philcvk Posted Monday at 21:16 Share Posted Monday at 21:16 (edited) Hi - I'm doing an extension in timber frame and on the outside of the studs I have OSB, breathable membrane (roofing felt), battens and cement render carrier boards. The final look I need is white render to tie into the rest of the house. The quotes to do the render (thin coat or 6mm silicon) are ££££, and so wondered if it'd be cheaper do beading with 200mm of filler around the edges and then prime and paint everything, using a good grade exterior paint? (probably exterior caulk the joints of the cement boards too). I'd be really interested to hear what others have done on render carrier / cement boards for the final layer. I've heard issues with thin coat render peeling off the cement boards, and nervous about the paint option that this could be one cheap fix not to make. Would be great to know what other people have done, thanks Edited Monday at 21:17 by philcvk Link to comment Share on other sites More sharing options...
nod Posted Monday at 23:01 Share Posted Monday at 23:01 Unfortunately paint and filler won’t stay on cement board Thin coat is fine if it’s done right Link to comment Share on other sites More sharing options...
Nick Laslett Posted Tuesday at 08:40 Share Posted Tuesday at 08:40 (edited) 9 hours ago, nod said: Unfortunately paint and filler won’t stay on cement board Thin coat is fine if it’s done right @nod are you sure about this? All my soffits/undercloaking is cement board. It has been up for 2 years, paint seems okay. I’m pretty sure I just followed M.I. on how to paint; use SBR primer. Of course this use case is completely different to what the original post is asking. https://www.sts-board.com/wp-content/uploads/2024/05/STS-Construction-Board-Product-Leaflet_2024.pdf @Adam2 did you go ahead with painted cement board as you suggested in this thread? Edited Tuesday at 09:01 by Nick Laslett 1 Link to comment Share on other sites More sharing options...
saveasteading Posted Tuesday at 09:22 Share Posted Tuesday at 09:22 10 hours ago, nod said: Unfortunately paint and filler won’t stay on cement board There are systems where a netting is applied first, with screw fixings, then the render sticks to the board enough, with the additional support of the mesh. Very expensive but it works and I would not advise any other way. Or apply sods law and spill paint or render on it accidentally, as we know that doesn't come off. 1 Link to comment Share on other sites More sharing options...
nod Posted Tuesday at 10:35 Share Posted Tuesday at 10:35 Think coat render we do lots of TF buildings that way Sticks like sh## to a shovel 1 Link to comment Share on other sites More sharing options...
philcvk Posted Tuesday at 14:07 Author Share Posted Tuesday at 14:07 Thanks, great comments, anyone have a view on doing it now when its sub ten degrees (either paint of thin coat render) or waiting until its warms up in a few months, will either adhere better if I wait a few months or does it not really make too much difference? The cement boards have a tarp over them at the moment so not too worried about keeping it like that for a while Cheers Link to comment Share on other sites More sharing options...
saveasteading Posted Tuesday at 16:07 Share Posted Tuesday at 16:07 1 hour ago, philcvk said: when its sub ten degrees Over 4 degrees and it's ok. If there is cement in the product then it is a chemical reaction, not drying, so this neds to be for at least a day, including early morning frost snaps. 1 Link to comment Share on other sites More sharing options...
Mr Punter Posted Tuesday at 17:25 Share Posted Tuesday at 17:25 For a couple of jobs I have specced Weber LAC and mesh onto cement type boards, sponge finished then painted. 6mm thick. It has stood the test of time. Thin coat beads. Material costs are about £12/m2. 1 Link to comment Share on other sites More sharing options...
philcvk Posted Tuesday at 19:29 Author Share Posted Tuesday at 19:29 thanks, the quotes on thin coat render have back £75-90 / sqm so far (labour and materials, excluding scaffolding), yet checkatrade guide says about £30-70 / sqm, just wondered what everyone's experience with thin coat price is here? the job is 50 sqm, base coat, fibreglass mesh, beading, top coat Link to comment Share on other sites More sharing options...
philcvk Posted 11 hours ago Author Share Posted 11 hours ago ah typo above .. checkatrade guide is more like 65-80 sqm https://www.checkatrade.com/blog/cost-guides/silicone-render-cost/ Link to comment Share on other sites More sharing options...
