  There can also be a potential fire risk if the reversal of the flue system flow results in the hot gases being expelled from the DA intake.  Also, if mechanical extraction in the house de-pressurises more than the chimney draw, smoke and gases can be drawn out of the stove and into the room.  REBUTTAL:  See “cold-air-intake” pdf (link above).  He says to have the external vent positioned in a place where there will be no wind (consistent known pressure), which would deal with this problem.  If that’s not possible, I wonder is something like the DR21 could help with this?
- Air from Below Stove (and Entry Into Ash Pan Area).  See “cold-air-intake” pdf (link above).  He states that the DA needs to be supplied from below the fire as a requirement for it to be effective.  This is not possible for many wood only stoves as they have no ash pan.
- More Money!  Kits are often £100+.  Fitting will add to the bill as well (unless DIYing).
- Historic Precedent.  It’s not how they used to do it in the old days!  Older houses need older methods?
The strongest article I found arguing DA – and air vents in general – and claiming that studies have proved it:
https://www.woodheat.org/the-outdoor-air-myth-exposed.html
I appreciate the post is long, and probably quite boring! So feel free to ignore it; although if you've got this far then I guess it's a bit late to say that! But if it interests anyone, I’d love to hear your thoughts, arguments and agreements. Personal experiences always great to hear as well.
Cheers
Edited by Oxbow16
Can I ask where that came from? I installed a stove in ~2019, signed off by BC, and this wasn’t a factor as far as I remember.
You’ve done a v thorough analysis. In my simplistic mind it just boils down to ‘if passivehouse levels of air tightness (and therefore MVHR) then piped in air, otherwise room air is fine’. Ours is in a not particularly air tight house, doesn’t have external air, and It’s been difficult for me to notice a draft when the thing’s pumping out serious heat (5kW). We also have a Nest CO and a PM detector and the internal air is good.
@Alan Ambrose, you can click and select text, and then hit the quote selection tab to quote other members posts ;)
Typing the @ symbol followed by the first letters of a username will allow you to tag a member (as I have done with your username here, with it now in a blue bubble).
I think there may be issues with his account that prevents this?
From experience of both.
Direct air is best. I agree with all the pros.
I add that when the wind is gusting we get backdraughts of smoke from the non direct one...horrible.
Also when the fire is not lit, I think quite a bit of draught/ heat loss is leaking through the vents.
Plus. Is isn't difficult to fit the intake if it is part of newbuild or refit.
Edited by saveasteading
I forgot about that gem, saw that in a friends house when we were fitting their alarm & cctv and was something I couldn’t tolerate. I also noticed the decoration around the WBS was displaying evidence of this happening plus general use…
The newly installed stove with direct air works beautifully.  Other benefits are that once it is going, it can burn a single log, rather than have to keep stacking more on, so that is more controllable and efficient,
The tiny amount of ash confirms burning efficiency too.
Anyway this is academic if you want building regulations.
If being done under the radar I still recommend direct air.
It's a shock that we now have to get a smoke test done at who knows what cost.
