I’m going to be installing some outdoor lights onto my cladding (thermo ayous). I’m trying to preempt and ensure there are holes/grommets etc in the correct positions but presumably the area should also be battened or a timber plate (plywood) fitted behind the cladding to give the light something strong to attach to?
23 minutes ago, Russell griffiths said:
Won’t you just screw it to the cladding
how heavy is this light ??
Thanks… just a standard light but wasn’t sure whether it’s better to support behind as well.
Depends on the cladding?  Are you using something substantial or DIY shop ultra thin shiplap cladding?
Thermowood cladding… good quality but slightly unsure about fixing strength as tends to be quite light and soft ish hence considering reinforcement.
If it's not something you're familiar with, then it's worth buying a pack of screws with plugs, so you know they are compatible, even though you only need a few.
I'd recommend a big brand too like Rawl or Fischer.
Get stainless steel screws if there is a choice.
Something like this.
They are fantastic for masonry.
For cladding I think battening where you know you’ll be putting a light is a really good idea.  The windage on some lights is huge and a rattling light is bad news.  I’d not go for ply myself behind the cladding as that might get wet from time to time, so a few extra treated battens in the right places is a good plan.
