On 25/01/2025 at 07:09, Beelbeebub said:
I think the benefit is from the manufacturer pov. The outdoor unit is a standard aircon unit
I agree. Having a standard unit is probably a good thing in terms of price and reliability, but my current thinking is to go with a monobloc - simpler and uses less space in the plant room. Plus it puts any potentially noisy bits outside.
The UFH will be a single zone and based around WC instead of thermostats. But I may hedge my bets and at least run the wiring for a thermostat in the bedrooms...
Just do wireless thermostat, easy, battery lasts a couple of years. You can also move it about.
We are running WC but use a thermostat to trigger a second operating point, basically WC plus 2 degrees. Use the thermostat to force the heat pump to run hotter during cheap rates period and also shelly relay across the terminals of the receiver to drive the heat pump hotter during excess solar production periods. Converted 3kWh of excess solar in to 11.5kWh of heat today for free.
  • 1 month later...
On 24/01/2025 at 15:44, PhilT said:
Surely it's similar to the English scheme whereby you can apply for the 7500 grant for a self build if it meets certain criteria
No, I don't think so. As far as I am aware there are no grants available here for self build.
I looked also, but from I could see, the £7500 is England and Wales. Grants for heat pumps is for people on benefits in Scotland. Nothing for new builds anyway.
I got my ASHP from eBay, there are plenty of bargains coming up. There were a couple of 6kW for £600, New unused.
That's what I've been looking for as well. Not been lucky yet, but I guess I will be at some point.
  • 10 months later...
Well, almost a year later and a lot has happened...
Build has started and the groundworks are more or less done. Timber frame kit is due to arrive in March. So I'm looking at the ASHP & UFH design again.
I'm a bit reluctant to delegate the design work to a specialist ASHP contractor as the two I've spoken to so far have suggested standard designs that either have multiple zones (one per room, complete with separate thermostats) or are massively over-specified for the house. Its only 140 m2, single level and very well insulated with MVHR, but one of the designs has a 8.5kW ASHP! Presumably these contractors would make a more accurate assessment once some money changes hands, but they don't fill me with confidence!
My own room-by-room calculations and Jeremy's spreadsheet suggest a total heat requirement of about 2.8kW worst case, dropping to about 1kW best case. A 4kW ASHP seems about right, with some margin at the top end (and for DHW), but how many will modulate down to 1kW? I've read every datasheet I can find, but very few manufacturers specify their minimum outputs. The 4kW Haier R290 that @JohnMo has just installed does indeed give this info: it will modulate down to 996W at +10C OAT and 35C flow, so this looks like a good fit for my case - it should be able to run without cycling for most of the time.
I'm interested to know how an ASHP actually modulates its output. Does it reduce the flow temp, while keeping the flow unchanged, or does it reduce the flow and keep the temp unchanged, or both?
Both. Most of the new ones have pwm pumps. It's also useful to confirm minimum flow temperatures as some are 25C some are 20C, but in some cases this really doesn't matter.
Thanks. That's what I was hoping (although it makes the UFH calculations more complex). The Haier ASHP will flow down to 20C, but this is below my 22C target temp of the bathrooms.
I think I've got enough data now to choose a suitable ASHP. Next step is the UFH design, but I'll take that into one of the existing threads to keep things simpler.
Not sure how useful that is in the real world. I currently have my compressor restart hysterisis set at 4 degs, any lower than that you don't get a successful restart because floor slab has then equalised in temperature and the heat pump has no where to dump the heat. So at a flow temp of 20, in real world you need what ever you are heating to to drop temperature down to 16 - that just will not happen.
My WC curve calculation says I need to flow 22 degs at 10 OAT, but I think realistically I may need to set a higher temperature. It's programmed like that for now, if we get a mild day any time soon I can test it.
I always find ensuites difficult to heat. We have the bedrooms cool, so heat from the ensuite just bleeds onto the bedroom. But even at around 20 they are comfortable as floor is radiating heat at you anyway
47 minutes ago, saveasteading said:
Don't you just need to  close the door?
That's easy - but when there are more than two in the house, almost never happens.
22 hours ago, AndySat said:
The 4kW Haier R290
Interesting fact, datasheet says at 30 degs and 2 degs outside the max output is 4.3kW.  However if you enable smart grid and use SG1 settings the ASHP pumps out 6kW, while giving a CoP of around 4.5.
Reason I did this was to heat the summer house to a usable temperature.
I think this is going to be a problem in my build as well. The floor area is small, even before I deduct the space taken up by the shower, toilet, handbasin etc. Probably it will just be a case of as much UFH pipe as will fit and add some extra heat with an electric towel rail when needed.
As long as the floor doesn't feel cold to walk on, it should be acceptable... Actually, I'd like to get some UFH pipe under the walk-in shower, but that might be ambitious!
Interesting! I am planning to use the SG capability to soak up any spare solar power, either by putting more heat into the slab, or pushing the DHW temp up a degree or two. But this is just a concept at this stage, I suspect it'll take at least the first year of actually living in the house to understand the trade-offs between putting solar power into the battery, or the ASHP, or selling it back to the grid. For now, I'm just making sure that these options are possible i.e. the necessary capability/connectivity is there.
Assuming the walkin shower is tiled then put in an electric UFH mat. You can get a former for the shower area to give a fall to the drain, electric mat over the whole floor then tile over the mat.
If you're getting batteries anyway and your solar is MCS accredited so you can get paid for PV export, then best £ROI solution that I can see is export everything you can @15p/unit and run the house off the batteries for much of the time charged @8p/unit on a TOU tariff. You'd need to work your own figures but my estimates suggest that's worth a few bob and worth recabling my PV so it's the first connection to the DNOs incoming supply so our new batteries can power the house while the PV runs to the grid
I tell all of my clients to have 4 seasons / 12 months of regular and normal living, and then we do a statistical download from the inverters etc to see what’s gone on (and if we need to / how we can improve things).
IR heaters in small en-suites work well. Particularly paired with a motion sensor for extract boost/hot water re-circ/ towel rail heating etc. You can get them as mirrored panels so you can admire yourself as you toast…
Do you have them? What sort of time delay do you get if switching by motion sensor?
