ADLIan Posted November 29, 2017 Posted November 29, 2017 See Celotex website , www.celotex.co.uk. Appears they have not been exactly truthful with their thermal performance!
ProDave Posted November 29, 2017 Posted November 29, 2017 So they have been under stating the values. So it is better then they have said? And the problem is.....?
ADLIan Posted November 29, 2017 Author Posted November 29, 2017 With lamba value lower = better so ‘understating’ is not good. Since 2009 they’ve been claiming 0.022 W/mK when it should have been 0.023 W/mK. Makes all your U-values higher (worse). Not good for their certification and CE mark especially on the back of Grenfell and incorrect quoted fire performance - all on website.
CC45 Posted November 29, 2017 Posted November 29, 2017 How much difference will this make in the real world?
Jeremy Harris Posted November 29, 2017 Posted November 29, 2017 22 minutes ago, CC45 said: How much difference will this make in the real world? Very roughly the performance will be around 4.5% worse that predicted. Down in the noise, really, but interesting, because at the time that Celotex claimed a lambda of 0.022 it was lower than any of their competitors who were selling near-identical PIR foam insulation, so it probably helped gain them market share.
A_L Posted November 29, 2017 Posted November 29, 2017 Something else is the reduction in R value as the temperature drops with falling exterior temps. This is American so have to divide by about 5.7 to get S.I. R values https://buildingscience.com/documents/information-sheets/info-502-temperature-dependent-r-value The R values of fibrous insulation tend to increase with falling temps.
ADLIan Posted November 29, 2017 Author Posted November 29, 2017 +1 JSH. PUR manufacturers sell heavily on conductivity - try selling 0.023 product against 0.022 product and you’re dead in the water! 4.5% degradation does not sound much but on 8 years production it adds up. Temp variation effect on conductivity is not important here compared to USA which has massive changes in climate from north to south. Under BS conductivity is normally measured at mean 10K (0C - 20C).
