Temporary Driveway Surface
Mack27
Hi, with our build about to start, I am looking to install a temporary track/road for the heavy vehicles that will be attending site. Is type 1 MOT what I should be putting down and compacting? Should I install a membrane first?
Cheers
10 minutes ago, Alan Ambrose said:
Can I ask - are you planning to replace this later, or will it be your driveway base in future?
this is a great question! our planning stipulated free draining driveway so we had to have permeable sublayer so rather than putting down loads of hardcore/type 1 to only have to remove it later we dug down the required depth and filled it with what will be the final subbase layer and then put terram on top and a 100mm layer of cheapest hardcore on top of that for the lorries to drive on.
