At the moment we only have our ASHP and solar PV connected to our 3phase consumer unit. Other than that we have 4 temporary power sockets energised. We are using these to power our internet router/switch and MVHR from time to time and a couple of lights etc. Also power tools from time to time.
I am currently installing a 2.5m external LED strip. I checked carefully with the supplier that the strip and driver are compatible. You will see the specs in the photos. I cut the 5m strip down to the 2.5m required. I added a plug to the mains end of the driver and connected to the strip as a dry run in the house and it lit up as expected.
I have now fitted it outside. However on wiring up again to test each time I plug in the MCB trips. The strip doesn't light at all.
I am totally puzzled - why would it work first time around with the strip lit and no tripping but now not at all?
I have googled and most answers are talking about inrush current but these seems mainly connected to multiple drivers etc.
Any other ideas what might be going on? thanks
It's an rcbo that is tripping, so you don't know if it's tripping on over current or earth leakage.
Do you have another socket anywhere, even in a different property, that has rcd and mcb separate, plug it in there and see which one trips.
You mention cutting a longer LED strip short.  Did you cut it where shown and are you sure it was a clean cut with no whiskas that could short out?  I would expect some form of cap to go over the cut once done.
Thanks Dave. First question is how do I tell between mcb and rcd? Once I know that I can check what I have connected to our external power sockets on our shed. Then I might be able to run an extension cord from there.
Yes def cut in the correct spot and then sealed with special silicone glue I bought. The thing is after I did all this and mounted the strip in a metal housing and then clipped on the diffuser and then siliconed the end caps I tested it in the house and it worked fine. It was plugged in to the exact same power socket.
An MCB only has the "switch" not the little test button as well.  A consumer unit with just those, should have one or 2 big RCD's at the end of the row with the test button on.
So this has got me thinking. If this new driver lasts a similar time to the one that failed how do you plan to be able to replace these things? I assume you normally fit them in the circuit behind plasterboard. Once hidden away and the wall finished and plastered and painted what do you do if/when the driver fails? should you design in some sort of access hatch?
Do NOT build it into an accessible space.  It has to be accessible somehow e.g in a kitchen, on top of a wall unit etc.  Or even build it in behind the light switch and run dc to the light strip?
I don’t have that many LED strips and those I do have are under cupboards with the driver easily accessible. The recessed LED in the kitchen was a little harder so I extended the cables through a flexible duct (cable tidy) and fitted the driver in the cupboard behind the kitchen behind a wall plate.
On my current project most drivers will be tucked into the corners of cupboards. Where that's not possible they'll be in a secondary consumer unit, next to the main one, with one conduit for the main voltage cables between the switch and the driver, and another carrying 24V to the LEDs.
