OldieNewbie Posted February 1, 2025 Posted February 1, 2025 Are concrete heads no longer used over doors and windows? it seems that every opening has steel in place where the head would usually be. why is that?
nod Posted February 1, 2025 Posted February 1, 2025 Some still do But most use steel insulated lintels
Onoff Posted February 1, 2025 Posted February 1, 2025 34 minutes ago, nod said: Some still do But most use steel insulated lintels Even over internal doorways?
Canski Posted February 1, 2025 Posted February 1, 2025 41 minutes ago, Onoff said: Even over internal doorways? No. Concrete or uninsulated steel there.
nod Posted February 1, 2025 Posted February 1, 2025 1 hour ago, Onoff said: Even over internal doorways? No concretes fine There’s a 1.3 million pounds house being built near us that has used Concrete Lintels over every opening some are 2.8 wide
OldieNewbie Posted February 1, 2025 Author Posted February 1, 2025 So there’s no actual rules or regulations on bridging over windows or doors and steel? its at the discretion of the designer/engineer?
dpmiller Posted February 2, 2025 Posted February 2, 2025 your building regs will tell you. Remember most of the guys here are in GB... 1
Iceverge Posted February 2, 2025 Posted February 2, 2025 11 hours ago, OldieNewbie said: So there’s no actual rules or regulations on bridging over windows or doors and steel? its at the discretion of the designer/engineer? It's the load they need to take. Steel is defaulted to buy many structural engineers as it's easy to spec and there's suppliers in every town. I would prefer concrete. Easier to plaster etc after. 1
