G and J Posted January 27, 2025 Posted January 27, 2025 8 minutes ago, Nickfromwales said: Just make sure you seal / foam the interior section of the threshold VERY meticulously, to stop any unwanted cold airflow, as alu is a PITA with condensation. Copy that. I’m going for nicely airtight anyway but I can see the need for even greater vigilance around aluminium door and window frames.
Russell griffiths Posted January 28, 2025 Posted January 28, 2025 @G and J extend the insulation outwards, carry your brick work around the house, but when you get to the door area change to a brick slip cut from the facing bricks you are using. that way you can keep the brick look and increase the insulation amount with a 20mm thick brick slip over the face for the step area. 1
G and J Posted January 28, 2025 Posted January 28, 2025 Just now, Russell griffiths said: @G and J extend the insulation outwards, carry your brick work around the house, but when you get to the door area change to a brick slip cut from the facing bricks you are using. that way you can keep the brick look and increase the insulation amount with a 20mm thick brick slip over the face for the step area. Sounds good but is that actually practical to do? Maybe with a high power tile cutter?
Russell griffiths Posted January 28, 2025 Posted January 28, 2025 2 minutes ago, G and J said: Sounds good but is that actually practical to do? Maybe with a high power tile cutter? Standard brick saw with a diamond blade, your brickies will have one, it will only be 30-40 bricks needed across patio door. I cut a couple of thousand chunks of Cotswold stone, now that was a silly idea. 1
G and J Posted January 28, 2025 Posted January 28, 2025 9 hours ago, Russell griffiths said: Standard brick saw with a diamond blade, your brickies will have one, it will only be 30-40 bricks needed across patio door. I cut a couple of thousand chunks of Cotswold stone, now that was a silly idea. Bet your neighbours loved you lol
SBMS Posted January 28, 2025 Author Posted January 28, 2025 22 hours ago, G and J said: Copy that. I’m going for nicely airtight anyway but I can see the need for even greater vigilance around aluminium door and window frames. What aluminium doors/windows you getting out of interest?
G and J Posted January 28, 2025 Posted January 28, 2025 2 minutes ago, SBMS said: What aluminium doors/windows you getting out of interest? At the moment we are looking at smart systems stuff: alitherm 800 windows, designer (ooh er Mrs!) front door and Visioglide patio doors all from a local company. Some fixed windows and the opening ones will be top hung. Still tons of work to be done on that, with the next job being to finalise the opening sizes for the timber frame company (another local-ish bunch). The big advantage is that once the timber frame is up they’ll come along and measure, then a 8 to 10 weeks later they fit them. Any breakages or mistakes they fix, pronto.
SBMS Posted January 28, 2025 Author Posted January 28, 2025 28 minutes ago, G and J said: At the moment we are looking at smart systems stuff: alitherm 800 windows, designer (ooh er Mrs!) front door and Visioglide patio doors all from a local company. Some fixed windows and the opening ones will be top hung. Still tons of work to be done on that, with the next job being to finalise the opening sizes for the timber frame company (another local-ish bunch). The big advantage is that once the timber frame is up they’ll come along and measure, then a 8 to 10 weeks later they fit them. Any breakages or mistakes they fix, pronto. Have you considered seniors? We looked at smarts but seniors looked better, lower u values and similar price.
Nickfromwales Posted January 28, 2025 Posted January 28, 2025 1 hour ago, G and J said: Bet your neighbours loved you lol He’d have to drive 10 mins to find out
Russell griffiths Posted January 29, 2025 Posted January 29, 2025 10 hours ago, G and J said: Bet your neighbours loved you lol I killed them a long time ago 💥🔨🔫🪓🔪⚰️⚰️ 1
G and J Posted January 29, 2025 Posted January 29, 2025 14 hours ago, SBMS said: Have you considered seniors? We haven't, mostly because we are attracted to what is a local (long standing) firm taking on the whole job, including manufacture, and should cash flow deem it necessary (!) more than one hit at fitting. From a quick look at the seniors site, they look very similar, but couldn't see anything about installation?
SBMS Posted January 29, 2025 Author Posted January 29, 2025 2 hours ago, G and J said: We haven't, mostly because we are attracted to what is a local (long standing) firm taking on the whole job, including manufacture, and should cash flow deem it necessary (!) more than one hit at fitting. From a quick look at the seniors site, they look very similar, but couldn't see anything about installation? Similar to smarts in that there will usually be a local fabricator and they might install or refer you to an installer. I get that finding a local firm is important. Where are you based?
G and J Posted January 29, 2025 Posted January 29, 2025 On 28/01/2025 at 12:06, Russell griffiths said: @G and J extend the insulation outwards, carry your brick work around the house, but when you get to the door area change to a brick slip cut from the facing bricks you are using. that way you can keep the brick look and increase the insulation amount with a 20mm thick brick slip over the face for the step area. Eureka!! I've come up with the perfect solution to my needing brick slips that I can’t buy to match our chosen plinth bricks without subjecting our neighbours to hours of deafening brick cutting or choking them and myself on the dust. Please would everyone on build hub order some brick samples. Each sample card comes with some lovely little brick slips to save postage costs! Perfect! What could possibly go wrong? 😕 1
G and J Posted January 29, 2025 Posted January 29, 2025 5 hours ago, SBMS said: Where are you based We're in Suffolk...the firm we're thinking of employ their own installers/surveyors etc as well as make windows....has the attraction of it being in their hands and if the worst happens they have capability to fix pretty quickly.....or that's the theory 🤞
Nickfromwales Posted January 30, 2025 Posted January 30, 2025 5 hours ago, G and J said: Please would everyone on build hub order some brick samples. Each sample card comes with some lovely little brick slips to save postage costs! There's over 20k members on here, beware of what you ask for. The postage to you would then be around £4k
Nickfromwales Posted January 30, 2025 Posted January 30, 2025 2 hours ago, G and J said: We're in Suffolk...the firm we're thinking of employ their own installers/surveyors etc as well as make windows....has the attraction of it being in their hands and if the worst happens they have capability to fix pretty quickly.....or that's the theory 🤞 ......🤞 indeed....
G and J Posted January 30, 2025 Posted January 30, 2025 6 hours ago, Nickfromwales said: There's over 20k members on here, beware of what you ask for. The postage to you would then be around £4k Hmmmmm, in that case I’ve an excuse for another Makita toy, I mean tool, honest!
